Il tipo di codec influisce sul DR?
Il tipo di codec utilizzato influisce in maniera minima sulla gamma dinamica e un po' più significativa sul level shifting dei canali, ma credo che sia la perdita di dinamica che lo sbilnciamento del VU meter sui due canali dipenda dalla perdita delle alte frequenze, presenti in maniera diversa sui due canali.
Canzone scelta: For Whom The Bell Tolls - Metallica
Ho provato diverse impostazioni di compressione: media (192kbps), alta (96kbps) ed estrema (48kbps) per i codec MP3, M4A e WMA. L'm4a si ferma a 96kbps, non ho potuto fare il 48kbps
Ecco i valori:
Buona giornata.
Ecco i valori:
- Wave:
- Peak Value: -1.56 dB --- -0.27 dB
Avg RMS: -14.50 dB --- -14.26 dB
DR channel: 11.68 dB --- 12.73 dB
Official DR Value: DR12
Samplerate: 44100 Hz
Channels: 2
Bits per sample: 16
Bitrate: 1411 kbps
Codec: PCM
- MP3 @ 192:
- Peak Value: -1.83 dB --- -0.54 dB
Avg RMS: -14.75 dB --- -14.51 dB
DR channel: 11.80 dB --- 12.73 dB
Channels: 2
Bitrate: 192 kbps
Codec: MP3
- MP3 @ 96:
- Peak Value: -1.40 dB --- -0.86 dB
Avg RMS: -14.87 dB --- -14.65 dB
DR channel: 11.90 dB --- 12.64 dB
Channels: 2
Bitrate: 96 kbps
Codec: MP3
- MP3 @ 48:
- Peak Value: -2.02 dB --- -0.79 dB
Avg RMS: -14.87 dB --- -14.69 dB
DR channel: 11.64 dB --- 12.73 dB
Channels: 2
Bitrate: 48 kbps
Codec: MP3
- M4A @ 192:
- Peak Value: -1.26 dB --- -0.03 dB
Avg RMS: -14.47 dB --- -14.24 dB
DR channel: 11.87 dB --- 12.83 dB
Channels: 2
Bitrate: 152 kbps (non so perchè mi dà 152)
Codec: AAC
- M4A @ 96:
- Peak Value: -1.70 dB --- -0.26 dB
Avg RMS: -14.48 dB --- -14.27 dB
DR channel: 11.51 dB --- 12.73 dB
Channels: 2
Bitrate: 96 kbps
Codec: AAC
- WMA @ 192:
- Peak Value: -1.28 dB --- -0.36 dB
Avg RMS: -14.47 dB --- -14.22 dB
DR channel: 11.91 dB --- 12.59 dB
Channels: 2
Bitrate: 193 kbps
Codec: WMA
- WMA @ 96:
- Peak Value: -0.93 dB --- -0.26 dB
Avg RMS: -14.40 dB --- -14.18 dB
DR channel: 12.23 dB --- 12.77 dB
Channels: 2
Bitrate: 97 kbps
Codec: WMA
- WMA @ 48:
- Peak Value: -0.66 dB --- -0.49 dB
Avg RMS: -14.18 dB --- -14.27 dB
DR channel: 12.11 dB --- 12.53 dB
Channels: 2
Bitrate: 49 kbps
Codec: WMA
Buona giornata.
pij- Affezionato
- Data d'iscrizione : 04.05.15
Numero di messaggi : 181
Provincia : Frosinone
Impianto : CDP: AMC CD8, Gira: Thorens TD321 / Linn Basik LVX / Linn K9, Amplificatore: HK AVR255.
Cuffie: Grado SR325e, Koss Porta Pro.
Re: Il tipo di codec influisce sul DR?
pij ha scritto:Il tipo di codec utilizzato influisce in maniera minima sulla gamma dinamica e un po' più significativa sul level shifting dei canali, ma credo che sia la perdita di dinamica che lo sbilnciamento del VU meter sui due canali dipenda dalla perdita delle alte frequenze, presenti in maniera diversa sui due canali.
Bel confronto.
Comunque il DR è stimato su blocchi di 2 sec, quindi troppo lunghi per essere veramente influenzati dal codec.
Se mai il codec pesa sugli acuti e sulla micro-dinamica.
Barone Rosso- Moderatore
Barone Rosso ha scritto:Comunque il DR è stimato su blocchi di 2 sec, quindi troppo lunghi per essere veramente influenzati dal codec.
Avevo fatto questo confronto proprio per dimostrarlo, visto che avevo notato su Internet utenti che sostenevano l'inaffidabilità dei valori riportati sul DR Database che riportavano la scritta LOSSY sotto al codec.
pij- Affezionato
pij ha scritto:Barone Rosso ha scritto:Comunque il DR è stimato su blocchi di 2 sec, quindi troppo lunghi per essere veramente influenzati dal codec.
Il DR a grandi linee misura il rapporto fra livello massimo e minimo sui blocchi di 2sec.
Si tratta di un tipo di misura che non può essere in alcun modo influenzato dai codec lossy; ameno che non si facciano compressioni eccessive.
Chi pensa che i codec lossy influenzano il DR non ha capito lo scopo di tale misura e sul come funziona
» Alimentazione filamenti influisce sul suono?
» Musica da PC: il computer influisce sulla qualita?
» quanto influisce la distanza tra il punto di ascolto e la parete opposta ai diffusori?
» Eac
» Eac
» Aiyima A07 - mi arriva oggi
» Thorens TD 320 mkll
Oggi alle 7:45 Da Quaiozi!
» Thorens rumore
Ieri alle 22:29 Da Quaiozi!
Ieri alle 13:08 Da Quaiozi!
» GAP nel TU SE
» Amplificatore per Kef q7
» Ritorno braccio
» Wiim Amp
