Virtue Audio: succulente novità in arrivo...
+6
Telstar
kingbowser
pentrio
H@L
Tigre Della Tazmania
10 partecipanti
T-Forum, la vera HiFi alla portata di tutti :: Amplificatori :: Integrati e finali a stato solido in classe T/D :: Virtue Audio
Ciao a tutti,
dallo "spazio" Virtue Audio su Audiocircle, post di Seth Krinsky:
"We're ready to start sharing some information about the new models we hope to show at RMAF... Not all will be ready for show time, but many will.
Look out for the new amp line-up that we will be calling the ONE.2, TWO.2, and THREE. We didn't want to lose the numbering but we want you to know that these aren't really dot-release upgrades. They represent a full year of engineering! The redesigned Sensation will come back with the same name... Michael will launch two DAC models. We'll have a CD-player to match Sensation and a pair of insane ICEPower 500W monoblocks.
Let's start with the Virtue ONE.2...
- 100% USA engineering
- Ground-up electrical rebuild
- 4 layer, heavy copper printed circuit board for better routing and higher current handling, lower noise floor.
- More and better decoupling. Optimized power decoupling including our custom 2 pole power caps.
- Much more and lower ESR capacitance
- more slam anyone?
- Soft start circuit.
- High-pass filter jumper
- won't overload your mains if you're using subs
- +8db subwoofer circuit for high sensitivity speakers
- USB input will be around $50 extra but won't be offered until early-2010
- More hand-assembly in the USA
Now the TWO.2...
- All the upgrades of the ONE.2 with the addition of:
- Stepped potentiometer. (For some, replaces a $300+ passive pre-amp)
- 2 of our custom, 4 pole power caps
- 36v capable (42v actually)
- with 3 x 12v lead acid batteries and oven-mitts, would allow you to get over 100 wpc
- Soft start and anti-pop circuits
- A heat-sink on top to soak for real power hogs (may still require an oven-mitt)
- other small improvements...
Now the THREE...
- Want to buy two amps to run as monoblocks? Don't.
- Buy a THREE. Completely dual mono amp with a special power connector that allows you to hook up 2 power supplies.
- Separate power routing to left and right channels.
- Can be run on 1 or 2 power supplies. Switching from 1 supply to 2 is internal and automatic
- Good, solid 130 wpc into 4 ohms.
- This unit can supply so much power we put 2 heatsinks on it and it sits on its side.
Hell on wheels in the same small box.
- Same great upgrades as the ONE.2 and the TWO.2 but with dual mono capability
- Tellurium copper binding posts and RCA connectors
Now Sensation...
- Takes the THREE to a new level with more than 2x the capacitance, heat-sinking and much more.
- Three analog inputs with a great remote control.
- Alps motorized pot with lots of room for upgrades.
- Gorgeous case-work
- Built-to order (longer lead times)
Now the DAC pre-amp... Michael's oeuvre...
- Digital and Analog preamplifier with headphone amp
- Complete new design from the ground up. In house Virtue Audio design.
- ESS Sabre DAC with custom transformer output stage. No op amps, no caps, no potentiometer in the signal path. Extreme quality Onetics transformers.
- Jitter elimination
- Highest quality digital volume control via the ESS Sabre DAC
- Custom 24 step attenuator for analog section
- Relay switching for analog inputs
- Analog section drives the same custom transformer output stage. No caps in signal path
- Separate power regulation for each section. Super regulation for DAC analog output
- 7 inputs. 3 stereo analog / 4 digital
- 2x coax, 2x optical, 1x USB digital inputs
- RCA stereo output + buffered mono sum for powered subwoofer
- Separate headphone amp circuit with ?? phone connector. Same output signal as main outs, but with headphone amp.
- Same form factor as Virtue ONE, TWO, and THREE amps.
- Can be battery powered (24V)
Virtue DAC only. (Just the DACs, ma'am!)
