Exposure 1010
Exposure 1010
è il piccolino di casa Exposure (425GBP):
Features
- High capacity 120VA custom made toroidal transformer
- Anodised aluminium faceplate
- High quality capacitors used in signal path
- Short signal path PCB
- Relay switching of input signals
- Dedicated fixed gain AV input
- Cascode circuitry used for improved power supply immunity
- High quality remote control
- Three year guarantee
Specifications
- Power Output (1KHz): 50W per channel RMS 8ohms
- Input sensitivity: 250mV
- Input Impedance: >14K Ohms
- Frequency Response: 20Hz - 20KHz ± 0.7dB
- Total Harmonic Distortion: <0.05% at rated power
- Signal to Noise Ration: >95dB, A Weighted, ref rated power
- Channel Separation: >60dB
- Mains Supply: 110/120V or 220/240V, 50/60Hz (factory set)
- Power Consumption: <120W
- Dimensions - H x W x D: 90mm x 420mm x 300mm
- Nett weight (unpacked): 5Kg
- Gross Weight (packed): 7Kg
Qualcuno l'ha sentito? Qualche commento?
Features
Specifications
aittam- Affezionato
- Data d'iscrizione : 25.01.11
Numero di messaggi : 210
In funzione - Amplificatore: Onkyo A933; Dac: SMSL SD-793 mini; Diffusori: Monitor Audio Silver RX2; Cavi potenza: Cavo sat; Cavi di segnale: TNT Shield (Mogami 2549); Stand: Atacama SL600 Black
Vintage (in vendita) - Amplificatore: Technics SU vx500; Lettore CD: Technics SL-P177A; Diffusori: Pioneer Prologue S-55
Re: Exposure 1010
Nessuno ha provato sentito il piccolino di casa Exposure? Sarebbe interessante un confronto con il nad 326 o con il Rega Brio R...
Qualcosa viene detto qui:
It just so happened I demo'd the Yamaha AS500 and Marantz PM6004, as well as a more expensive Exposure 1010 today (£425)......using Dali Zensor 5 speakers and Marantz CD6004 cd player.
Before going my friend and I sat down and listened to my system.....muddled, lacking definition and clarity and top end using the Pioneer amp.
First came the Yamaha.......great sound, but still a muddled bass area. Vocals were clear and detailed.(Hurt my friends ears a little though)
Marantz......Better bass definition and depth, but the vocals didn't shine as much as the yamaha, in my opinion.
Exposure 1010....detail and clarity galore!!! deep bass, but missing the middle a bit and it sounded too laid back for my ears.
http://www.avforums.com/forums/hi-fi-systems-separates/1580092-anyone-demod-marantz-pm6004-recently.html
Un paio di test KruKKI
http://www.testberichte.de/p/exposure-tests/1010-a-testbericht.html
R!ck- Membro classe argento
Numero di messaggi : 4987
Provincia : ---
Impianto : -------------
Re: Exposure 1010
Va che bellino che è. C'e' anche il lettore Cd 1010 (molto carino secondo me) da associarsi per una spesa simile.
Sarebbe interessante saperne un po di più.
Numero di messaggi : 1015
Provincia : easy
Impianto : Bushmaster MKII
tpa3116
cavi
Neat Motive 2
Re: Exposure 1010
L'ho sentito poco tempo fa in un negozio qui a Milano, con delle neat da pavimento modello entry, e mi era piaciuto poco.
La tendenza è sempre quellla recentemente: ampli chiari chiari, bel dettaglio, poca anima. Il confronto con il 2010s2, ascoltato subito dopo nello stesso negozio era impietoso. Molta più sostanza, autorità. Ma neanche quello mi aveva entusiasmato. Un pò come i Creek nuovi (Destiny e Evolution).
Usato il 2010s sui 500/600 euro si riesce a trovare, non so quanto valga la pena un 1010 nuovo. Un pò poverello anche come costruzione.
