Berhinger - Behritone C50A - C5A
axxx007xxxz
vicarious
Berhinger - Behritone C50A - C5A Empty Berhinger - Behritone C50A - C5A
Messaggio Da vicarious Lun Set 03, 2012 1:25 pm
Ci sono capitato per caso cercando qualcosa di attivo per un mini impianto da pc, come vi sembrano?
Berhinger - Behritone C50A - C5A Behritone-DSCF6685
http://www.behringer.com/EN/Products/C50A.aspx
http://www.behringer.com/EN/Products/C5A.aspx
http://www.behringer.com/assets/C50A_C5A_WebBrochure.pdf
High-resolution, 30-Watt active nearfield monitor
Full-range 5 1/4" speaker with special diaphragm and deformation-resistant chassis
Frequency response from 90 Hz to 17 kHz with zero crossover phase distortion
Homogeneous dispersion pattern due to singular small-diaphragm full-range driver configuration
Magnetic shielding allows placement near computer monitors
6 1/2" cube cabinet with multiple coats of high-gloss piano lacquer finish
Precision-milled, high-rigidity MDF cabinet and baffle for minimal resonance
5/8" microphone stand mount built into the cabinet base
1/4" soft neoprene pad to serve as an acoustic isolator
Servo-balanced XLR, 1/4" TRS and RCA input connectors plus gain control for precise calibration in stereo setups
High-quality components and exceptionally rugged construction ensure long life
Conceived and designed by BEHRINGER Germany
vicarious
vicarious
UTENTE DISISCRITTO
Numero di messaggi : 2833
Impianto : RadioMarelli
http://www.cospe.org
Berhinger - Behritone C50A - C5A Empty Risposta
Messaggio Da axxx007xxxz Mar Giu 18, 2013 9:01 pm
Non hanno neanche il tweeter...  -.-
axxx007xxxz
axxx007xxxz
Data d'iscrizione : 18.06.13
Numero di messaggi : 41
Provincia : A
Berhinger - Behritone C50A - C5A Empty Re: Berhinger - Behritone C50A - C5A
Messaggio Da Masterix Mar Giu 18, 2013 9:36 pm
axxx007xxxz ha scritto:Non hanno neanche il tweeter...  -.-
Shocked
E quindi?
Non ce l'hanno neanche queste, eppure...
Berhinger - Behritone C50A - C5A C-Horn_d
Data d'iscrizione : 23.10.09
Numero di messaggi : 4098
Provincia : AN (Jesi)
Messaggio Da wasky Mar Giu 18, 2013 10:11 pm
vicarious ha scritto:Ci sono capitato per caso cercando qualcosa di attivo per un mini impianto da pc, come vi sembrano?
Guarda che graziose le Behringer MS16 un micro main monitor
http://www.thomann.de/it/behringer_ms16.htm
Messaggio Da SaNdMaN Mar Giu 18, 2013 10:20 pm
Robè hai un mp Ok
SaNdMaN
SaNdMaN
Data d'iscrizione : 29.09.11
Numero di messaggi : 5972
Trasporto: M2Tech HiFace Two
Messaggio Da axxx007xxxz Mer Giu 19, 2013 7:12 am
Se non hanno il tweeter rischiano di non suonare bene, io ho delle casse (da pc) senza tweeter e non fanno gli acuti.
axxx007xxxz
axxx007xxxz
Provincia : A
Messaggio Da fbj Mer Giu 19, 2013 7:17 am
axxx007xxxz ha scritto:Se non hanno il tweeter rischiano di non suonare bene, io ho delle casse (da pc) senza tweeter e non fanno gli acuti.
scusami tanto ma non centra una mazza Ironic ... per esempio i full range:soinlove: si chiamo cosi xchè hanno tutte le frequenze Oki
fbj
fbj
Data d'iscrizione : 11.09.12
Numero di messaggi : 345
Provincia : .........................
Occupazione/Hobby : ......
Impianto : casse : kef q7
casse : fe103en
PRE :srpp by mau749
ampli : minimalist by hell67
ampli : S.E. EL34
Messaggio Da axxx007xxxz Mer Giu 19, 2013 7:23 am
Allora sono le mie casse da pc che fanno schifo. Crying or Very sad
axxx007xxxz
axxx007xxxz
Provincia : A
Messaggio Da Stentor Mer Giu 19, 2013 7:27 am
axxx007xxxz ha scritto:Allora sono le mie casse da pc che fanno schifo. Crying or Very sad
Va beh ...con Behringer spendi poco e ottieni molto di più !
Cambia la tua firma però !!!! Wink
PS si sa cosa costano queste Behritone?
Messaggio Da Stentor Mer Giu 19, 2013 7:30 am
Quelle con il cabinet in MDF su Thomann costano € 148,00 ...ma la finitura nera è più bella Very Happy
Messaggio Da axxx007xxxz Mer Giu 19, 2013 7:32 am
Il prezzo è scritto nell'immagine del primo post: $119,99 = €89,5982676
Firma cambiata.
axxx007xxxz
axxx007xxxz
Provincia : A
Messaggio Da sonic63 Mer Giu 19, 2013 7:35 am
Shocked
E quindi?
Ma il tweeter non è il conetto piccolino?
Data d'iscrizione : 21.12.09
Messaggio Da Stentor Mer Giu 19, 2013 7:39 am
Guardate invece queste che connettività che hanno ....è una versione Audiophile dei monitor Behringer progettata dalla KRK:
http://www.behringer.com/EN/Products/K5.aspx
http://www.ziomusic.it/2013/02/27/behringer-monitor-nekkst-k5-e-k8/
Non li trovo in vendita ....che non siano ancora disponibili guardando la data dell'articolo?
Berhinger - Behritone C50A - C5A K9
Messaggio Da Stentor Mer Giu 19, 2013 7:45 am
Leggo ora sul sito ...sono in arrivo !!!
Sono pure biamplificate ...compatibili con lo streaming bluetooh .... con IOS c'è la sua app ....connessione USB diretta x il PC ....ingressi RCA e XLR.... la versione con il woofer da 8" deve essere una bomba Very Happy
