Emotiva XDA 1
Menestrello
spawnman
Kobayashi
Emotiva XDA 1
Segnalo questo DAC che mi pare molto interessante e visto il rapporto qualità prezzo in linea con la filosofia del T Forum.
peccato per la limitazione dell'ingresso USB a 48 khz.
Qualcuno lo conosce ?
The XDA-1 Differential Reference™ balanced 24Bit/192kHz DAC/Digital Preamp represents a stunning achievement in sonic performance. Designed around the acclaimed Analog Devices AD1955 DAC operating in a fully differential mode, its differential output is then coupled to a digitally controlled volume control stage. The output of this stage then drives our fully discrete, cross coupled, Differential Reference™ balanced line amp stage. The result is breathtaking.
In addition to being a state of the art 24Bit/192kHz DAC, the XDA-1 can operate as a digital preamplifier and source selector in a digitally based reference level audio system. Inputs for up to six digital sources including AES/EBU, USB, Coax, and Toslink are available. The XDA-1 incorporates a VFD display for volume, input select, and system status messages. In addition, it is supplied with a milled aluminum remote control for convenient operation.
The XDA-1: transcendent.
Signal-to-Noise Ratio: > 105dB (A-Weighted)
Frequency Response: 5Hz - 48kHz
THD+N: 0.001%
Ground Floor Noise Level: < 15uV
Nominal Output Voltage: 1V RMS
Peak Output Voltage: > 12VRMS (balanced)
Sample Rate: All standard resolutions are supported up to 192kHz
Bit Depth: Standard bit depths up to 24Bit are supported at clock frequencies up to 192kHz
USB hardware support up to 48kHz / 24Bit
Inputs: 2 Optical TOSLINK, 2 COAX Digital, 1 AES/EBU, 1 USB
Outputs: 2 RCA (Unbalanced), 2 XLR (Balanced)
Internal Volume Control: Digitally controlled in increments of 0.5 steps
Remote Control: Milled Aluminum Full Function Remote Control
I/V conversion: Burr Brown OPA-2134
D/A conversion: high performance, multibit Sigma-Delta AD1955 Data Directed Scrambling
with high jitter immunity, and an 8x Oversampling Digital Filter
Fully Discrete Differential Reference™ Output Stage with fully independent balanced and unbalanced drive stages
Dimensions:
17" wide x 2.25" high (1.75" without feet) x 14" deep
Copio in calce un link
http://emotiva.com/xda1.shtm
THD+N: 0.001%
Dimensions:
Kobayashi- Interessato
- Data d'iscrizione : 30.01.11
Numero di messaggi : 59
Provincia : Padova
Impianto : PRE-AMPLIFICATORE: Leak Point one
FINALE: Leak Strereo 20
GIRADISCHI: PRO-JECT RPM GENIE 1.3
PRE-PHONO: PRO-JECT PHONO BOX MM
SORGENTE: Sony cdp X 33 ES
CONVERTITORE: Musical Fidelity V DAC 2
DIFFUSORI: Klipsch RF52
CAVI DI SEGNALE: G&BL HPCD310 491 LUXURY
CAVI DI SEGNALE: RCA Mogami 2534 Stentor - Pierpabass
CAVI DI SEGNALE: Spidif Mogami 2964 - Pierpabass
CAVI DI POTENZA: Audioquest x2
CAVI DI POTENZA: Van Den Hull CS 122 Hybrid
AMPLIFICATORE CUFFIA: Darkvoice 366SE
CUFFIE: Grado SR 325 iS
Re: Emotiva XDA 1
Non è la prima volta che ne sento parlare ma purtroppo non ne so molto...
Se ne parlava un (bel) pò di tempo fa sui forum di head-fi ma, se la memoria non mi inganna, le impressioni erano buone ma di certo non è stato mai osannato.
Numero di messaggi : 3782
- Impianto principale:
Testina: Ortofon Super OM40
Pre Phono: NVA Phono 1
Impianto in camera:
Sorgente: iMac 27"
Giradischi: Rotel RP-900
Testina: Ortofon 2M Red
Pre Phono: Cambridge P540
dac che vale quel che costa..
