Daphile - Audiophile Music Server & Player OS
+78
TheDarkKnight
JERRY_2000
root
iwata78
ulisse
brico
ARGENTAX
gipione
manitux
Marko
magistercylindrus
Jupiter8
Luca Marchetti
tano.longo
Fabster
alessandro1
gigihrt
Pierpaolo Pennacchietti
vito
wild
green marlin
no-fi
fuzzu82
C-3PO
vastx
giangievo
b.veneri
Sigmud
franz 01
sodis11
Dreammachine
apremi
elenesther
andreaea
germolo
tix88
wcartman
Docarlo
Fat george
Alessandro Asborno
Roberto7627
meraviglia
Antonello Alessi
zenit
alluce
Miclaud
luigigi
sontero
dankan73
segugio74
aleaudio2010
kereos
danilopace
arivel
sickshotshow
trecentodueotto
Alessio Zenga
handros
ghiglie
MDT360
iperv
kurt10
82 partecipanti
Pagina 1 di 27
Pagina 1 di 27 • 1, 2, 3 ... 14 ... 27
http://www.daphile.com/
http://www.daphile.com/download/Instructions.pdf
Daphile is an audiophile class music server & player OS – targeted to dedicated headless PC.
Features
Headless music server OS
Bitperfect and gapless playback of common audio formats up to 192kHz/24bit
Automatic configuration of music player for each audio device
Multiplayer support (eg. multiple USB DACs)
CD ripping with automatic metadata tagging and cover art
Supports external file servers as music source (CIFS, NFS, sshfs & ftp)
Easy configuration and installation through the web interface
WiFi hotspot support (if compatible hardware exists)
Software update via web interface
Whole system image ISO-file is below 200MB
Daphile is based on the open source Squeezebox Server, SqueezePlay and Linux.
Features
kurt10- Membro classe bronzo
Numero di messaggi : 1625
Re: Daphile - Audiophile Music Server & Player OS
Molto interessante,
soprattutto il multichannell.
Spero si presti ad un uso crosso ver. Digitale, ma pare proprio di si.
iperv- Membro di riguardo
- Data d'iscrizione : 17.06.09
Numero di messaggi : 660
Provincia : Ragusa
JLsounds_usbtoi2s-pcm5102
diy_sure_tpa3116d2
diy_BR_Audionirvana_Super8
JBL_Arena_180/
diy_Zigmahornet_Fe103
_____________
AudioGd_Fun
Denon_AH-D2000
Addirittura sshfs! Roba seria!
Molto interessante, aspetto resoconti di chi lo proverà.
Numero di messaggi : 3781
- Impianto principale:
Testina: Ortofon Super OM40
Pre Phono: NVA Phono 1
Impianto in camera:
Sorgente: iMac 27"
Giradischi: Rotel RP-900
Testina: Ortofon 2M Red
Pre Phono: Cambridge P540
io l'ho provata, o meglio ci ho provato ma non riesco ad usarla, ogni volta che faccio il boot mi dice waiting for network connection e non va avanti -.-
MDT360- Membro di riguardo
- Data d'iscrizione : 01.05.11
Numero di messaggi : 709
AMP STEREO : AERON A-160
DIFFUSORI : MONITOR AUDIO RX6
mmm... questo weekend...
Non ho capito molto riguardo il client, però. C'è per Android?
ghiglie- Membro classe bronzo
Numero di messaggi : 1883
Provincia : AN, TO, Roma
C'e per qualsiasi cosa che abbia un browser web.ghiglie ha scritto:mmm... questo weekend...
Basta collegarsi all'indirizzo http://daphile o http://daphile.local, ci sono anche altre modalità di collegamento è tutto scritto nelle istruzioni.
Appunto, mi riferivo al punto 11 delle istruzioni:MDT360 ha scritto:C'e per qualsiasi cosa che abbia un browser web.ghiglie ha scritto:mmm... questo weekend...
