Extending USB over Cat 5, Wireless, Fiber and Powerline
Extending USB over Cat 5, Wireless, Fiber and Powerline Empty Extending USB over Cat 5, Wireless, Fiber and Powerline
Messaggio Da flovato Gio 16 Feb 2012 - 10:55
Forse ho trovato la soluzione ma non trovo il prezzo. Hoping
http://www.icron.com/resources/usb-extension-products.php
Aiutatemi ad estendere la caccia... se trovo il modo di trasportare la USB 2.0 dall'ufficio alla sala d'ascolto direi che ci siamo, non servono altri computer.
Edit: prezzo altino http://www.instacable.com/en/icron-extreme-usb/icron-ranger-2101.html
Ostia... questo è buono: http://compare.ebay.com/like/130513531430?_lwgsi=y&ltyp=AllFixedPriceItemTypes&var=sbar
http://www.ebay.it/itm/USB-2-0-Extender-Extension-Adapter-RJ45-Lan-Cable-Over-Cat5-5E-6-Up-to-300ft-New-/290613776615#ht_3778wt_1098
In uso: http://www.computeraudiophile.com/content/Stello-U3
I have the icron CAT5 extender and it works pretty well as intended but its not necessarily a magic bullet. The interface to USB electronics need to be really carefully designed for low noise and that was not the purpose of the Icron stuff, just offering extension.
Passing clocks over an interface and keeping phase noise low is quite difficult. There are some papers on this problem with fiber optic clock distribution in a spacecraft and solutions that NASA resorted to. The 10G fiber stuff is great but comparing a laser vcsl and receiver to an optoisolator is a stretch and even those have a pretty high phase noise.
Locating the clocks in the dac side of the interface is the solution. I2S supports clocks at either end of the link but few products have done this. You still have noise coupling issues and its all technique once you get to a certain base level.
UTENTE BANNATO
Data d'iscrizione : 23.12.10
Numero di messaggi : 12509
Extending USB over Cat 5, Wireless, Fiber and Powerline Empty Re: Extending USB over Cat 5, Wireless, Fiber and Powerline
Messaggio Da adicenter Gio 16 Feb 2012 - 13:10
Ma chettefrega? Tanto stai inesorabilmente diventando sordo Wink
Cominciano a diffondersi gli aggeggetti...pardon, devices che che cerchi:
http://www.amazon.it/Belkin-rete-porte-spina-tipo/dp/B000WQ9BPM/ref=sr_1_2?ie=UTF8&qid=1329393938&sr=8-2
Se googli "wireless usb" ne vengono fuori altri.
adicenter
adicenter
Data d'iscrizione : 03.02.09
Numero di messaggi : 2131
Impianto : Si
Messaggio Da flovato Gio 16 Feb 2012 - 13:28
adicenter ha scritto:Ma chettefrega? Tanto stai inesorabilmente diventando sordo Wink
Questo non va con Apple Sad
Recensione di un utente:
Mi sono trovato molto male con questo Network HUB USB.
Per fortuna che l'ho pagato a prezzo scontato grazie ad amazon, altrimenti erano 100€ buttati nel cesso.
Anche se nelle specifiche tecniche scritte sulla carta, il Belkin è compatibile con Mac OS X, nei fatti è tutta un altra storia.
I driver danno problemi nell'installazione e non sono aggiornati per Snow Leopard, tanto meno per il nuovo arrivato Lion.
Manda in kernel panic un numero mostruoso di volte. Fin prima non era mai successo, ora appena provo a disconettere un hdd esterno o a lavorare con la stampante collegata, tac kernel panic.
Ogni 2 per 3 non riconosce l'hdd esterno partizionato. Onestamente ho cercato a lungo una recensione, ma non l'ho trovata. Forse ho capito il perchè! Nessuno ha mai comprato questo pessimo prodotto.
Ah per concludere, l'assistenza Belkin è incompetente al massimo. Nel form di assistenza, bisogna inserire l'OS. Cosa mi ritrovo nella prima e unica email di risposta da parte dell'assistenza? La domanda:"Che sistema operativo utilizza?"
Tirate voi le somme.
UTENTE BANNATO