Ero interessato anche io al dac della emotiva...e pensavo di fare un'upgrade del mio Matrix mini-i....ma alla fine leggendo prove e forum...ho capito che il mio era migliore....certo che esteticamente e' davvero bello però.
spawnman- Novizio
- Data d'iscrizione : 02.03.11
Numero di messaggi : 12
Impianto : Pre : AM AUDIO A1 / ONkYO TX1007
Finale front : AM AUDIO A70 Reference
Finali cent/post : Classè CAV150
Diffusori front : B&W 802N - B&W HTM1
Diffusori post : B&W 805N
Sorgenti : PC-PS3-ASUS OPLAY HD
Re: Emotiva XDA 1
spawnman ha scritto:Ciao
Chi non ha testa, usi gambe
Vale anche per il marketing
Numero di messaggi : 3131
Provincia : molesto
Impianto : bacato
Re: Emotiva XDA 1
...e per chi non ha niente come me (o meglio, ho un modestissimo Mocha JYM2)? Come lo vedete?
Più che altro mi attirano i molti ingressi, volendo uscire in stereo digitale dal Denon DVD2910, dal WDTV live e dalla xbox + magari attaccarci un pc via usb (un hiface magari più avanti) per la musica liquida.
Stigmata- Affezionato
- Data d'iscrizione : 25.01.10
Numero di messaggi : 115
Impianto : iMac | Lampucera DAC | Fenice20 | Jensen Absolute
Re: Emotiva XDA 1
Secondo me per quel prezzo c'è di meglio... considerando spese e spedizione e dazi vari... facile che arrivi a € 400... a quel prezzo io prenderei in considerazione Dac Asus Essence One o il nuovo Dac Teac.
Non ho mai sentito nessuno dei 3 , anche se a te non interessa, di certo l'Asus e il Teac hanno un USB migliore.
pablos74- Affezionato
Numero di messaggi : 157
Impianto : Pc autocostruito: Case Media NOX live 2, I7-860
Cavo Usb: Wireworld Starlight Digital 0.5m
Musiland Monitor 02 US
Audiolab MDAC
Buffer Valvolare Yaquin SD-CD3 con valvole ShuGuang Treasure CV-181-Z
Cavo Digitale: Oyaide DR-510 0.7m
Cavi audio: Thender Silver Plating
Aeron A 160
Cavi di potenza: QED Silver Anniversary XT Speaker Cable
Diffusori: Dynaudio 2/7
Re: Emotiva XDA 1
In effetti ho un pc in giro a far niente (eeebox con hd rotto): potrei usarlo per la musica liquida (in alternativa iPod + Pure i20) via usb oggi e via hiface domani.
Per il resto ho un wdtv live e un lettore denon dvd2910 che vorrei collegare in digitale: ecco che i tanti input mi tornano molto utili.
Comunque secondo me l'emotiva non arriva a 400e consegnato, anzi ci sta lontano... in più ha il telecomando che per me sarebbe comodo.
Edit: l'xda1 viene 250€ spedito, ho chiesto al produttore.
Re: Emotiva XDA 1
Spedito da dove? Dall italia?
Audiolab MDAC
Aeron A 160
Re: Emotiva XDA 1
no da usa
XDA-1 $249.00
Freight $85.61 FedEx Economy
Total $ 334.61 che fa poco più di 250€
XDA-1 $249.00
Re: Emotiva XDA 1
Devi poi aggiungere le spese per sdoganarlo e pagarci il dazio. Credo che con altri 50 euro te la dovresti cavare. Ho visto che su ebay un tizio in Italia lo vende a 340 euro... mah.. comunque sulla rete non ho trovato nulla su questo dac.. chissa come suona..
Audiolab MDAC
Aeron A 160
Re: Emotiva XDA 1
Mi sono informato un po' e devo dire che non ne parlano benissimo.
Intendiamoci: non ne parlano *male* e nemmeno in modo *medio*, ma non è che brilli di luce propria, diciamo. Aveva qualche problema con il volume (troppo sensibile) ma è stato risolto. E' che per me sarebbe comodo, ha anche il telecomando!
Ce ne sono altri col telecomando?
Re: Emotiva XDA 1
Si c'è l' M Dac che appartiene certamente ad un'altra galassia...ma anche come prezzo...
