Fidelizer eccellente ottimizzatore audio per Vista e seven
+17
Tigre Della Tazmania
Telstar
Saetta McQueen
grunter
audiofan
Link70
Miclaud
Menestrello
Massimo
21 partecipanti
Pagina 1 di 6 1, 2, 3, 4, 5, 6  Successivo
Fidelizer eccellente ottimizzatore audio per Vista e seven Empty Fidelizer eccellente ottimizzatore audio per Vista e seven
Messaggio Da Massimo Mar Mar 01, 2011 10:40 pm
grazie a bibo1 per la segnalazione copio e incollo
Prendendo spunto da AA, segnalo questo nuovo programma per l'ottimizzazione audio di Vista/Seven.
Promette bene
Fidelizer will instantly turn your Windows Vista/7 computer to audiophile workstation for sophisticated audiophile player like J River, XXHighEnd, HQPlayer, foobar, etc. It involves no permanent modifications so system will remain safe and sound after restart so even system with normal Windows installation can experience better sound quality when needed. I'm still considering adding some useful permanent tweaks after this program is proven itself.
Features:
-Stop over 80 services leaving only audio related ones
-Cutting edge core audio's thread, I/O priorities optimization
-State-of-art clock rate and resolution adjustment
After optimizing your system, most services related applications including network will stop running and some services may start again depending on running applications.
Please leave your feedback and suggestions for better and more flexible software in future.
You can download and test Fidelizer from http://www.windowsxlive.net/downloading-fidelizer
Let me know if it helps anything in your system.
The more it's digital, the more it's analogue
Massimo
Massimo
Data d'iscrizione : 05.02.08
Numero di messaggi : 1999
Provincia : Macerata
Fidelizer eccellente ottimizzatore audio per Vista e seven Empty Re: Fidelizer eccellente ottimizzatore audio per Vista e seven
Messaggio Da Menestrello Mar Mar 01, 2011 10:49 pm
Sembra molto interessante...
Fidelizer eccellente ottimizzatore audio per Vista e seven Fidelizer_0
appena ho tempo lo provo!
Ok
Menestrello
Menestrello
Data d'iscrizione : 24.01.11
Numero di messaggi : 3131
Provincia : molesto
Impianto : bacato
Messaggio Da Massimo Mar Mar 01, 2011 10:56 pm
Segnalo che sul mio pc gli dava fastidio mozilla, per farlo andare avanti ho dovuto toglierlo.
Massimo
Massimo
Messaggio Da Stentor Mar Mar 01, 2011 10:58 pm
Massimo ha scritto:Segnalo che sul mio pc gli dava fastidio mozilla, per farlo andare avanti ho dovuto toglierlo.
acchhh questo è un male.
Che benefici hai riscontrato dopo l'utilizzo?
Messaggio Da Menestrello Mar Mar 01, 2011 11:03 pm
Mozilla?? Shocked
male... Suspect
Menestrello
Menestrello
Provincia : molesto
Impianto : bacato
Messaggio Da Stentor Mar Mar 01, 2011 11:09 pm
Con Chrome da problemi ?
Messaggio Da Massimo Mar Mar 01, 2011 11:22 pm
Sul pc dove scrivo ora nessun problema nemmeno con moxilla.
Disabilitare l'antivirus prima di eseguirlo è meglio, con tutti i servixi che stoppa il vs antivirus potrebbe bloccarlo.
Impressioni.... necessito di un ascolto più critico, sul momento direi che è più che eccellente,
La cosa che ho gradito molto poco è che al riavvio del pc la pagina di default del mio browser è quella dell'autore del programma.
Massimo
Massimo
Messaggio Da Miclaud Mar Mar 01, 2011 11:24 pm
Massimo ha scritto:grazie a bibo1 per la segnalazione copio e incollo
Ciao Massi, bobo1 chi? Lo stesso di nexthardware.com? In ogni caso personalmente gli darò sicuramente un'occhio, magari confrontandolo con cmp2 Wink
Di fatto, lato software, la sostanza è quella. Magari però questo Fidelizer cura alcuni aspetto inediti...
Ultima modifica di Miclaud il Mar Mar 01, 2011 11:25 pm - modificato 1 volta.