- Nothing but high quality digital signal path
- Same superb ESS Sabre DAC with custom transformer output
- 4 digital inputs
- No volume control or analog section
- Dual RCA outputs
- Same form factor as Virtue amps, in black only
Now the ICEBlock..
- Killer Class-D monoblock based on the ICEpower ASP500 module.
- 500 Watts into 4 ohms
- 115dBA dynamic range
- Damping factor over 1000
- Big, powerful, masculine bass (if you know what we mean)
- Built in power supply 120V or 240V
- Custom balanced XLR or unbalanced RCA inputs, selectable
- Buffered RCA loop out
- Accurate and analytical
- Same form factor as Sensation amp and Piano CD player
And last but not least or lovely Piano CD-player...
- Custom CD player in a case to match the Sensation and ICEBlock amps.
- TDA1542 DAC chip with our own output stage
- Smooth, warm analog like sound
- Dual wound transformers to power the analog and digital circuits separately
- Coax and optical digital outputs
- Dual analog outputs via RCA connectors
- Full featured remote that also works with Sensation
- Customizable colors and appearance
- Heavy and stable. A real brute"
Gli apparecchi ai quali sono maggiormente interessato sono senz'altro i 2 DAC, sono curioso di saperne qualcosina in più anche sul Three; l'ampli basato sui moduli IcePower (strano che non si siano piuttosto orientati su Hypex, a livello di costi mi pare siano lì lì...) e il CD Player mi solleticano invece poco, il Sensation così così e le nuove versioni del "One" e del "Two" suppongo non rappresentino una rivoluzione. Speriamo che la politica prezzi della Virtue non registri grosse variazioni...
Saluti a go-go,
Grrr...
- more slam anyone?
Now the TWO.2...
Now the THREE...
Now Sensation...
- 4 digital inputs
- Dual RCA outputs
Now the ICEBlock..
Saluti a go-go,
Grrr...
Tigre Della Tazmania- Appassionato
- Data d'iscrizione : 07.10.08
Numero di messaggi : 372
Impianto : Grrr...
Re: Virtue Audio: succulente novità in arrivo...
Che dire? Virtue sa come prenderci per... le orecchie!
Strano che il DAC venga proposto in un solo colore ("in black only"), pur avendo lo stesso form factor degli ampli Virtue (disponibili in 5 colori diversi) .
Ciao e grazie per le news, Tigre!
H@L- Membro di riguardo
- Data d'iscrizione : 12.06.09
Numero di messaggi : 678
Provincia : Cagliari
Occupazione/Hobby : apprendista stregone dell'Hi-Fi
- Sorgenti Mac Mini, hiFace, SuperPro DAC 707 USB, Beresford TC-7520, Peachtree DAC•iT.
Preamplificatori KingRex Pre-Amp V.3, Xindak XA3200-MKII.
Amplificatori Trends Audio TA-10.1, KingRex T20U con PSU, Virtue Audio Two.
Integrato TEAC A-H01S.
Diffusori Duevel Planets, Sonus Faber Toy Speaker, JohnBlue JB3.
Cuffie Docet Cuffia-Amp e...
AKG K 701.
H@L ha scritto:Che dire? Virtue sa come prenderci per... le orecchie!
Si ma i prezzi??? Non credo che saranno in piena filosofia class T
Luciano.
pentrio- Membro di riguardo
Numero di messaggi : 924
Provincia : variabile
Sorgente: computer + V-dac
Diffusori: Usher x 719
I loro prezzi in dollari pero' sono sempre stati convenienti (trasporto
compreso). Il plus di potenza secondo me li vale tutti.
Numero di messaggi : 4292
Provincia : CA
Ma cavolo... mi hanno copiato praticamente ogni idea per il DAC.