Provincia : Padova
Re: Emotiva XDA 1
anche il mini-i ha il telecomando, non lo sapevo... certo ha la metà degli ingressi dell'emotiva
Re: Emotiva XDA 1
Stigmata guarda che ti confondi
l'M DAC è questo
http://www.audiolab.co.uk/M-DAC%20Series.aspx?lang=En
Ha tutto quello che ha l'Emotiva...e anche qualcosa in più...
Costa però quasi il triplo..
l'M DAC è questo
Provincia : Padova
Re: Emotiva XDA 1
l'm-dac l'ho visto (e ho visto anche il prezzo ), stavo guardando su audiophonics e ho scoperto che pure il matrix mini-i ha il telecomando (anche altri, se è per questo) ma ha pochissimi ingressi
Re: Emotiva XDA 1
aggiornamento: sembra che l'xda-1 accetti i 24/192 via usb, in giro si legge il contrario
http://www.hometheatershack.com/forums/two-channel-audio/41429-emotiva-xda-1-dac.html
I just got off the phone from speaking with Eric about the XDA-1's USB ports. There has been confusion as to just what the specs for the USB is really capable of handling. Well, now we have the official confirmation from Eric that the XDA-1 DOES handle 24 bit/192 KHz via its USB inputs. Of course it also handles 16/44.1, 16/48, 24/96, etc, etc. It will output whatever you send it without down converting the signal.
Re: Emotiva XDA 1
Sul sito della Emotiva effettivamente parlano di limite di 48Khz sulla USB. Girando un po' per i vari forum c'è qualcuno che ne parla bene... sempre in rapporto a quello che costa
Audiolab MDAC
Aeron A 160
Re: Emotiva XDA 1
Via, ho appena preso un XDA-1 a 300€ spedito. Per la cronaca è quello in vendita su ebay: ho fatto notare al venditore che con circa 300€ lo si portava a casa nuovo dagli usa e gli ho offerto la stessa cifra...
Re: Emotiva XDA 1
Attendiamo il tuo test drive...
Provincia : Padova
Re: Emotiva XDA 1
Sei un grande!!!! Ora aspettiamo con ansia le tue impressioni!!
Audiolab MDAC
Aeron A 160
Re: Emotiva XDA 1
trad. ita: aspettiamo che fai da cavia
scherzi a parte, vi farò sapere anche se le mie impressioni non saranno certo al livello dei "recensori professionisti", anzi
Re: Emotiva XDA 1
Per curiosità, ho visto in firma che hai il Lampucera DAC, com'è? Era uno dei papabili, poi ho preso un Forssell MDAC-2 (non è l'MDAC di Audiolab). Grazie.
-Roberto
-Roberto
Stigmata ha scritto:trad. ita: aspettiamo che fai da cavia
Numero di messaggi : 1696
Provincia : Pisa
Impianto :- premi per vedere:
- pannelli T-class
- IKEA bass trap
- Metal bass trap
- Limp mass bass trap
- Soundwall
- CD: Marantz SA-11S2
- pannelli T-class
Re: Emotiva XDA 1
l'ho preso perchè me ne serviva uno in kit e qui ne parlavano bene, è questo qui
e l'ho inserito in un cabinet col fenice20. Suona bene, per quel che ne capisco, ma non accetta > 24/48.
Di certo per quel che costa è un affare, poi si può modificare per accettare bitrate maggiori ma non mi sono avventurato.
Re: Emotiva XDA 1
Stigmata ha scritto: ma non accetta > 24/48.
Per accettare 96Khz si deve fare una modifica:si stacca il piedino 2 del CS4397 dalla massa e si collega al piedino 16 del CS8416,se il dac
è Lampucera.
Ultima modifica di florin il Sab 25 Feb 2012 - 22:24 - modificato 1 volta.
florin- Membro classe argento
Numero di messaggi : 3236
Re: Emotiva XDA 1
mi ricordo di averlo letto, poi mi sono ricordato anche che non so in pratica usare il saldatore
» Emotiva XDA-2 DAC, Pre e HP Amp
» Emotiva Stealth DC-1
» Ma 'sti Emotiva... come sò?
» Pre emotiva
» Emotiva
» Pre emotiva
» Emotiva
Oggi alle 19:22 Da mrcpal91
Oggi alle 17:37 Da ste-65
Oggi alle 8:51 Da Fabiolydia
Ieri alle 23:56 Da Quaiozi!
Ieri alle 11:13 Da embty2002
Ieri alle 10:16 Da Chardonnay
