Hi-END DIR9001+TDA1541A*4 NOS DAC Kit TDA1541?
wincenzo
kingbowser
Sapete dirmi come va il DAC proposto nel titolo? lo si trova su ebay a 228 euro al cambio attuale (318$) venduto da raindrop_hui. E' un po' caro, ma se è come penso con musica liquida darebbe filo da torcere alle migliori marche
sulla carta sembrerebbe un'ottima implementazione del chip Philips (a parte la mancanza di Toslink, l'entrata che servirebbe a me - ma quello volendo si risolve abbastanza facilmente...)
un link attualmente funzionante all'articolo
http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=220428123950
HI-END DIR9001+TDA1541A*4 NOS DAC Kit)
This reference of clip DIR9001 + TDA1541A*4 (Philips chip) parallel output version is extremely professional DAC product.
This DAC DIY KIT is fully assembled and tested.
Circuit design :
A. input : SPDIF (coaxial) and I2S.
B. DIR9001 as digital receiver + TDA1541A*4 parallel output.
C. NOS (non over sampling) design, no digital filter
D. Reserve the analog output for difference music favorite ( say for op-amp, tube or HDAM output ).
*optional : HDAM analog output kit provided on ebay
E. Deluxe and audio grade components selected
1) The use of 56 pcs. RIFA film capacitors of high frequency response for the filtering by the sides of 4 x TDA1541A
2) All high grade capacitors ELNA brown, Nichicon and WIMA black WIMA154CBB capacitors for the bypass and filtering.
3) Fast switching rectifiers D3S81 and LT108* voltage regulator were used for the power supply.
4) Total 7 groups of power source with 2 stages regulation design.
0-18Vac x 2, 0-9Vac x5
5) Resistors are using U.S. Military grade DALE Resistors.
6) All gold-plated IC sockets
F. PCB design:
PCB is 2 mm thickness of double-sided gold-plated copper foil with high-frequency design. PCB size: 263mm x 223mm. and weight = 0.945kg
Circuit diagram are provided.
Numero di messaggi : 1176
Re: Hi-END DIR9001+TDA1541A*4 NOS DAC Kit TDA1541?
se vuoi spendere abbastanza per il DAC io ti suggerirei questo:
http://t-class.niceboard.org/dac-f42/un-superdac-almeno-sulla-carta-t2828.htm
al momento quello indicato da pincellone sembra l'unica implementazione, di questo chip, presente sul mercato; per di più è tutto esaurito al momento si può solo ordinare. Poi ci sarebbe questo integrato che ha anche il DAC EES Sabre
http://www.6moons.com/audioreviews/peachtree3/nova.html
Nella recensione si dice chiaramente che il convertitore è la parte migliore dell'amplificatore.
Insomma secondo me fra un pò aumenterano i prodotti con questo DAC e magari ad un prezzo più accessibile, se puoi aspettare forse ne vale la pena.
Numero di messaggi : 2531
Ne parlano piuttosto bene qui link ma tieni presente che dovrai spendere altri soldi per farlo funzionare, e non mi riferisco solo ai tre trasformatori
piero7- Membro classe oro
http://www.lampizator.eu/LAMPIZATOR/REFERENCES/DAC%20Four_TDA/fourTDA_dac.html
''it generally has very serious pretensions to be the best DAC that I know of. I am now listening and already preferring it to the AD1865. Very very small difference, but the TDA - being a TDA - has that something that no other DAC has.
If they were women, AD1865 would be the pretty one, but the TDA would be the pretty AND WISE one.''
kurt10- Membro classe bronzo
Numero di messaggi : 1625
King, su diyaudio un tedesco l'ha pesantemente modificato, con stadio di uscita a valvole ed alimentazione sempre valvolare piuttosto curata, fikus sul suo sito ne dice più che bene, dopo le modifiche... Hai visto le sue modifiche? E' partito dalla base di idee del buon Fikus
A me sto dac me piace un sacco!!! E da quello che leggo, il suo punto forte è proprio nella naturalezza della zona media, suadente e fascinosa!!!!
quasi quasi...
quasi quasi...
Io sono in dubbio se modificare le essence con i burson o farmi un dac esterno usb..
Quasi quasi.. il fatto è che con la essence non ho bisogno del pre perchè lo stadio di amplificazione è già on board..
Mentre con il dac forse dovrei prenderlo..
Skywalker- Membro di riguardo
- Data d'iscrizione : 17.05.09
Numero di messaggi : 876
Skywalker ha scritto:Io sono in dubbio se modificare le essence con i burson o farmi un dac esterno usb..
ma prendi quelli di audio-gd....
molti che li hanno ascoltati han detto che i burson sono moooolto meglio
Skywalker ha scritto:molti che li hanno ascoltati han detto che i burson sono moooolto meglio
costano pure mooooooooooooooolto di più!
Io, ci metterei un bello stadio a valvole....
A Bursom glieli fa Audio-GD...
Se te ne servono ne ho quacuno, comunque.
Felfra- Appassionato
- Data d'iscrizione : 12.10.08
Numero di messaggi : 405
a leggere pctuner par di no..
ecco la rece
http://www.pctuner.net/articoli/schede_audio/1279/Integrati-VS.-discreti-qual-e-la-scelta-migliore-per-la-nostra-scheda-audio/
cmq quali e quanti ne hai e a che prezzo?
ecco la rece
mah..Skywalker ha scritto:Mentre con il dac forse dovrei prenderlo..
se intendi il discorso in ottica "adattamento di impedenze" mi faccio da parte, se invece parli dei livelli di tensione di uscita..
io esperienza poca (2-3 sorgenti e un solo DAC, peraltro esemplare unico )
tieni presente che il mio (come praticamente tutti i DAC mid-lowcost) ha uno stadio di conversione I/V ad OpAmp,
che credo amplifichi pure un poco, il DAC esce praticamente quasi allo stesso livello della mia sorgente più alta (il Trevi3540)
ovvero AMPIAMENTE sufficiente a qualsiasi finale con un minimo di guadagno (diciamo dai 20 dB in su, classico gainclone, SureTK,...)
intendo condurre una guerra contro il mondo dei (troppi) dB di guadagno
la sera, quando ascolto a volume MOLTO basso, devo girare sull'uscita analogica, per usare anche il controllo digitale del volume,
perchè solo col pot del pre non riesco, troppo basso sta per fare regolazione fine (ho casse da 89dB e 38dB di guadagno tra pre e finale,12+26)
il pot l'ho pagato tutto, se va bene ne uso un terzo..
mediamente, quando ascolto musica con ZERO dB di guadagno tra pre e finale, sto ascoltando musica ad un livello soddisfacente..
madqwerty- Moderatore
Skywalker ha scritto:a leggere pctuner par di no..
ecco la rece
ecco la rece
Be', la recensione non mi pare nemmeno seria, tanto sono grossolani i giudizi e sparati senza nemmeno parlare di sfumature, sembra che da un operazionale all'altro cambi l'impianto da un full Kondo a una radiolina. Recensoni el genere squalificano la categoria dei recensori, secondo me...
Comunque io ho dei Moon, 40 euro spediti la coppia (comprese le due prolunghette)
» DIR9001+TDA1541A*4 NOS DAC
» NEW TDA1541A-1.0U OS NOS DAC@USB@SAA7220@26C32+DIR9001
» [VENDUTO] DAC TDA1541 - 200€ + ss
» Il mio progetto con i TDA1541A
» TDA1545: differenze dal TDA1541?
