MiniDSP USBStreamer: XMOS, 10 canali in/out, interfaccia Toslink & I2S a 125$
MiniDSP USBStreamer: XMOS, 10 canali in/out, interfaccia Toslink & I2S a 125$ Empty MiniDSP USBStreamer: XMOS, 10 canali in/out, interfaccia Toslink & I2S a 125$
Messaggio Da R!ck 27th Giugno 2012, 17:07
Oibo' incominciano a saltar fuori come i funghi! Hehe
The USBStreamer is a miniature 24/192 multi-channel USB to Toslink & I2S interface. Packaged on a tiny PCB of only 2.4" by 1.4" (40x62mm), this interface is the perfect fit for OEM integration or as an element of a customized high performance A/V product.
The USBStreamer utilizes high speed USB2.0 along with the Audio Class 2.0 implementation to simultaneously provide up to 10channels of playback along with 10channel of recording. Out of the 10channels, 2ch are provided on the toslink interface with the remaining provided on the I2S expansion connector. The dongle is up & running in a matter of seconds with compatible drivers for both Mac/Windows platforms. An easy and flexible system integration that follows the footsteps of the miniDSP product line. From a high end stereo USB interface to a multi-channel USB interface, the USBStreamer is an innovative yet cost effective USB 2.0 audio interface for a wide range of custom A/V products.
Features
• 10 x in + 10 x out multi-channel
USB audio asynchronous interface
• Native support up to
24bits/192kHz
• Easy integration for OEM/DIY
Technical
USB Audio Class 2.0 interface
• 2ch in + out over Toslink (optical)
• 8ch in + out over I2S
• Asynchronous USB synchronization
• 24bit Resolution I2S lines
• 44.1/48/88.2/96/176.4/192KHz
• Optical Receiver/Transmitter
• Buffered I2S interface on header
OS compatibility
• WinXP/Vista/7 Thesycon driver
• Mac OS X driverless
Power
• USB Bus powered
• External DC supply header
MiniDSP USBStreamer: XMOS, 10 canali in/out, interfaccia Toslink & I2S a 125$ USBStreamer-thumb
http://www.minidsp.com/products/usb-audio-interface/usbstreamer
R!ck
Data d'iscrizione : 03.09.09
Numero di messaggi : 4987
Provincia : ---
Impianto : -------------