Impressioni da negozio, sia chiaro, ma non mi ha fatto venir voglia nè di risentorlo, nè di farci un pensierino.
Anche perchè dopo aver sentito la serie Farlow, secondo i miei gusti non c'è confronto.
Vella- Membro classe argento
Numero di messaggi : 3992
Re: Exposure 1010
Vella ha scritto:L'ho sentito poco tempo fa in un negozio qui a Milano, con delle neat da pavimento modello entry, e mi era piaciuto poco.
Vella, di quel negozio si tratta? A me i suoni chiri piacciono e ho proprio un paio di Neat.
Provincia : easy
tpa3116
cavi
Neat Motive 2
Re: Exposure 1010
I suoni "chiri"?????!!!!!
Guarda che siamo su un altro livello (più basso) rispetto al Nuforce, se parliamo di suoni "chiri"!!!!???
Il negozio sta in un cortile di un complesso di palazzi, devi scendere verso i garage e sta in una dependance..
Adesso mi concentro e tiro fuori il nome..
Re: Exposure 1010
Ascoltato velocemente, le impressioni sono molto simili a quelle di Vella.
Si riconosce il marchio Exposure ma, oltre a essere uno step indietro sotto tutti i parametri rispetto ai modelli superiori, il suono risulta un po' esile.
Esteticamente non mi piace, al contrario dei 'fratelloni' non è Made in England, ma ha il tastino per l'esclusione pre.
Comunque, con circa 200 euro in più si prende il 2010S2, che è di ben altro livello.
In caso di acquisto andrei dritto sulla serie S2 (tra l'altro l'unica disponibile sul mercato del nuovo), che è più aperta, precisa e ha un miglior controllo delle basse frequenze.
GoP- Appassionato
- Data d'iscrizione : 06.06.10
Numero di messaggi : 260
Re: Exposure 1010
Vella ha scritto:I suoni "chiri"?????!!!!!
Ah! Grazie
Non sono mai stato in nessun negozio a Milano non ti saprei aiutare.....
Solo uno a Merate che aveva parecchia roba.
Provincia : easy
tpa3116
cavi
Neat Motive 2
Re: Exposure 1010
Ce l'ho!!!!!
Tuttaltrosuono
Via D'alviano 55
Milano
Zona via Lorenteggio
Tuttaltrosuono
Via D'alviano 55
Milano
Re: Exposure 1010
Ma il prezzo del nuovo qual'è?
Provincia : ---
Re: Exposure 1010
Il 1010? Circa 800 euro.R!ck ha scritto:Ma il prezzo del nuovo qual'è?
Da quel che so, tra i rivenditori HiFi United, Tuttaltrosuono e Stereodrom hanno i prezzi più interessanti.
GoP- Appassionato
Re: Exposure 1010
Ahhh ecco perchè siete così severi. Alla faccia del prezzo da entry level...Mi sa come al solito in Italia hanno messo l'asticella del prezzo un po' alta
Io ne ho trovato uno usato ma perfettamente "intonso" a 400 euro e forse riesco anche a togliere qualcosa...certo rispetto ai fratelli maggiori non sarà comprensibilmente allo stesso livello ma mi piacciono gli ampli dettagliati e dal suono 3d e non è facile trovare roba decente con il telecomando a prezzi entry level praticamente nuovi.
Altra review Malesiana
http://webcache.googleusercontent.com/search?q=cache:aF7zjiYmC64J:sites.thestar.com.my/audio/story.asp%3Ffile%3D/2012/2/20/afreviews/10735113%26sec%3Dafreviews+exposure1010+holographic&cd=1&hl=it&ct=clnk&gl=it
Exposure’s enticing entry level
By KHAIRAN NASIR
A Brit veteran proves excellence can exist at the modest end of the price spectrum.
