LUMIN - The Audiophile Network Music Player
A soli 6000 Euri...
Bello è bello
http://www.luminmusic.com/index.html
rece:
http://www.6moons.com/audioreviews/lumin/1.html
Specification
Streaming Protocol:
UPnP AV protocol with audio streaming extension
Gapless Playback
On-device Playlist
Supported Audio File Formats:
DSD Lossless:
DSF (DSD), DIFF (DSD), DoP (DSD)
PCM Lossless:
FLAC, Apple Lossless (ALAC), WAV, AIFF
Compressed (lossy) Audio:
MP3, AAC (in M4A container)
Supported Audio Sample Rates, Bit Depths, Number of Channels:
PCM, 44.1khz-384kHz, 16-32bit, Stereo
DSD, 2.8MHz, 1bit, Stereo
Supported Control Devices:
All models of Apple iPad (iPad 2 or later recommended). iOS 5.0 or later required
Input:
Ethernet Network 100Base-T
Outputs:
Analog Audio:
XLR balanced, 4Vrms, pin 2 Hot
RCA unblanced, 2Vrms
Digital Audio:
BNC SPDIF:
PCM 44.1khz-192kHz, 16-24bit
HDMI:
DSD 2.8MHz, 1bit
Analog Output Stage:
Wolfson WM8741 DAC chips, 1 per channel
Fully balanced layout with discrete components
Output connectors coupled with LUNDAHL LL7401 output transformer
Pysical:
Lumin (solid aluminum chassis):
350mm (W), 345mm (D), 60mm (H), 8kg
Dual-toroidal PSU:
100mm (W), 295mm (D), 55mm (H), 2kg
Power Consumption:
Operation: 20W
Standby: 15W
Others:
Firmware Upgradable for further features and enhancements
Bello è bello
rece:
Specification
Streaming Protocol:
Gapless Playback
On-device Playlist
DSD Lossless:
PCM Lossless:
Input:
Outputs:
Analog Audio:
Digital Audio:
BNC SPDIF:
HDMI:
DSD 2.8MHz, 1bit
Pysical:
Dual-toroidal PSU:
Power Consumption:
Operation: 20W
Standby: 15W
Others:
Numero di messaggi : 1574
Provincia : kefiano...
Re: LUMIN - The Audiophile Network Music Player
Bellino davvero ma 6000 euro non ce li spenderei. Con mooolto meno puoi ottenere le stesse prestazioni e il DAC è integrato oppure te lo scegli tu (io lo uso con il mio DAC e ho preso la sola scheda NMR).
https://www.tforumhifi.com/t32125p30-oggetto-misterioso#583103
C'è anche la sorgente di Gappone / Giovanni che va molto bene
http://www.chiaki.cc/Transport/index.htm
Numero di messaggi : 1696
Provincia : Pisa
Impianto :- premi per vedere:
- pannelli T-class
- IKEA bass trap
- Metal bass trap
- Limp mass bass trap
- Soundwall
- CD: Marantz SA-11S2
- pannelli T-class
beato chi può
l'invidia non è tanto per l'oggetto (effettivamente bello e probabilmente valido), quanto per la possibilità di spendere una cifra simile solo per un "player".
eddy1963- Appassionato
- Data d'iscrizione : 29.11.12
Numero di messaggi : 360
Provincia : rm
Occupazione/Hobby : agente di commercio / arte in generale
Impianto : raspberry pi3 b+ - topping d30 pro gustard x-16 - moode / dussun v6i / dynaudio bm15 + isoacoustics
desktop win11 - jriver - audio-gd 28.38 - dynaudio bm5 compact + isoacoustics
xduoo x3ii + akg k702 - ifi zen dac + beyerdynamic dt250 80ohm - audio-gd 28.38 + (hifiman sundara - tripowin hbb mele)
Mamma mia che spettacolo... fatto veramente benissimo!
Certo però... 6000 euri... so un pò troppi!
Numero di messaggi : 3781
- Impianto principale:
Testina: Ortofon Super OM40
Pre Phono: NVA Phono 1
Impianto in camera:
Sorgente: iMac 27"
Giradischi: Rotel RP-900
Testina: Ortofon 2M Red
Pre Phono: Cambridge P540
» Network player, quale?
» Yamaha CD-N500 - cd + network player
» Audiophile Stream Network
» Pioneer N-50 "network player"
» Pioneer N-50 - network player
Oggi alle 19:43 Da Simone63
Oggi alle 19:11 Da Alessandro Gurato
Oggi alle 16:34 Da ste-65
» Ppreamp per finale PA
Ieri alle 14:01 Da root
Ieri alle 13:58 Da root
» Piatto Thorens TD166 MK2
Ven 31 Mag 2024 - 8:38 Da Quaiozi!
» Consiglio acquisto cuffie con dac fiio ka17
Gio 30 Mag 2024 - 21:55 Da tonyd77
Gio 30 Mag 2024 - 20:44 Da saltonm73
Mer 29 Mag 2024 - 11:38 Da philball1959
» FOZGOMETER
Mer 29 Mag 2024 - 11:28 Da philball1959
» Thorens TD 320 mkll
» Thorens rumore
» 2 Ampli e un Subwoofer
» Aiyima A07 - mi arriva oggi
» GAP nel TU SE
» Amplificatore per Kef q7
» Ritorno braccio
