Quanto Jitter è discernibile?
Quanto Jitter è discernibile? Empty Quanto Jitter è discernibile?
Messaggio Da R!ck Mer 15 Feb 2012 - 10:23
Mi sono posto questa domanda è la migliore risposta che ho trovato è questa:
Good quality Interconnects (need not be high priced) are important since they deal with low amplitude signals. The rest is up to you on how much you want to lighten your wallet.
Cables cannot introduce "new" jitter since it is only a medium/channel. But a bad channel/cable (a really bad one) can worsen the "pre-existing" jitter.
But is jitter in digital audio really the demon what it is made out to be? IMHO it is more over-hyped than the NASA moon mission!!!
It has been proven by innumerable measurement and listening tests by audio engineering experts and artists that jitter below 250 nS is undetectable by humans and you really need to have a pathetic cable or system to cause that much jitter. Any decent and modern design will conform to less than 1nS jitter and you need to have really badly manufactured cable to worsen it to 250nS or above.
Quoting a few studies (Highly recommended reading for the Jitter-Demon make-believe brigade!)
Theoretical & Audible Effects of Jitter on Digital Audio Quality by Benjamin & Gannon.
105th AES Convention, 1998
Jitter added to digital signal between transport and DAC with a hardware device.
Conclusions: Uncorrelated jitter inaudible below 10nS rms on pure tones, Uncorrelated jitter inaudible below 20nS rms on music signal
Detection Threshold for Distortions due to Jitter on Digital Audio by Kaoru Ashihara, Shogo Kiryu, Nobuo Koizumi, Akira Nishimura, Juro Ohga, Masaki Sawaguchi and Shokichiro Yoshikawa
Acoust. Sci. & Tech. 26, 1 (2005)
Jitter simulated in the digital domain.
Conclusions: Uncorrelated jitter inaudible below 250nS on music signal.
Ultima modifica di R!ck il Mer 15 Feb 2012 - 10:25 - modificato 1 volta.
R!ck
Data d'iscrizione : 03.09.09
Numero di messaggi : 4987
Provincia : ---
Impianto : -------------
Quanto Jitter è discernibile? Empty Re: Quanto Jitter è discernibile?
Messaggio Da HistoireDuSoldat Mer 15 Feb 2012 - 10:27
Punto.
Clap
HistoireDuSoldat
HistoireDuSoldat
Data d'iscrizione : 18.02.10
Numero di messaggi : 764
Provincia : Buono assai
Messaggio Da R!ck Mer 15 Feb 2012 - 12:08
kurt10 ha scritto:La emu 1212m collegata in digitale ha meno jitter della m2tech........
1° emu 1212m jitter 980ps pk-pk.
2° hiface m2tech jitter 1,30ns pk-pk.
3° musiland usd02 jitter 1,56ns pk-pk
(preso da videohifi..ma il link non va.)
In pratica non ci dovrebbero essere differenze imputabili al jitter
R!ck
Provincia : ---
Messaggio Da flovato Mer 15 Feb 2012 - 14:56
R!ck ha scritto:In pratica non ci dovrebbero essere differenze imputabili al jitter
Il jitter non esisteva ai miei tempi, quindi teoricamente le motivazioni delle differenze erano da imputarsi ad altri fattori.
Non so se i trasporti suonano differentemente per via dei diversi valori di jitter so solo che suonano differentemente uno dall'altro e questo mi basta e avanza.
Valutare se spendere 300/400 euro per far cambiare in un modo o nell'altro la riproduzione è sempre una valutazione strettamente personale... come cambiare puntina ad un giradischi.
Credo a quello che hai postato e a quello che scrivono ma credo sempre di più alle mie orecchie, alla fine quelle sono l'unica cartina tornasole.
UTENTE BANNATO
Data d'iscrizione : 23.12.10
Numero di messaggi : 12509