Io però lo farò pagare di sicuro meno il mio Altair, stay tuned (adesso che ho finito di lavorare posso dedicarmi al sabre con tutto me stesso)
Numero di messaggi : 1176
In effetti, leggendo il tuo thread sullla progettazione del DAC Sabre ci avevo proprio pensato...kingbowser ha scritto:Ma cavolo... mi hanno copiato praticamente ogni idea per il DAC
Ah però! Non avevo capito che avessi anche intenzione di venderne degli esemplari assemblati; interessante...kingbowser ha scritto:Io però lo farò pagare di sicuro meno il mio Altair, stay tuned
L'idea che mi sono fatto è che il Virtue solo DAC uscirà con un prezzo tra i 300 e i 400 dollari (399?), comunque sotto i 500. Il DAC/Preamp (e qui il margine d'errore si fa più ampio...) s'avvicinerà invece ai 1000 dollari (899?) ma potrebbe anche costare qualcosina in più...
Saluti a go-go,
Grrr...
Impianto : Grrr...
Strano l'uso di un chip DAC diverso nel cd-player.
Sarà interessante conoscere i prezzi di dac e dac-pre.
Telstar- Membro classe bronzo
Numero di messaggi : 1717
Porca miseria, non sarebbe male il Virtue.Three...
Giusto per provarlo in confronto al Two e vedere dosa apporta l'alimentazione duale.
Silver Black- Amministratore
Numero di messaggi : 16700
Tigre Della Tazmania ha scritto:Ciao a tutti,
Solo per vedere se ho capito bene: questo vuol dire che i Virtue One/Two escono dal catalogo?
E si sa quando saranno disponibili i Virtue ONE.2 e TWO.2?
pasquale- Affezionato
- Data d'iscrizione : 17.09.09
Numero di messaggi : 239
Provincia : CN
Impianto : Marantz CD67 o macbook --> Onkyo A933 --> Quad 11L
pasquale ha scritto:Tigre Della Tazmania ha scritto:Ciao a tutti,
Qui trovi le ultime info da Virtue: http://www.audiocircle.com/index.php?topic=71115.msg663513#msg663513
dicono che i nuovi prodotti saranno presentati anche se non definitivi qui: http://audiofest.net/2009/index.php
Ho idea che prima di vederli commercializzati dovremo attendere un po'...
Numero di messaggi : 2131
Impianto : Si
A me interessa il nuovo 2.
Poi, non ho bisogno di tantissima potenza, mi basterebbero 100wpc.
Vorrei anche chiedere una cosa: sono watt misurati a 4 od 8ohm?
Cyan- Membro di riguardo
- Data d'iscrizione : 25.06.08
Numero di messaggi : 669
Cyan ha scritto:A me interessa il nuovo 2.
Dovrebbero essere su 4 Ohm. Se hai le Mosscade 502 100WPC bastano
e avanzano (oltre i 40Wpc la distorsione e' dietro l'angolo).
Provincia : CA
Sto leggendo ora la recensione di silver, e dice che siano a 8ohm. Se magari mi puoi dare la conferma silver. Se sono proprio a 8, sai quanti watt hanno a 4ohm?
Perchè 55w a 8ohm sono perfetti, sono proprio quelli che mi ha consigliato renato giussani. Basta che ne abbiano quasi il doppio a 4ohm.
Cyan ha scritto:Basta che ne abbiano quasi il doppio a 4ohm.
Questi sono i parametri dal datasheet tripath:
High Output power
35W @ 6Ω, < 1% THD+N
50W @ 8Ω, < 3% THD+N
117W @ 4Ω, < 10.0% THD+N (paralleled outputs)
Audiophile Quality Sound
0.007% THD+N @ 30W 8Ω
0.005% THD+N @ 70W 4Ω (paralleled outputs)
Sono tutti ottenuti alimentando a 30V.
Per arrivare a 130 WPC probabilmente
hanno aumentato la tensione a 36V
(40v dovrebbe essere il limite teorico massimo )
Se cerchi un ampli con erogazione
doppia a meta carico fa al caso tuo.