EXPOSURE 1010 amplifier / CD Player
Price: RM2,600 / RM2,500
Distributor: SOUND CONCEPTS (012-429 6101 ) / Also available from AUDIO IMAGE(016-600 1218)
THE 1010 series from Exposure Electronics marks a new baseline for the British stalwart, whose products include the 3010 and 2010 range of components, now in S2 incarnations. The 1010 represents the starting point to Exposure ownership, making it relatively more affordable across a broader customer stratum.
At what price, you ask? While Exposure is not exactly the first brand to come to mind when one considers serious money components and systems (bar the MCX series), it has never really been at the entry-level end either. Owning an Exposure component myself, I pondered upon this as I unpacked the single box containing both units – a CD player and integrated amplifier.
10 on 10: The Exposure 1010 CD player and integrated amplifier are high on the bang-for-buck factor.
Under-exposed?
The overall family visual cues are unmistakable, finished in the now-familiar Exposure silver with blue LED display for both the CD player and amplifier.
Stacking them on the equipment rack makes a strong case for a one-brand system; they may look restrained, but there has seldom been more of a feel that both boxes are truly made for each other.
It would seem that Exposure is sticking to a tried-and-tested formula, at least where the 1010 amplifier is concerned.
A beefy power supply underpinned by a high-capacity toroidal transformer is the core basis for the 50-Watt unit.
While this may sound a little short-changed in this day and age, I have this sneaking suspicion it will be more than sufficient to drive day-to-day speaker loads with reasonable ease. The 1010 amp is physically ever-so-slightly slimmer than its 2010 and 3010 brethren, although heft is a giveaway that some corners were trimmed to reach this price point.
Its fighting weight of 5kg gives more than half away to the 3010S2 I own.
That said, features are respectable if not outstanding – five line-level inputs (including a dedicated fixed-gain AV input), a set of record outputs and a pair of speaker outputs.
The 1010 CD player, on the other hand, is a bit more of an unknown quantity to me.
Externally, it appears to share the same chassis casework as the costlier 2010 and 3010 units but not much is immediately evident from the sparse owners’ manual, apart from the usual output level/frequency response specs.
One will probably assume the chipset used in the 1010 CD player is a scaled-down derivative of the PCM chip used in its elder siblings. Despite that, CD player provides for an optical output to connect to external DACs, so some measure of future-proofing is provided for.
A rather rudimentary remote control unit comes with both the components, and can be used to control both units together.
I also managed to use my 3010S2 remote without issues, at least the programming protocol is fairly spot on with the rest of the product family. Score one for Exposure in this regard.
What’s interesting to note is that both units are made in Malaysia.
While I’m not entirely familiar with Exposure’s manufacturing practices, I can’t detect much difference (if at all) in terms of fit and finish of the 1010 series components compared with the 3010S2.
Perfect pair
The 1010 may be entry-level in Exposure’s stable but I was surprised at what this combo brought to the fore.
The sonic signature was unmistakably Exposure, the house sound instantly recognisable – fast yet weighty, with neutral-ish mids and a sparkling top-end.
The big party trick the 1010 combo manages to pull off is in how organic the overall sound is. I kept going back to my reviewing notes and lingering on “holographic” as an adjective. This combo pulls a convincing “speaker disappearing” trick, not something you would normally find in hi-fi equipment at this price point.
Of particular note, my Audio Physic Yara 2 Evolution floorstanders hooked up to the 1010 combo felt as if they had grown an octave or two lower in the frequency spectrum.
The sound was undoubtedly weighty and anchored proceedings with a very distinct rhythmic foundation. Notes started and stopped on a dime and coupled to the inherent Exposure family sound, the result was a bottom end with impressively little overhang.
Substituting the 1010 CD player with my Audiolab 8200 CDQ yielded dividends but what was surprising was that differences were not as night-and-day as anticipated.
Yes, there was a heightened sense of sophistication and realism; yes, there was better resolution of leading edges and better articulation and control at the frequency extremes. And yes, there was an appreciable broadening of the soundstage.
