[Venduto] Dac Musiland MD11 200€ spedito
[Vendo] Dac Musiland MD11 210€ +ss
Per upgrade vendo DAC Musiland MD11 32/192 su tutti gli ingressi con Usb asincrono.
Specifications:
Digital input:
USB2.0 High Speed Interface: 16Bit, 24Bit, 32Bit sampling depth, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz sampling.
RCA coaxial, BNC coaxial, fiber optic: 16Bit, 24Bit sampling depth, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz sampling. Support MMDI instruction.
MULINK high-definition digital interface: 16Bit, 24Bit, 32Bit sampling depth, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz sampling. Support MMDI instruction.
Clock jitter (44.1kHz): S / PDIF less than 200PS, USB, MULINK less than 100PS
Line output
Dynamic range: greater than 116dB
SNR (A weighted): greater than 116dB
Total harmonic distortion: less than 0.0005%.
Frequency Response (20Hz ~ 20KHz): +-0.2dB
Max Level: 2V rms
Output Impedance: 10KΩ
Headphone
Max Level: 4V rms
Impedance: 10Ω
Power: 300mW/RL = 300Ω
Other
AC Power Input: 90V-265V, 50/60Hz
Power consumption: <15W
Color: Black
Case Material: iron box, brushed aluminum panel technology
Dimensions (Chassis): 195x160x50 (mm)
DAC body Weight: about 1.4kg
Package weight: 3kg
Interface
A side port optical input interface
An RCA coaxial input
A BNC coaxial input
A B-type USB input interface
1 group RCA line output interface
A 6.25mm headphone output interface
Main characteristics
Stereo analog output
Support S / PDIF input format: PCM
The maximum supported number of input formats: 32Bit/192KHz
LCD, brightness, contrast adjustable backlight color R, G, B independent adjustable
Line, headphone independent switch, independent volume adjustment
High-end discrete headphone amplifier
Manually select the input
USB2.0 high-speed computer interface, driver support: Windows XP / Server 2003 / VISTA / 7, support for ASIO 2.0
Specifications:
Digital input:
Line output
Max Level: 2V rms
Headphone
Max Level: 4V rms
Impedance: 10Ω
Other
Color: Black
Package weight: 3kg
Interface
A BNC coaxial input
Numero di messaggi : 1849
Provincia : Varese Prov.
Sorgente: Oppo DV-983-H
Diffusori: Focal Aria 906
Cuffie: AKG K272HD ,AKG K340
Re: [Venduto] Dac Musiland MD11 200€ spedito
Ribasso a 200€ spedito.
Venduto su altri lidi ,si può chiudere.Grazie
» [VENDUTO] DAC Musiland SVDAC06 - 80 Euro spedito (TO)
» [Venduto][Fi]Musiland USD 01 versione 2012 €45.00
» Vendo MUSILAND MONITOR 01 USD 45€ spedito
» ROMA vendo musiland svdac06 dac 70 euro spedito
» [VENDUTO] Musiland Monitor 02 US € 80 + ss
Oggi alle 18:07 Da ste-65
