diffusori NuForce
diffusori NuForce
Get CD-quality audio from your mobile devices with NuForce S3-BT speakers, featuring the latest aptX and AAC Bluetooth compression codes.
Milpitas, Calif. – EMBARGO until October 16 @ 9:00 AM EST – NuForce, Inc., a leader in professional and consumer audio solutions, announces the arrival of its S3-BT wireless Bluetooth loudspeakers. The NuForce S3-BT is a meticulously designed active loudspeaker that features the latest aptX® and ACC technology for clear, full-bodied, distortion-free audio streamed over Bluetooth.
Jason Lim, NuForce CEO: “With Bluetooth-enabled devices becoming the most common way to carry and listen to audio files, we at NuForce decided to create a speaker that would satisfy even our most discerning customers. By implementing the latest technology and focusing on custom design, we’ve successfully created speakers that deliver the most advanced audio performance from a Bluetooth bookshelf speaker today.”
The S3-BT speakers are based on an essential, time-honored principle: good sound depends on intelligent design and superior materials. For example, the S3-BT’s woofer employs a proprietary anti-resonance cone and powerful magnet assembly. Similarly, the tweeter consists of a custom-designed soft dome design for negligible distortion and smooth, natural sound. And, for the eye, the speakers’ outer shells are wrapped in soft white or black leatherette.
The S3-BT’s aptX Codec feature offers exceptional Bluetooth performance. However, for those who demand yet better sound along with convenience, we’ve included a set of analog inputs for connecting directly to a TV or other entertainment device. NuForce’s own Air DAC wireless system can be also be connected to the S3-BT speakers for even higher quality wireless audio streaming.
Note: The NuForce Air DAC has been designed to achieve a 16-bit performance level that simply isn't possible via the Bluetooth standard. As good as Bluetooth with aptX are, the S3-BT coupled with the NuForce Air DAC sounds even better.
Product Specs:
Features
-Superior sound from mobile devices. Utilizes the latest AAC (iPod, iPad, iPhone) and aptX Bluetooth compression Codecs (Select Apple products* and Android devices) for CD-quality wireless audio
-Secondary analog inputs for integration with TV or other home audio devices
-Analog inputs can also be used for upgrading to NuForce Air DAC wireless system offering outstanding performance and negligible latency
-Elegant design wrapped in soft black or white leatherette
-Compact bookshelf size that fits any room or decor
-Wireless freedom - music playback from any Bluetooth device
-Proprietary anti-resonance woofer and custom-designed soft-dome tweeter
-Efficient Class-D amplification for crystalline sound and low power consumption
Speakers
-1" soft dome tweeter x 2
-3.5" composite paper cone woofer x 2
Amplifier
-Maximum power output: 18 Watt x 2 RMS
-Harmonic distortion: less than 0.5% 1 W 1 kHz
-Frequency response: 50 Hz - 20 kHz
-Signal/Noise ratio: greater than 75 dB
-Separation: greater than 45 dB
Input/Output
-Speaker output on right channel unit: Five-way binding posts
-Speaker input on left channel unit: Five-way binding posts
-Analog Input: RCA jacks
-USB Charger Port: 5v, 1A output (strictly for charging mobile devices only, no audio/data transmitting)
-Bluetooth wireless connection: Bluetooth core version 4.0 with aptX , SBC, AAC codecs; A2DP and AVRCP profiles
Dimensions: 7” H x 4.57” W x 7.48” D
Weight: 5.51 lb. each
Included Accessories: (2) S3-BT Bookshelf Speakers, 3.5mm Stereo to RCA Cable, Interconnect Speaker Cable, AC Power Adapter
The NuForce S3-BT is available for $299 starting from October 31. For purchase, visit Nuforce Amazon Online Store, Nuforce eStore and Nuforce dealers. For more information on this or any NuForce product, contact PR representative Jessica Darrican at 305-374-4404, extension 116.
About NuForce:
Based in Milpitas, California, NuForce first gained notice with its patented Class-D power amplifiers, earning numerous awards from audio publications in the U.S. and Japan. Building upon its reputation as a company that develops state-of-the-art audio products, NuForce has worked diligently to expand its product line with digital-to-analog converters, in-ear and over-the-ear headphones, speakers, subwoofers, cables, additional home and headphone amplifiers, and other quality audio accessories.
Today, NuForce is sold internationally and remains firmly committed to being a high-performance consumer electronics company adhering to stringent quality standards, ensuring integrity and value in every NuForce product.
Media Contacts:
Jessica Darrican
Max Borges Agency
305-576-1171 x.16
305-299-3449
Anna Zhao
NuForce, Inc
Phone: +1-408-890-6840
JessicaDarrican@maxborgesagency.com
Numero di messaggi : 1265
Provincia : trasparente
phono -- Graham Slee Amp 2 se
CUFFIE-- akg q 701
Re: diffusori NuForce
DIFFUSORI PER T-AMP DA SCRIVANIA
Come qualità CD audio dai tuoi dispositivi mobili con NuForce S3-BT casse, dotate ultime APTX e codici di compressione AAC Bluetooth.
Milpitas, California - EMBARGO fino al 16 ottobre @ 9:00 AM EST - NuForce, Inc., leader nello sviluppo di soluzioni audio professionali e consumer, annuncia l'arrivo del suo S3-BT altoparlanti wireless Bluetooth. Il NuForce S3-BT è un diffusore progettato meticolosamente attivo che caratterizza le ultime APTX ® e la tecnologia ACC per un chiaro e corposo, senza distorsioni audio streaming via Bluetooth.