However, these were apparent only if one was working hard at consciously looking out for them.
I also added my Rega P3/RB301/Benz Micro MC Gold/Trichord Dino rig into the mix for good measure.
The 1010 amp was impassive to all this and took the analog source in without batting an eyelid. The P3’s musical integrity was largely intact and I found myself hard-pressed to detect anything detracting from its overall honesty.
Of course, a comparison between the 1010 series and its more expensive siblings was inevitable. I can comfortably attest that the differences are there – my earlier observations on control over leading edges and frequency extremes were more effortlessly articulated by the higher grade siblings. But on their own, the 1010 series component’s achievements were indeed pretty high.
One for the underdog
You will gather by now that I found the Exposure 1010 combo to be pretty impressive.
If five grand is your ballpark for a CD player and amplifier, these two make a very persuasive case for themselves, taking you closer to the next step than other pairings. They will likely be more sympathetic to quality upgrades than most others – money well-spent in my books for what you get in return.
Exposure has managed to pull off a good one with this pairing, extracting such a high degree of performance at the price.
Of course, in the final scheme of things, everything is built to a price, which is precisely why the high-end market exists. Think of it like this - you are more likely to do wrong than otherwise by not giving the 1010 components due consideration.
Ultima modifica di R!ck il Ven 2 Mar 2012 - 16:58 - modificato 1 volta.
Provincia : ---
Re: Exposure 1010
Vella ha scritto:Ce l'ho!!!!!
Tuttaltrosuono
Via D'alviano 55
Milano
Vella,
Scusa ma tu hai sentito l'accoppiata cd + ampli?
Per mia esperienza le elettroniche inglesi tendono sempre a compensarsi da qualche parte. Tipo naim che ha i lettori cd con un casino di bassi e l'ampli più secco.
Provincia : easy
tpa3116
cavi
Neat Motive 2
Re: Exposure 1010
In realtà, secondo me non è male, il problema è che, pur essendo costruito in Malesia, costa troppo poco meno rispetto al 2010S2.R!ck ha scritto:Ahhh ecco perchè siete così severi. Alla faccia del prezzo da entry level...Mi sa come al solito in Italia hanno messo l'asticella del prezzo un po' alta
Comunque non sei lontano dalla realtà; il grande limite è rappresentato dal distributore italiano, che fa impallidire i propri diretti concorrenti, con le sue costanti botte di aumento di listino da centinaia di euro...
GoP- Appassionato
Re: Exposure 1010
@The Pescator
Era ampli 1010 + cd 2010
Re: Exposure 1010
Me ne mandano uno in "prova".
Vedo che utilizza dei connettori di potenza diversi dal solito (sono BFA?)...è possibile usare del semplice cavo spellato pigiandolo dentro ai buchi dei connettori di potenza?
Provincia : ---
Re: Exposure 1010
No, devi utilizzare le banane.R!ck ha scritto:Me ne mandano uno in "prova".
GoP- Appassionato
Re: Exposure 1010
Quindi non sono connettori BFA ma semplici banane?
Ultima modifica di R!ck il Sab 3 Mar 2012 - 19:17 - modificato 2 volte.
Provincia : ---
Re: Exposure 1010
Gli Exposure accettano soltanto banane.
Ultima modifica di GoP il Sab 3 Mar 2012 - 19:19 - modificato 1 volta.
GoP- Appassionato
Re: Exposure 1010
Ottimo! Grazie
Provincia : ---
» [TO] Exposure 1010
» Diffusori per Exposure 1010
» Exposure XV
» Exposure X
» [CHIUSO] Kenwood KAF-1010 [140 euro + S.S.]
» Exposure XV
» Exposure X
Ieri alle 19:22 Da mrcpal91
Ieri alle 17:37 Da ste-65
Ieri alle 8:51 Da Fabiolydia
