Urd CD Transport and Unison USB™ Hub
dinamanu- UTENTE BANNATO
Numero di messaggi : 6340
Provincia : NoFlacx
Impianto : ClasseA
Re: Urd CD Transport and Unison USB™ Hub
Spin CDs...and seamlessly integrate with streamers and computers. Urd is the only CD transport with USB output and two USB inputs. So go ahead. Dig up those old shiny memories…and run them right next to your latest streams.
CD Transport with USB or SPDIF Output
Urd is the only CD transport that gives you Unison USB output, allowing direct connection to a USB-input DAC. Or, choose the included SPDIF outputs—coax and AES—for easy integration with any system.
USB Hub for Your Entire System
Here’s where things get interesting: you can also connect two USB devices to the Urd. Yes, Urd has two USB inputs! Then, choose what you want to listen to—CD, USB1, or USB2—using the standard remote control. Now, you can run CDs when you feel like it, and stream when you want convenience, all with a DAC with a single USB input.
Convert USB to AES and Coax, Too
What’s more, Urd can also convert the two USB inputs into SPDIF output, for integration with DACs that don’t have a USB input. It’s a versatile centerpiece of an entire digital system. Bring your discs and your computer, choose your DAC, and you’re ready for anything.
Super High Quality Throughout
Urd starts with a real StreamUnlimited metal tray-loading Redbook CD mechanism—not a cheap computer drive or slot-loader. From there, massive computing power, including four 32-bit microprocessors, and a 100% linear supply, including separate transformers for both the drive and digital sections, make Urd a CD transport that stands far above entry-level options.
Provincia : NoFlacx
Impianto : ClasseA
Provincia : NoFlacx
Impianto : ClasseA
Provincia : NoFlacx
Impianto : ClasseA
» Cerco Unison 100
» Mastersound vs Unison Research
» UNISON RESEARCH UNICO..........
» Transport budget
» unison unico (p, primo, nuovo etc)
» Transport budget
Oggi alle 10:16 Da Chardonnay
Oggi alle 10:06 Da Chardonnay
Ieri alle 21:26 Da lello64
Ieri alle 21:15 Da marco123
Ieri alle 5:05 Da AndreaCD
Ieri alle 1:03 Da Gabriele1
