Class D Audio
+37
lucarsenio
danilopace
verderame
ilfungo
traspar
gianluca sassu
pny73
Felfra
Germano
wincenzo
FastFonz
Alessandro Asborno
shantim
pippo1999
pincellone
thema2000ie
Marf
Wushuliu
Robfug
cestma
H. Finn
maurizio3929
R!ck
Artinside
fannaru
K8
gianluca
kingbowser
pentrio
luka964
roby2k
41 partecipanti
Pagina 12 di 14 Precedente  1 ... 7 ... 11, 12, 13, 14  Successivo
Class D Audio - Pagina 12 Empty Re: Class D Audio
Messaggio Da Felfra Sab 20 Feb 2010 - 20:19
Great, thanks!
Meanwhile I found this http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=320484651290&ssPageName=STRK:MEWAX:IT
Do you think the scheme is exactly the same?
Beside the 4 mkp caps that can be replaced, the rest of the components look good, the fets look right (it seems it can be red LSK170...), and beside the bad pot, everything looks ok, right?
p.s. can't exctly understand why there are 4 input spots... Rolling Eyes
Felfra
Felfra
Data d'iscrizione : 12.10.08
Numero di messaggi : 405
Messaggio Da Wushuliu Sab 20 Feb 2010 - 20:44
Only 2 source inputs: 1 L / GR / G, 2 L / GR / G
Unfortunately I do not trust chinese kit components. There are so many fake resistors and capacitors. Why risk the quality if you can also buy them for cheap yourself? Also with a design this simple, the better the parts the better the sound. You'll want to use at least Dale resistors and better quality caps (I do not recognize the red caps - Audiophiler?).
Also I would buy the JFET from a real supplier.
I would avoid this kit.
Only buy the pcb. The PCB is good quality.
Wushuliu
Data d'iscrizione : 18.11.09
Numero di messaggi : 27
Occupazione/Hobby : DIY Audio, Film
Impianto : Class D Audio Amplifier 2X250W
RS180/Seas 27TDFC Modula MTM
B1 Pass Buffer
Hagerman Bugle
Yamaha 801BL
WDTV
Messaggio Da Felfra Sab 20 Feb 2010 - 21:46
I agree about component quality, maybe better not to risk.
I still don't understand about the input spots: instead of two spots (2 channels, 2 spots!) this board has 4 input spots, why do you say they are 2?
Felfra
Felfra
Messaggio Da Wushuliu Sab 20 Feb 2010 - 21:52
[quote = "Felfra"] I agree about component quality, maybe better not to risk.
I still do not understand about the input spots: instead of two spots (2 channels, 2 spots!) This board has 4 input spots, why do you say they are 2? [/ Quote]
I mean 4 inputs for 2 sources.
Source 1
R
L
Source 2
R
L
Wushuliu
B1 Pass Buffer
Hagerman Bugle
Yamaha 801BL
WDTV
Messaggio Da Felfra Sab 20 Feb 2010 - 22:01
Wushuliu ha scritto:[quote = "Felfra"] I agree about component quality, maybe better not to risk.
Source 1
R
L
Source 2
R
L
I understand, but where is the sense in that? With a rotary switch you can connect as many sources you want... never seen something like that.
Felfra
Felfra
Messaggio Da Wushuliu Sab 20 Feb 2010 - 22:05
[quote = "Felfra"] [quote = "Wushuliu"] [quote = "Felfra"] I agree about component quality, maybe better not to risk.
Source 1
R
L
Source 2
R
L [/ quote]
I understand, but where is the sense in that? With a rotary switch you can connect as many sources you want ... never seen something like that. [/ quote]
Don't know. I think Nelson Pass just wanted to keep things simple.
Wushuliu
B1 Pass Buffer
Hagerman Bugle
Yamaha 801BL
WDTV
Messaggio Da Wushuliu Dom 21 Feb 2010 - 10:50
I updated the BOM. Had some errors.
Wushuliu
B1 Pass Buffer
Hagerman Bugle
Yamaha 801BL
WDTV
Class D Audio - Pagina 12 Empty classDaudio quali moduli?
Messaggio Da Germano Mar 9 Mar 2010 - 20:58
ragazzi un consiglio...secondo voi quali sono i migliori moduli della classDaudio? ioho delle casse da 95 db\w quindi la potenza massima non sarebbe un grosso problema...
ho scritto a Tom e lui mi consiglia i moduli da 60W su 8 ohm...ma non so perchè non mi sono troppo convinto...secondo voi sono troppo malfidato?
ringrazio chi vorrà dirmi cosa ne pensa..
Ok
Germano
Data d'iscrizione : 17.11.09
Numero di messaggi : 233
Provincia : Bbbuono...