...sapete se per Android c'è un'app simile?11.Although the music playback control is possible via the web interface the preferred
solution is to use excellent applications like Squeezebox, iPeng or Squeezepad on
iPad.
pensao che qualcosa del genere potrebbe andare
https://play.google.com/store/apps/details?id=com.angrygoat.android.sqzctrl&hl=it
https://play.google.com/store/apps/details?id=de.bluegaspode.squeezeplayer&hl=it
Dunque siccome non riuscivo a farla funzionare sul mio pc ho inviato una mail allo sviluppatore chiedendo delucidazioni, si è subito reso disponibile e ha corretto il bug facendomi testare una iso corretta prima di pubblicarla.
Comunque devo dire che a mio parere per chi vuole allestire un pc per sola musica non c'e assolutamente niente di meglio e soprattutto nulla di più immediato e compatibile.
Pensate che una volta fatto il boot mi ha rilevato tutte le periferiche audio che avevo collegato al pc (uscita hdmi della scheda video, uscita analogica e coassiale della xonar essence e il dac teac).
L'interfaccia web è molto intuitiva e ben fatta, la scanssione degli album viene fatta automaticamente ed è molto veloce.
A livello di qualità audio l'ho trovata poco migliore di ubuntu "liscia", miglior controllo dei bassi e un pochino più rivelatoria.
Unico neo è che l'interfaccia web non è supportata sui terminali android per via di un limite tecnico dei dispositivi, ma l'applicazione squeeze commander funziona benissimo e rileva subito tutte le periferiche audio collegate al pc, anzi è possibile far suonare anche due periferiche contemporaneamente con due brani differenti, davvero eccezionale.
https://play.google.com/store/apps/details?id=de.cedata.android.squeezecommander&hl=it
Avendo il server audio in rifacimento, vedo se riesco a provare anche questa soluzione.
Quindi si riesce a "pilotare" solo con app squeezebox o dal pc?
Numero di messaggi : 2457
Provincia : Parma
Doh, non posso provarla... x64, peccato.
@handros : si per quanto riguarda i terminali android si può controllare soltanto tramite le app sqeeze"qualcosa" (consiglio squeeze commander) oppure collegandosi all'ip del pc tramite il browser (che solitamente è qualcosa tipo 192.168.1.x:9000 dove per x sta un numero compreso tra 1 e 255), ma in tal caso non vedresti l'interfaccia di daphile bensì quella del logitech media server.
Mentre per quanto riguarda i prodotti apple come ipod ipad iphone puoi tranquillamente collegarti tramite browser, forse funziona anche con i prodotti windows mobile ma non ne sono sicuro.
@ghiglie dovrebbe funzionare anche su pc a 32 bit infatti il nome della iso riporta daphile-13.08-b091659-x86_64.iso dove "x86" sta per 32bit.
Beh, browser x browser x 3.14 male che vada dovrebbe funzionare anche col browser del tablet android...o no?!?
Provincia : Parma
Installato al volo ..... è facilissimo si seleziona la periferica e funziona ....più facile di cosìMDT360 ha scritto:
Però a meno che per la fretta non sbagli qualcosa io avrei qualche dubbio sul fatto che non ci sia nulla di meglio.
Ho colegato un dac uSB con il tenor 7022 che vede la frequenza di 96 ma non gli 88.2 e nemmeno quelle superiori (176,4 e 192)
Però il sistema suonava anche i formati che in teoria non dovrebbe riprodurre: evidentemente se suona fa un downsampling ....ma non avendo settato nulla a che frequenza? Non è che fa i downsampling di tutti i file a bassa risoluzione?
Se così fosse non sarebbe il top.
Cmq riprovo con Hiface Two e un dac che segna le frequenze così vi saprò rispondere anche se rimane il mistero di cosa fa in automatico con il tenor .....
No purtroppo non va con android che sia tablet o smartphone, riporto la speigazioen che mi ha dato lo sviluippatore (in inglese).handros ha scritto:Beh, browser x browser x 3.14 male che vada dovrebbe funzionare anche col browser del tablet android...o no?!?
Praticamente i telefoni android non supportano un protocollo chiamato mDNS (multicast dns) e quindi non riescono a collegarsi all'interfaccia web di daphile.The problem with Android phone(s) is that they don't support technology called mDNS (Bonjour/Zeroconf).
Unfortunately there is nothing that Daphile can do about it.
One thing you could try is that you configure you home router's local DNS, DHCP Server or DNSMasq settings (if it is possible). It's very dependent on model.