Provincia : CA
bonghittu ha scritto:Cyan ha scritto:A me interessa il nuovo 2.
Che vuoi dire, che oltre i 40 W le Mosscade distorcono?
Silver Black ha scritto:bonghittu ha scritto:Cyan ha scritto:A me interessa il nuovo 2.
Ti parlo del mio impianto. Avendo un subwoofer, non ho problemi alle basse frequenze. Infatti, per quel che riguarda i bassi e medio bassi, riesco a tenere volumi "reference" (come chiamano gli Inglesi il volume che si usa nei cinema), ovviamente nella mia piccola stanzetta e a 1m di distanza.
Il problema è che alle medie frequenze non reggono volumi elevati.
Per questo ritengo che le mosscade a 3 vie (le bookshelf) siano superiori sotto sto punto di vista.
Quindi, le mosscade sono eccezionali se ascoltate a volumi moderati. Il meglio di se infatti, lo danno con jazz: dinamica non enorme come nei film o sinfonie, e ascoltabile a volumi non necessariamente da hard rock live.
bonghittu ha scritto:Cyan ha scritto:Basta che ne abbiano quasi il doppio a 4ohm.
High Output power
Grazie. Effettivamente i valori sono abbastanza buoni.
Peccato che non dicono la potenza a 1% di distorsione. Tanto una distorsione inferiore difficilmente porterà a un miglioramente udibile. Cioè, è intuibile, ma non per i valori a 4ohm. Inoltre, cosa vuol dire paralleled outputs?
Secondo voi, aumentare la tensione, avvicina il virtue audio a condizioni limite, facendolo suonare in maniera più sforzata, o no? Ovviamente si parla di ipotesi per ora.
Datasheet TK2050
A pag. 9 il primo grafico partendo dall'alto a destra ti da la curva della
distorsione in relazione alla potenza erogata.
Quindi la distorsione dell'1% si raggiunge a circa 48Wpc.
Per paralleled outputs credo intendano l'uso di un TK2050 per canale,
pilotati entrambi dal TC2000. Che poi e' l'applicazione piu'
frequente di questo chipset.
Non necessariamente. Il TA2024 ha come specifiche 9-14v e si usa
normalmente tra i 12 e i 13,8v. Per il TK2050 le tensioni di utilizzo
piu' frequenti sono 24 e 30v.
Provincia : CA
Datasheet TK2050
Cioè, quindi quella potenza doppia indicata non conta? A 4ohm ha la stessa potenza che a 8ohm?
Cyan ha scritto:Cioè, quindi quella potenza doppia indicata non conta? A 4ohm ha la stessa potenza che a 8ohm?
No, il doppio.
Tranquillo che una distorsione inferiore all1% è tranquillemente udibile. Dipende a che frequenza è e di che tipo è
E comunque solitamente sono le distorsioni dei diffusori che arrivano prima. Molto prima.
Ok che sia udibile. Ma se i diffusori distorcono al 2% (valore comune al 90% dei diffusori, anche "solo" a volumi d'ascolto medi), dubito che cambi molto se distorce del 3%.
Quindi, quello che volevo sapere è se a 1% i watt siano "abbastanza da far alzare la distorsione dei driver relativamente molto più in alto", così che la distorsione dell'ampli conti poco.
Pare quindi che i watt siano abbastanza a quel valore.
Più che altro, spero che il two.2 sia POCO più alto del two, dato che ho spazio limitato, visto che l'ampli lo tengo in un piccolo scompartimento dell'armadio.
» Playstereo inserisce Virtue ONE e TWO tra le novità in arrivo
» Novità virtue audio a settembre?
» Nuovo arrivo nel mio set Virtue audio One2
» Virtue Audio - Virtue.ONE (l'anti ta 10.1?)
» Nuovo Virtue Audio recensito in anteprima su TNT-Audio
Oggi alle 14:33 Da AndreaCD