Occupazione/Hobby : Luce/figlio, fotografia, sport, moto, viaggi, amici
Impianto : Imac, dac Weiss Minerva, finale Usher R1.5, casse Usher Mini Dancer One Be...in evoluzione...
II impianto: scheda Roland uc55 + monitor attivi Prodipe pro 8 Ribbon!
Messaggio Da Felfra Mer 10 Mar 2010 - 1:56
Avendo fatto il confronto diretto TA3020 vs. ClassD modello da 120W posso dire che non sono male. Quello da 60W non l'ho ascoltato, e credo non l'abbia fatto nessuno, qua.
Felfra
Felfra
Messaggio Da pentrio Mer 10 Mar 2010 - 9:24
Felfra ha scritto:Avendo fatto il confronto diretto TA3020 vs. ClassD modello da 120W posso dire che non sono male. Quello da 60W non l'ho ascoltato, e credo non l'abbia fatto nessuno, qua.
Come no..... io ce l'ho e sono stato il primo a comprarlo in questo forum:lol: Laughing
Il problema è che non ho quello da 120 w per un confronto diretto e nmmeno il 3020.
Però io a naso scometto che quello da 60 potrebbe essere un pò più "raffinato" sia di quello da 120 w e sopratutto del 3020.
Luciano.
pentrio
pentrio
Data d'iscrizione : 04.05.09
Numero di messaggi : 924
Provincia : variabile
Sorgente: computer + V-dac
Diffusori: Usher x 719
Messaggio Da bonghittu Mer 10 Mar 2010 - 9:25
Hai provato anche i nuovi basati sul TAS5630 ?
Data d'iscrizione : 09.04.09
Numero di messaggi : 4292
Provincia : CA
Messaggio Da pentrio Mer 10 Mar 2010 - 9:41
No!!!
quali sono quelli che possono essere alimentati da un alimentatore esterno?
Se sono quelli ciavevo fatto una mezza idea........ ma per il momento come amplficatori sto bene così Very Happy Very Happy
pentrio
pentrio
Messaggio Da Germano Mer 10 Mar 2010 - 10:53
Luciano.
grazie della risposta...
tu hai preso il kit completo con il trasformatore da 300va o l'hai assemblato con pezzi tuoi?
tra gli ampli che hai o che hai provato diresti che è tra i migliori???
grazie ancora
p.s. tra l'altro questo è l'unico kit che non vendono su ebay!!!! (dove gli altri costano meno che sul sito del produttore!!!)...
Germano
Messaggio Da Felfra Mer 10 Mar 2010 - 14:56
Luciano.
Ti sbagli: il 3020 è piuttosto nettamente più raffinato del ClassD da 120W come abbiamo potuto verificare sia io che Alessandro Asborno, ed entrambi abbiamo qua riportato le nostre impressioni, praticamente completamente combacianti su questo parametro.
Ma scusa, tu li hai confrontati? Io e Alessandro sì...
Felfra
Felfra
Messaggio Da Felfra Mer 10 Mar 2010 - 14:58
No, mai ascoltato.
Felfra
Felfra
Messaggio Da bonghittu Mer 10 Mar 2010 - 16:22
Si, singola da 20/50V più uno stadio secondario a 12v. Ho visto che si sta
creando un po' di movimento attorno a questi nuovo chip TI e a breve potrebbero
esserci novità interessanti.
Datasheet Rev.B. Feb2010
Chiaramente è tutto da verificare con le proprie orecchie Smile
Provincia : CA
Messaggio Da Germano Mer 10 Mar 2010 - 16:27
ho scambiato un paio di mail con Tom della classdaudio e cmq secondo lui i chip TI sono sonicamente inferiori ai precedenti... Mmm
non so se l'ha detto perchè voleva vendermi gli altri o perchè vero...
Germano
Messaggio Da bonghittu Mer 10 Mar 2010 - 17:33
Germano ha scritto: i chip TI sono sonicamente inferiori ai precedenti... Mmm
Bisogna vedere la destinazione d'uso finale. Viste le potenze in gioco penso al mondo
PA e al car-audio più che a prodotti multimediali di largo consumo.
Provincia : CA
Messaggio Da pentrio Mer 10 Mar 2010 - 21:22
Luciano.
Dalle rissposte di Alessandro mi è sembrato di capire che non fosse totalmente d'accordo con te, e comunque voi avete confrontato il 3020 con il classd da 120 w io ho il 60 w e può darsi benissimo che il 60 w fosse superiore qualitativamente al 120 w ..... un pò come Adcom 555 e il 535 che io ho avuto entrambi.
Poi se suonano così bene non ho capito perchè ne hai già venduti 2 nel mrcatino. Io il mio ancora ce l'ho.
Luciano.
pentrio
pentrio
Messaggio Da Alessandro Asborno Mer 10 Mar 2010 - 22:59
Luciano.
