[OPEN SOURCE] Equalizer APO - Equalizzatore parametrico a sistema largo per Windows 7 / 8
[OPEN SOURCE] Equalizer APO - Equalizzatore parametrico a sistema largo per Windows 7 / 8  Empty [OPEN SOURCE] Equalizer APO - Equalizzatore parametrico a sistema largo per Windows 7 / 8
Messaggio Da Marco Ravich Ven 14 Giu 2013 - 12:17
Ho appena scoperto questo interessante software open source per Windows:
Equalizer APO is a parametric equalizer for Windows. It is implemented
as an Audio Processing Object (APO) for the system effect infrastructure
introduced with Windows Vista.
Features:
- virtually unlimited number of filters (currently limited to 100 per channel for sanity)
- works on any number of channels
- very low latency, which makes it suited for interactive applications
- low cpu usage
Requirements:
- Windows Vista or later (currently only Windows 7 and 8 have been tested)
- Sound card driver must support APOs (this includes most onboard sound drivers)
- The application must not bypass the system effect infrastructure
(possible by using special APIs like ASIO)
Equalizer APO is best used in conjunction with Room EQ Wizard (http://www.hometheatershack.com/roomeq/), because it can read its filter text file format.
Please have a look at the Wiki (http://sourceforge.net/p/equalizerapo/wiki/) for instructions on installation and configuration.
Sito ufficiale: http://sourceforge.net/projects/equalizerapo/
Download: http://sourceforge.net/projects/equalizerapo/files/
Data d'iscrizione : 20.04.09
Numero di messaggi : 6070
Provincia : MC
https://www.forart.it/
[OPEN SOURCE] Equalizer APO - Equalizzatore parametrico a sistema largo per Windows 7 / 8  Empty Re: [OPEN SOURCE] Equalizer APO - Equalizzatore parametrico a sistema largo per Windows 7 / 8
Messaggio Da Bicicletta Dom 16 Giu 2013 - 11:47
WOW!
Bicicletta
Bicicletta
Data d'iscrizione : 20.01.13
Numero di messaggi : 548
Impianto : PC e varie
Messaggio Da Hoogo Dom 16 Giu 2013 - 16:40
Per fare cosa: un DSP di correzione ambientale tipo MathAudio Room EQ VST che, poi, con con il modulo VST wrapper per foobar, usi in quest'ultimo?
http://mathaudio.com/room-eq-foobar.htm
Hoogo
Hoogo
Data d'iscrizione : 01.04.13
Numero di messaggi : 2199
Provincia : GE
http://www.flickr.com/photos/giannimaselli/
Messaggio Da Bicicletta Dom 16 Giu 2013 - 20:09
Ma quell'add on lavorerebbe solo con foobar? Lo uso quasi mai.
Ho verificato che la "scovata" del Ravich si applica a tutti i flussi audio.
Bicicletta
Bicicletta
Messaggio Da Hoogo Dom 16 Giu 2013 - 20:35
Bicicletta ha scritto:Ma quell'add on lavorerebbe solo con foobar? Lo uso quasi mai.
Mi sembra che usi il framework di Steinberg (VST). Infatti foobar ha bisogno di un wrapper per utilizzarlo.
Hoogo
Hoogo
Provincia : GE
Messaggio Da Bicicletta Dom 16 Giu 2013 - 20:41
Azz, mi sa che devo studiare un po' ...
Non  so di che parli ...
Bicicletta
Bicicletta