Miclaud
Miclaud
Data d'iscrizione : 03.03.10
Numero di messaggi : 1915
Provincia : MC
-> Dell Wyse + Gentoo Player
-> Pre valvolare Sonus Mirus
(a.k.a. Xindak 3200 MKII)
-> B&O IcePower 50ASX2 BTL
Dual Mono
-> ProAc Response D15
http://www.unprogged.com
Messaggio Da Stentor Mar Mar 01, 2011 11:24 pm
Massimo ha scritto:Sul pc dove scrivo ora nessun problema nemmeno con moxilla.
Spiegati meglio sul più che eccellente Smile
Messaggio Da Miclaud Mar Mar 01, 2011 11:26 pm
Fossi in te Massimo mi farei una partizioncina dedicata all'ascolto audio dove puoi tirare al massimo le ottimizzazioni. Ad esempio, il primo che farei fuori sarebbe l'antivirus, solitamente un divorarisorse Wink
Comunque sembra un bello strumentino che automatizza molte cose che altrimenti andrebbero fatte manualmente.
Miclaud
Miclaud
Provincia : MC
Dual Mono
Messaggio Da Massimo Mar Mar 01, 2011 11:31 pm
Per esempio ho messo la latenza di foobar al minimo e nessunissimo problema.
Quanto all'ascolto credo, ma tiripeto devo fare un ascolto critico, ho avuto la nettissima impressione di un miglioramento generale
e maggiore ricchezza di definizione a tutte le frequenze, ma magari stasera sono in vena di ascolti e rilassato vedo anche quello che non c'è Laughing
Massimo
Massimo
Messaggio Da Stentor Mar Mar 01, 2011 11:35 pm
Aspetto con interesse delle tue impressioni in un ascolto critico Smile ..... sembra uno strumento interessante! Grazie per la segnalazione Smile
Messaggio Da Massimo Mar Mar 01, 2011 11:35 pm
Da tempo già fatto, ma con seven sul portatile è difficile far miracoli per quanto ottimizzato stavo sui 100 110 us.
ora la latenza nemmeno la conosco, perchè dpc latency non mi parte, e il pc per quello che non riguarda la musica è quasi inutilizzabile,
ma basta riavviare Hehe
Massimo
Massimo
Messaggio Da Silver Black Mer Mar 02, 2011 1:26 am
Sto programma è un virus! Scherzi a parte, si comporta come un toolkit che funziona in kernel level, probabilmente con un system-wide hook, non mi stupirei se chiedesse privilegi amministrativi prima di avviarsi... Suspect Un tale software è normale che faccia alzare più di un sopracciglio all'antivirus e secondo me a ragion veduta. Il fatto poi che modifichi la home page del proprio browser me lo farebbe rimuovere istantaneamente (se fosse un cavallo di Troia? se in realtà, oltre a ciò che dice, cominciasse a installare roba strana e ad avere comportamenti anomali? Tanto si fa dare privilegi amministrativi, per cui può fare tutto, anche installare rootkit, e pretende che l'antivirus venga disattivato... praticamente gli dai carta bianca).
Se proprio lo vuoi, io lo userei da macchina virtuale, così almeno se fa danni questi sono relegati alla macchina virtuale (sistema guest) e non al sistema vero e proprio (host).
Data d'iscrizione : 03.02.08
Numero di messaggi : 16700
Messaggio Da Massimo Mer Mar 02, 2011 5:30 am
Non viene rilevato come virus, alla scansione, ma solo dopo che lo si lancia.
Ma va a toccare un pò tutto ed a bloccare varie cose, e immagino che per questo
possa essere facilmente rilevato come virus.
Ha me lo hanno segnalato quelli di nexthardware, se è un virus o meglio un trojan, non ci fanno una gran figura Laughing Laughing li facciamo chiude
Nn mi va di formattare Laughing lol! lol! lol!
Massimo
Massimo
Messaggio Da Tfan Mer Mar 02, 2011 7:48 am
bè Gianluca (Bibo01) è una persona molto competente (lo conosco personalmente), se ha segnalato la cosa significa che è valida sicuramente, altro che trojan...
del resto se un programma esegue delle ottimizazioni audio oriented, compresa la disattivazione di parecchi servizi mi pare il minimo che l'antivirus lo segnali.... altrimenti cambierei antivirus!!