Ciao Luciano, con Felfra sono d'accordo sulla superiore raffinatezza del 3020, il Classdaudio ha una grana piu grossa, ma io lo preferisco perche ha piu impatto, con due monitor come le mie Celestion SL6 si esalta parecchio, trovo che abbia nella potenza e nella dinamica la sua arma migliore, quindi fossi in te upgraderei verso la versione piu potente.
Quanto alle vendite di Felfra, ti assicuro che e' un sperimentatore, ha gia realizzato parecchie versioni del 3020 ed e' fisiologico che venda il surplus.
Alessandro Asborno
Data d'iscrizione : 09.03.08
Numero di messaggi : 850
Provincia : Minopoli
Impianto : Compattone
Messaggio Da Felfra Mer 10 Mar 2010 - 23:26
Luciano.
Luciano.
1) Non so come tu faccia a dare giudizi su cose che non hai sentito, ma mi sto abituando all'idea che sia usanza diffusa. Sulla raffinatezza del 3020 ti ha già risposto anche Alessandro, che come vedi dice quel che dico io, su quel parametro. Poi, siccome la raffinatezza non è l'unico parametro in gioco, lui ha preferito il ClassD per il suo setup, ma sulla raffinatezza siamo completamente d'accordo (e anche su quel che dice sull'impatto, tra l'altro, ma non di questo si parlava).
2) Se un amplificatore suona bene uno non può averne due o tre e venderne altri? Che ragionamento è, scusa? Io per esempio ho già avuto 2 V3b e un V3c, e in arrivo ho un altro V3b, e li ho provati con diverse alimentazioni e configurazioni. Secondo te li dovrei tenere tutti? E perchè, scusa?
Felfra
Felfra
Messaggio Da pentrio Gio 11 Mar 2010 - 8:19
Luciano.
Luciano.
Ma guarda che io ho solo ipotizzato che il classd andasse meglio del 3020 ben lungi da me dall'affermare cose che non conosco direttamente........ d'altronte voi l'avete comparato con il 120 w e non con il 60 w che non avete!!!
Con quali pre li avete interfacciato? Perhè in effetti ilmio classd interfaciato con un pre audiolab 8000q non mi è piaciuto tanto nel senso che era meno preciso e dettagliato..... un pò troppo ruffiano se vogliamo!!! Con un pre Xndak 3200 mkII le cose sono cambiate radicalmente.
Per quanto riguarda il secondo punto ..... beh se avessi le capacità ed il tempo...... probabilmente farei la stessa cosa Laughing Laughing Oki Oki
Luciano.
pentrio
pentrio
Messaggio Da Alessandro Asborno Gio 11 Mar 2010 - 18:04
Luciano.
Io l'ho interfacciato con il pre Yaqin MS12B con valvole upgradate e con un DAC Zero, ormai qualsiasi amplificatore Classe T, compreso il Virtue Two non potrei piu ascoltarli senza pilotarli con questo pre.
Alessandro
Alessandro Asborno
Messaggio Da Wushuliu Dom 14 Mar 2010 - 0:25
Hi everyone,
2 new things to consider:
1) Input coupling caps
The classdaudio (the IR versions, like the 250w) have input 22UF SMD caps. These caps are small orange caps on the bottom of the board * near the front, by the inputs *. I pulled them off, then shorted them with a small piece of metal. Then, I put 2 22UF polypropylene caps attached to the input wires.
The sound is * much * improved. This is very similar to the input cap modification for the boards like the Tripath TA2024 and TK2050, ETC. So if you have done this, you know how big an improvement it can make.
Unfortunately, I do not have pictures. If someone has a picture of the bottom of the board I can show the SMD caps.
This a very easy mod. The SMD caps like right off w / soldering iron.
2) Power Supplies
There is a very long thread at about audiocircle.com classdaudio amps. They are becoming very popular. Someone mentioned how important it is to improve power supply! Which I forgot! Classdaudio The power supply is ok, but we can do much better! So I replaced the power supply caps w / TS-HA 6800uf caps. So, ~ 20,000 uF per rail.
The bass is * much * improved and midrange is clearer. I have only replaced them today so I am sure it will sound even better in the next few weeks.
This is very easy also. The caps are easy to replace.
Class D Audio - Pagina 12 Img_2115
Ultima modifica di Wushuliu il Dom 14 Mar 2010 - 0:40 - modificato 2 volte.
Wushuliu
B1 Pass Buffer
Hagerman Bugle
Yamaha 801BL
WDTV
Messaggio Da Wushuliu Dom 14 Mar 2010 - 0:37
Class D Audio - Pagina 12 Img_2114
Wushuliu
B1 Pass Buffer
Hagerman Bugle
Yamaha 801BL
WDTV