I have router that uses dd-wrt software and that enable me to connect to Daphile with Android Nexus 7 by using http://daphile address on the browser. I think the most important settings were there:
DHCP Server: enabled
Use DNSMasq for DHCP: enable
Use DNSMasq for DNS: enable
DNSMasq: enable
Con che hardware si usa? Un raspy andrebbe bene?
Numero di messaggi : 1418
Provincia : Treviso
Impianto : A manovella
Non so se col limone funziona, ma potresti provareAlessio Zenga ha scritto:Con che hardware si usa? Un raspy andrebbe bene?
Comunque scherzi a parte basta un comune pc di qualsiasi marca o modello che abbia una scheda di rete e almeno una porta usb.
La distro è x64, quindi... ricordatevi che deve essere compatibile.MDT360 ha scritto:Non so se col limone funziona, ma potresti provareAlessio Zenga ha scritto:Con che hardware si usa? Un raspy andrebbe bene?
scusa, non avevo visto il messaggio. Sul thin client basato su VIA C7 cmq non parte - da appunto come messaggio che è stata trovata una CPU i686 e non una ad architettura x64... Non so se lo sviluppatore non ha integrato il microcodice per questi processori, ma sono quasi sicuro che l' x86_64 stia appunto per architettura X64... e non 32bit.MDT360 ha scritto:Mi autoquoto nel caso a qualcuno fosse sfuggito.MDT360 ha scritto:
Nemmeno sul mio muletto P4 ne vuole sapere, cerca chipset a 64bit.
Provincia : Parma
CHANGES on August 21st 2013
Support for native DSD playback with DSD-over-PCM
(verified only for DSD64 with Benchmark DAC2 HGC). Enable
it from Audio Settings for the DAC that supports it.
DSD file "Clear library and rescan everything" problem fixed
Replay Gain calculation added to the CD ripping process
Some other minor bug fixes and changes
Any feedback is warmly welcomed! Now especially any DSD-over-PCM experiences with different DACs and DSD128.
Installato al volo su una macchina virtuale, l'interfaccia mi sembra ottima. Per ora parlo da informatico e non da audiofilo ma mi sembra che tutto giri bene in termini di sistema operativo. Collegato in un secondo anche alla cartella del NAS (via CIFS) dove ho la musica ed è partito con lo scan dei brani.
Per la questione Android domani faccio una prova ma nella pegiore delle ipotesi dovrebbe bastare impostare il DHCP della propria rete per assegnare un IP fisso al server Daphile in base al MAC address...
trecentodueotto- Appassionato
- Data d'iscrizione : 18.08.13
Numero di messaggi : 259
Impianto : Beyerdynamic DT990
Ah, X86_64 non vuol dire che la versione va bene sia per sistemi 32bit che per sistemi 64bit, ma che va bene solo con i 64bit (http :// en.wikipedia.org/wiki/X86-64).
PS: Sono ancora troppo nuovo per postare link sul forum per cui ho messo degli spazi nel link sopra...
CHANGES on September 6th 2013
Storage configurations improved
Support for LVM and RAID volumes (not for DaphileBoot or DaphileData)
Samba file server configuration support for internal drives
CD ripping configuration options added for automatic start, disc eject, ripping target disk, CD drive offset and to disable ripping service
Support for Mytek Digital Stereo192-DSD DAC (thanks to KahLeong for testing)
DSD playback fix for HW with max rate above 192kHz
Sample rate limit configuration added
Kernel audio module parameter configurations added to web UI
Other minor changes and bug fixes
» LUMIN - The Audiophile Network Music Player
» Il Mio Music Server... Mpd
» NVA TFS - il music server di NVA
» Music Server
» Subsonic Music Streamer Server
» Music Server
Pagina 1 di 27
» Aiyima A07 - mi arriva oggi
» Thorens TD 320 mkll
Oggi alle 7:45 Da Quaiozi!
» Thorens rumore
Ieri alle 22:29 Da Quaiozi!
Ieri alle 13:08 Da Quaiozi!
» GAP nel TU SE
» Amplificatore per Kef q7
» Ritorno braccio
» Wiim Amp