Jason Lim, NuForce CEO: "Con i dispositivi abilitati Bluetooth diventando il modo più comune per trasportare e ascoltare i file audio, noi di NuForce deciso di creare un diffusore che potesse soddisfare anche i nostri clienti più esigenti. Implementando la tecnologia più recente e concentrandosi su design personalizzato, abbiamo creato con successo gli altoparlanti in grado di offrire le più elevate prestazioni audio da un diffusore da scaffale Bluetooth oggi. "
Le S3-BT casse si basano su una essenziale, tempo onorato principio: un buon suono dipende dal design intelligente e materiali di qualità superiore. Ad esempio, il woofer S3-BT utilizza un esclusivo anti-risonanza cono e magnete potente. Allo stesso modo, il tweeter è costituito da una custom-designed disegno a cupola morbida per la distorsione trascurabile e liscia, suono naturale. E, per l'occhio, involucri esterni dei diffusori e sono avvolti in morbida similpelle bianco o nero.
L'S3-BT APTX funzionalità Codec offre prestazioni eccezionali Bluetooth. Tuttavia, per coloro che chiedono suono ancora migliore con comodità, abbiamo incluso una serie di ingressi analogici per il collegamento diretto ad un televisore o altro dispositivo di intrattenimento. NuForce proprio DAC sistema Air wireless può essere anche collegato alla S3-BT oratori per lo streaming wireless ancora più elevati di qualità audio.
Nota: Il DAC NuForce Air è stato progettato per ottenere un 16 bit livello di prestazioni che semplicemente non è possibile tramite lo standard Bluetooth. Buono come Bluetooth con APTX sono, la S3-BT insieme alla Air NuForce DAC suona anche meglio.
Specifiche del prodotto:
Lineamenti
-Superior audio da dispositivi mobili. Utilizza l'ultima AAC (iPod, iPad, iPhone) e APTX codec di compressione Bluetooth (Seleziona prodotti Apple * e dispositivi Android) per audio di qualità CD senza fili
-Secondari ingressi analogici per l'integrazione con la TV o altri dispositivi audio domestici
-Ingressi analogici può essere utilizzato anche per l'aggiornamento al sistema wireless NuForce DAC aria grazie alle straordinarie prestazioni e latenza trascurabile
-Design elegante avvolta in morbida similpelle nero o bianco
-Dimensioni compatte libreria che si adatta a qualsiasi ambiente o arredo
-Wireless libertà - la riproduzione di musica da qualsiasi dispositivo Bluetooth
-Proprietary anti-risonanza woofer e custom-designed tweeter a cupola morbida
-Efficiente amplificazione in classe D per un suono cristallino e bassi consumi
Altoparlanti
-1 "Tweeter a cupola morbida x 2
-3,5 "Composito woofer cono di carta x 2
Amplificatore
-Potenza massima: 18 Watt x 2 RMS
-Distorsione armonica: inferiore allo 0,5% 1 W 1 kHz
-Risposta in frequenza: 50 Hz - 20 kHz
-Signal/Noise Ratio: maggiore di 75 dB
-Separazione: maggiore di 45 dB
Input / Output
-Uscita altoparlante canale destro sull'unità: Cinque vie morsetti
-Speaker ingresso dell'unità di canale sinistro: cinque vie morsetti
-Ingresso analogico: jack RCA
-USB Charger Port: 5V, 1A di uscita (rigorosamente per caricare solo i dispositivi mobili, dati audio / trasmissione)
-Bluetooth connessione wireless: Bluetooth versione 4.0 con nucleo APTX, SBC, codec AAC, A2DP e AVRCP
Dimensioni: 7 "H x 4.57" W x 7.48 "D
Peso: 5,51 £ ogni
Accessori inclusi: (2) S3-BT Diffusori da scaffale, stereo 3,5 mm a RCA Cavo, Speaker Cable Interconnect, Adattatore CA
Il NuForce S3-BT è disponibile per $ 299 a partire dal 31 ottobre. Per l'acquisto, visitare il sito NuForce Amazon Online Store, NuForce eStore e rivenditori NuForce. Per ulteriori informazioni su questo e altri prodotti NuForce, contatto PR rappresentante Jessica Darrican al 305-374-4404, interno 116.
A proposito di NuForce:
Con sede a Milpitas, in California, NuForce primo ha guadagnato l'avviso con i suoi brevettati in classe D amplificatori di potenza, ottenendo numerosi riconoscimenti da pubblicazioni audio negli Stati Uniti e in Giappone. Sulla base la sua reputazione di una società che sviluppa prodotti audio state-of-the-art, NuForce ha lavorato diligentemente per espandere la propria linea di prodotti con digitale-analogico convertitori, in-ear e over-the-ear cuffie, altoparlanti, subwoofer , cavi, casa supplementare e amplificatori per cuffie, e altri accessori audio di qualità.
Oggi, NuForce è venduto nel mondo e rimane fermamente impegnata ad essere una potente società di elettronica di consumo rispettando rigorosi standard di qualità, garantendo l'integrità e il valore in ogni prodotto NuForce.
Lineamenti
Altoparlanti
Amplificatore
Input / Output
Peso: 5,51 £ ogni
CUFFIE-- akg q 701
» Diffusori per...Nuforce!
» Diffusori per Nuforce
» Diffusori per NuForce Ref.9SE V3
» Diffusori NuForce S-1
» Quali diffusori per nuforce Icon ?
Oggi alle 18:07 Da ste-65