Data d'iscrizione : 02.09.08
Numero di messaggi : 2194
Provincia : Kepler186F
Messaggio Da Marco Ravich Mer Mar 02, 2011 7:51 am
Massimo ha scritto:ho avuto la nettissima impressione di un miglioramento generale
E' davvero magico !
Un programma che ottimizza le risorse per l'ascolto audio è un mistero come faccia a migliorare la qualità degli ascolti... al massimo la latenza...
Ragazzi, non facciamoci prendere dalla psicoacustica ! Laughing
nota: per il cambio dell'homepage basta togliere l'ultima spunta... o siete fra quelli che premono sempre "avanti" senza leggere quando installano qualcosa ?
Data d'iscrizione : 20.04.09
Numero di messaggi : 6070
Provincia : MC
https://www.forart.it/
Messaggio Da Massimo Mer Mar 02, 2011 12:13 pm
Marco lo hai provato?
Di misteri ce ne sono tanti nell'hifi , lol! , ma ti assicuro che non avevo bevuto lol!
Se trattasi di psicoacustica lo verificherò con ascolti prolungati
Massimo
Massimo
Messaggio Da Miclaud Mer Mar 02, 2011 3:46 pm
Tfan ha scritto:bè Gianluca (Bibo01) è una persona molto competente (lo conosco personalmente), se ha segnalato la cosa significa che è valida sicuramente, altro che trojan...
Confermo, sto avendo a che fare con Bibo (non al livello di Tfan) in questo periodo, nel suo forum, e credo sia proprio una fonta più che affidabile.
Confermo la bontà della soluzione e Bibo stesso potrà confermare che le ottimizzazioni non si fermano affatto qui...
Marco Ravich ha scritto:
E' davvero magico !
Marco! Ma proprio tu mi sei scettico su queste cose? Smile
E gli studi che stiamo facendo su cosa si basano, secondo te Wink
Ciao a presto
Michele
Miclaud
Miclaud
Provincia : MC
Dual Mono
Messaggio Da Menestrello Mer Mar 02, 2011 3:49 pm
Mi piacerebbe sapere in dettaglio che cosa fa Mmm
Ho fatto qualche ricerca l'altra sera ma mi son fermato quasi subito per mancanza di tempo.
Non ho trovato molto, anzi.
Qualcuno ha un link a qualche pagina di spiegazioni più dettagliata? Glasses
Menestrello
Menestrello
Provincia : molesto
Impianto : bacato
Messaggio Da wasky Mer Mar 02, 2011 3:52 pm
Massimo ha scritto:Ha me lo hanno segnalato quelli di nexthardware, se è un virus o meglio un trojan, non ci fanno una gran figura Laughing Laughing li facciamo chiude
Tacci loro Laughing
Messaggio Da wasky Mer Mar 02, 2011 3:54 pm
In un Pc Audio Oriented un antivirus non ci dovrebbe stare proprio tra i program file Hehe
Messaggio Da Stentor Mer Mar 02, 2011 4:03 pm
Sicuro ? ..in un PC audio oriented non devi mica collegarlo a internet per sentire anche gli streaming e scaricare le copertine/titoli ??? Smile
Messaggio Da Miclaud Mer Mar 02, 2011 4:07 pm
Credo Roberto volesse intendere in un Pc audio al suo estremo, inteso come una sorta di "meccanica" ottimizzata. Chiaramente ci sono diversi gradi di ottimizzazioni, alcuni dei quali prevedono comunque di mantenere il networking. Io stesso ho due partizioni, una stirata al massimo, l'altra che uso per filmati hd e navigazione Wink
Miclaud
Miclaud
Provincia : MC
Dual Mono
Messaggio Da wasky Mer Mar 02, 2011 4:28 pm
Se mi connetto in maniera sicura su radio selezionate e salvate su foobar in playlist, posso tranquillamente disattivare Firewall e defender, il mio PC è connesso in rete e acquisisce, dati e copertine da lastFM o da Apple Store ma, non ho explorer o altri browser Wink
Del resto in rete lo devo mettere, mi connetto da portatile comodamente seduto e navigo nel web dal notebook che uso per controllare il PC audio Transport
