[VENDUTO] Monster Cable XPHP + cavo segnale - 40€
[VENDUTO] Monster Cable XPHP + cavo segnale - 40€ Empty [VENDUTO] Monster Cable XPHP + cavo segnale - 40€
Messaggio Da Drugo Mer 1 Dic 2010 - 11:53
Vendo i seguenti cavi:
Potenza: Monster Cable XPHP una coppia da 2mt.
Segnale: Alphaplus 1 mt.
[VENDUTO] Monster Cable XPHP + cavo segnale - 40€ Ok310
[VENDUTO] Monster Cable XPHP + cavo segnale - 40€ Ok410
[VENDUTO] Monster Cable XPHP + cavo segnale - 40€ Ok510
[VENDUTO] Monster Cable XPHP + cavo segnale - 40€ Ok110
[VENDUTO] Monster Cable XPHP + cavo segnale - 40€ Ok210
INFORMAZIONI dalla MONSTER CABLE:
Monster XPHP™ Clear Jacket - Advanced Speaker Cable
Monster's Time Correct® windings for accurate music reproduction.
Magnetic Flux Tube® construction for maximum bass response and more natural sound.
LPE dielectric for greater overall clarity.
Unique round shape and smooth, flexible jacket for easy installation.
Terminated with Monster's patented 24k gold angled pin connectors.
COMPACT TIME CORRECT HIGH PERFORMANCE SPEAKER CABLE
A new level of performance in an affordably priced cable
Monster XPHP speaker cable achieves a new level of performance in a cable of this size and price. Using Monster's patented cable technologies in a low cost design, XPHP delivers outstanding sonic performance for use with today's moderately-priced high-resolution loudspeakers and Audio/Video & Home Theatre systems.
Time Correct windings and Magnetic Flux Tube construction for enhanced sonic performance
Using patented Magnetic Flux Tube construction, Monster XPHP controls distortion-producing magnetic fields for a smooth, natural re-creation of the music. Unlike ordinary cables of this size and price, Monster XPHP uses Time Correct windings for more accurate transfer of the signal as it travels down the wire. This results in extended high and low frequency response, improved imaging, and deep, tight bass. A Special LPE(Linear Polyethylene) dielectric insulation reduces signal loss for greater overall clarity in the music.
Flexible, round jacket for easy installation
Monster XPHP features a unique round shape that's extremely flexible for easy handling and installation. And our UV stabilized DuraFlex jacketing is abrasion and chemical resistant to keep the cable looking as good as it sounds.
Drugo
Drugo
Data d'iscrizione : 06.11.08
Numero di messaggi : 480
Impianto : Radio Marelli del '39
[VENDUTO] Monster Cable XPHP + cavo segnale - 40€ Empty Re: [VENDUTO] Monster Cable XPHP + cavo segnale - 40€
Messaggio Da Drugo Mer 12 Gen 2011 - 12:47
Ritiro questa vendita, grazie
Drugo
Drugo
Messaggio Da madqwerty Mer 12 Gen 2011 - 14:50
allora mi permetto di spammare un po' Embarassed (poi si chiude Wink )
il cavo RCA proviene da Auchan ? ne ho uno che da lì proviene (zona HiEnd Hehe del reparto AudioVideo) ed è molto ma molto identico a quello..
abbastanza rigido, connettori sufficientemente robusti (anche se annegati nella plastica con solo una ghiera esterna metallica), e pesa un accidente Smile
Messaggio Da Drugo Mer 26 Gen 2011 - 15:11
madqwerty ha scritto:allora mi permetto di spammare un po' Embarassed (poi si chiude Wink )
come ti permetti? L'ho comperato dalla Upim!!! Al reparto detersivi :-) No seriamente presi questo cavo da un negozio audio-video di Roma e me lo consigliarono come rapporto qualità prezzo. Questo non è molto rigido, è fatto benissimo e suona anche bene... Insomma alla fine me li tengo :-)
Drugo
Drugo
Messaggio Da Drugo Sab 9 Apr 2011 - 22:18
Venduto
Drugo
Drugo
