[OPEN SOURCE] Preamplificatore bilanciato
Appena scoperto su GitHub questo interessante progetto su cui, al momento, abbiamo questi "indizi":
Per chi volesse approfondire/collaborare, la pagina ufficiale è la seguente:
https://github.com/gkeeth/preamp-2019
preamp-2019 ha scritto:
Balanced input & output preamplifier with volume and balance controls.
Based on preamps designed by Doug Self (see Small Signal Audio Design by Douglas Self)
The preamp is split over several PCBs, with a kicad project for each:
- balanced_amplifier: volume/balance controls
- power_supply: power supplies for
- positive analog rail
- negative analog rail
- digital/relay rail
input_output: board with input/output jacks and relays to select the desired input input_select: board with pushbutton controls and logic to select desired input
enclosure: consider Hammond 1441-16BK3CWW
dimensions: 10" W x 6" D x 2" H
necessary parts:
- enclosure (1441-16BK3CWW) - $65.03
- bottom plate (1431-16BK3) - $8.90
- screws (1421J6BK) - $5.87 (mouser)
- feet (1421T6CL) - $7.13
transformer: consider Triad VPT30-1670
dimensions: 83mm D x 36mm H (1.42" height)
15VAC parallel / 30VAC series, 50VA max
$32.47
power switch: consider E-switch RC1083BBLKBLKFF0
4.7mm faston/0.187"
power filter/inlet: consider Schaffner FN9260-6-06
faston 6.3mm/0.25"
input selection switch: https://www.digikey.com/product-detail/en/c-k/A10405RNCQ/CKN11161-ND/3751691
» [OPEN SOURCE] Riuso amplificatori TV
» [PROGETTO OPEN SOURCE] GodDAC
» [GUIDA] Crossover/EQ digitale con software open source
» [OPEN SOURCE] rilasciato ReactOS 0.3.16
» [OPEN SOURCE] Multiamplificatore basato su TA7377
» Aiyima A07 - mi arriva oggi
» Thorens TD 320 mkll
Oggi alle 7:45 Da Quaiozi!
» Thorens rumore
Ieri alle 22:29 Da Quaiozi!
Ieri alle 13:08 Da Quaiozi!
» GAP nel TU SE
» Amplificatore per Kef q7
» Ritorno braccio
» Wiim Amp
