File "Cascade Noise" per rodaggio e sbrinamento impianti
+6
zenit
SaNdMaN
H@L
gabmak
thepescator
10 partecipanti
Segnalo The Cascade Noise / Burn in disc, un file scaricabile gratis che contiene 74' di rumore per rodare dispositivi audio e anche per "smagnetizzare" e "sbrinare" gli impianti di quando in quando.
The new CASCADE noise burn-in disc is a proprietary combination of white noise with frequency tone bursts and pink noise mixed at different levels. However, what makes it really effective is a series of descending and ascending (cascading) multi-octave square sweeps for better and more complete results than any other “burn-in” discs that have been made to date. The CASCADE noise burn-in disc may be used with audio electronic component and with audio cable including cables with attachments such as batteries or filter networks. Before and after results will be obvious with any of these cables.
Numero di messaggi : 2889
Re: File "Cascade Noise" per rodaggio e sbrinamento impianti
Smanetton ha scritto:Segnalo The Cascade Noise / Burn in disc, un file scaricabile gratis che contiene 74' di rumore per rodare dispositivi audio e anche per "smagnetizzare" e "sbrinare" gli impianti di quando in quando.The new CASCADE noise burn-in disc is a proprietary combination of white noise with frequency tone bursts and pink noise mixed at different levels. However, what makes it really effective is a series of descending and ascending (cascading) multi-octave square sweeps for better and more complete results than any other “burn-in” discs that have been made to date. The CASCADE noise burn-in disc may be used with audio electronic component and with audio cable including cables with attachments such as batteries or filter networks. Before and after results will be obvious with any of these cables.
Numero di messaggi : 1015
Provincia : easy
Impianto : Bushmaster MKII
tpa3116
cavi
Neat Motive 2
Scarico al volo. Grazie!!!
gabmak- Interessato
- Data d'iscrizione : 26.03.13
Numero di messaggi : 33
H@L- Membro di riguardo
- Data d'iscrizione : 12.06.09
Numero di messaggi : 678
Provincia : Cagliari
Occupazione/Hobby : apprendista stregone dell'Hi-Fi
- Sorgenti Mac Mini, hiFace, SuperPro DAC 707 USB, Beresford TC-7520, Peachtree DAC•iT.
Preamplificatori KingRex Pre-Amp V.3, Xindak XA3200-MKII.
Amplificatori Trends Audio TA-10.1, KingRex T20U con PSU, Virtue Audio Two.
Integrato TEAC A-H01S.
Diffusori Duevel Planets, Sonus Faber Toy Speaker, JohnBlue JB3.
Cuffie Docet Cuffia-Amp e...
AKG K 701.
SaNdMaN- Membro classe oro
Numero di messaggi : 5972
Trasporto: M2Tech HiFace Two
Grazie per la segnalazione.
MA mi aiutereste a scaricare il file? cliccando su download si apre una nuova finestra dalla quale posso ascoltare il file e non scaricare
zenit- Membro di riguardo
- Data d'iscrizione : 27.09.11
Numero di messaggi : 697
Tasto dx su download e fai salva con nome
gabmak- Interessato
Grazie riuscito con explorer, con crhome non mi dava l'opzione
Tasto DX e poi "salva destinazione con nome"
Grazie mille...salvato! Alla prima occasione utile lo provo!
Ciao Mauro
Ciao Mauro
emmeci- Membro classe oro
l'ho sempre fatto ascoltando, ma questa volta mi faccio tirare dentro
Numero di messaggi : 3693
Provincia : PU
diffusori - Stabilo 880 Woody
il resto è diy montessoriano
Ne avevo uno in CD .....i rumori si assomigliano ....ma i risultati rispetto ad un normale riscaldamento dell'impianto e dei diffusori con della normalissima musica?
Secondo voi ci sono?
Stentor ha scritto:Ne avevo uno in CD .....i rumori si assomigliano ....ma i risultati rispetto ad un normale riscaldamento dell'impianto e dei diffusori con della normalissima musica?
Ivano, ho quello della XLO e IHMO per una rodata veloce delle elettroniche (sorgente, ampli, cavi, ecc.) è ottimo. Se lo lasci tutta la notte anche a volume minimo, la mattina senti delle differenze. Ovviamente ti parlo di componenti nuovi. Fatta la prova con un normale CD non produce gli stessi effetti. O meglio. Diciamo che questi CD Burn-in velocizzano il rodaggio. Non che con un normale CD non si possa fare, ma ci vuole più tempo.
PS: sui diffusori IHMO è favoloso (XLO). Anche a volume non troppo alto i woofer si muovono che è una bellezza
E tu vuoi dirmi che dopo una nottata, con la corrente elettrica cambiata (a diverse ore ci son diverse tensioni e disturbi a volte), con la tua testa cambiata dopo aver dormito ...riesci a discernere le differenze per aver utilizzato un CD con un rumore invece che normale musica ?
Stentor ha scritto:E tu vuoi dirmi che dopo una nottata, con la corrente elettrica cambiata (a diverse ore ci son diverse tensioni e disturbi a volte), con la tua testa cambiata dopo aver dormito ...riesci a discernere le differenze per aver utilizzato un CD con un rumore invece che normale musica ?
E' esattamente quello che scritto E non si tratta di "rumore"
SaNdMaN ha scritto:Stentor ha scritto:E tu vuoi dirmi che dopo una nottata, con la corrente elettrica cambiata (a diverse ore ci son diverse tensioni e disturbi a volte), con la tua testa cambiata dopo aver dormito ...riesci a discernere le differenze per aver utilizzato un CD con un rumore invece che normale musica ?
A me basta uno sbadiglio per invalidare le mie prove d'ascolto, dopo una nottata passata dormendo non mi esprimo sul risultato di questa traccia.
Però son contento che la cuffia si sia fatta un ampio giro per frequenze che sono in minoranza negli ascolti di tutti i giorni.
Provincia : PU
Azz, ma è in MP3 !!!Smanetton ha scritto:Segnalo The Cascade Noise / Burn in disc, un file scaricabile gratis che contiene 74' di rumore per rodare dispositivi audio e anche per "smagnetizzare" e "sbrinare" gli impianti di quando in quando.The new CASCADE noise burn-in disc is a proprietary combination of white noise with frequency tone bursts and pink noise mixed at different levels. However, what makes it really effective is a series of descending and ascending (cascading) multi-octave square sweeps for better and more complete results than any other “burn-in” discs that have been made to date. The CASCADE noise burn-in disc may be used with audio electronic component and with audio cable including cables with attachments such as batteries or filter networks. Before and after results will be obvious with any of these cables.
Nonono, non ci siamo !
Se fosse in flac funzionerebbe ?
Ivano, io ho questo della XLO, come ti avevo detto, http://www.hi-figuide.com/musica/strumenti/2008/1/index.html
Quest'ultimo l'ho scaricato, ma non l'ho usato e non so dirti se porta a migloramenti.
Quello della XLO IHMO è eccezionale
» Positive Noise
» Che Bit sto Ascoltando ora
» NOISE KILLER BLU
» ESS SABRE DAC es9012: progetti
» Stamattina... Oggi pomeriggio... Stasera... Stanotte... (parte 14)
» NOISE KILLER BLU
Oggi alle 18:26 Da MarcoHD
» Aiyima A07 - mi arriva oggi
» Thorens TD 320 mkll
Oggi alle 7:45 Da Quaiozi!
» Thorens rumore
Ieri alle 22:29 Da Quaiozi!
Ieri alle 13:08 Da Quaiozi!
» GAP nel TU SE
» Amplificatore per Kef q7
» Ritorno braccio
» Wiim Amp
