CODE ACOUSTICS: An independent British Hi-fi company specialising in active loudspeakers.
Code Acoustics ha scritto:SYSTEM-1
Aim: SYSTEM-1 from the outset was always going to be an active 3-way DSP speaker.
Amplifiers: The amplifiers are the latest generation Hypex n-core OEM modules. There are a pair of dedicated 100 watt amplifier for the tweeters, which have incredibly low distortion in the milliwatt and single digit watt region where a tweeter often operates.
Homepage: https://www.code-acoustics.com/
Whitepaper: https://code-acoustics.blog/2017/05/27/system-1-white-paper/
Re: CODE ACOUSTICS: An independent British Hi-fi company specialising in active loudspeakers.
Niente male.
Anche questi però...
https://www.k4revenge.com/k56/
Numero di messaggi : 11584
giucam61 ha scritto:Niente male.
Numero di messaggi : 4290
Provincia : CA
Nel primo caso parliamo di "aiend & muchsord":
...mi auguro che, nel prezzo, forniscano anche la compagnia per GODERSI l'impianto (foto presa dalla homepage):
Devo però ammettere che questo approccio è proprio "nelle mie corde":
The Rational Audiophile's DIY project
Code Acoustics ha scritto:An active 3-way speaker for £6,350.
Code Acoustics ha scritto:Cabinet Principle:
In small rooms, the speakers often have to sit close to the rear walls or in a corner. The problem with this is the speakers can easily excite room modes. These are specific frequencies predominantly in the bass region that relate to the physical dimensions of the room.
When a bass note in your music is around the frequency of the room mode (there will be several at varying frequencies) it will sound particularly pronounced and can literally sound like a ‘BOOM’. This is a rather annoying and obvious distortion, as it can completely take over the listening experience.
Sealed vs. Ported cabinet:
Ported speakers are particularly bad for activating these modes and the problem is exacerbated by these speakers needing to play at reasonable volumes to correctly activate the ports and sound neutral.
Various types of room modes:
Sealed speakers in contrast sound fairly neutral irrespective of volume and don’t cause booming anywhere near to the same extent. This in combination with good transient response, a gentle bass roll-off and limited re-radiation of energy, makes it the preferred choice.
Per gli "indigenti" come me, c'è anche questo interessante (ed economico) progettino che mi stuzzica non poco:giucam61 ha scritto:Niente male.
interessanti,
per quello di k4 biogna ammettere che un Woofer da 18 pollici non ci sta proprio ovunque...
per quello Rational, tutto ok ma il condensatoe da 80mF è decisamnte troppo alto di valore, non protegge abbastanza il TW, nel malaugurato caso che l'HPF abbia un problema e non tagliasse adeguataente, il valore opportuno è sui 10mF, inoltre trovare un condensatore da 80mf di qualità costa un botto...
Mauro
Think before click
SubitoMauro- Moderatore
Numero di messaggi : 1941
Provincia : Alto Milanese
Impianto : Nad C 356 BEE
Dynaudio Emit M20
Sennheiser HD380pro
Il possessore del 4k sta valutando di amplificare i tweeter con un ampli più raffinato,il secondo,per le mie conoscenze informatiche, è troppo complicato e con altoparlanti veramente economici
» [FE-BO] Vendo tutto!!!!!!
» British Bands Medley
» Martin Audio MLA
» Conoscete Secret Rabbit Code ?
» Cambridge P35, un amplificatore molto British
» Martin Audio MLA
» Thorens TD 320 mkll
Oggi alle 7:45 Da Quaiozi!
» Thorens rumore
Ieri alle 22:29 Da Quaiozi!
Ieri alle 13:08 Da Quaiozi!
Ieri alle 11:33 Da MarcoHD
» GAP nel TU SE
» Amplificatore per Kef q7
» Ritorno braccio
» Wiim Amp
