Eccovi qui perfettamente sintetizzata (con parole altrui) la mia posizione sui cavi USB :)
+33
mako
BigBoy
Fernando Micelli
fradoca
Albers
GPDB
fedearc89
lukyluke
tix88
wings
natale55
sontero
enrico massa
beppe61
n.enrico
alessandro1
Seo360
paolofb65
ideafolle
Mulo
37 partecipanti
Pagina 1 di 15
Pagina 1 di 15 • 1, 2, 3 ... 8 ... 15
Leggendo questa pagina mi sono illuminato d'immenso, c'est à dire che ho trovato un rispecchiamento fedele (e, soprattutto, ammirevolmente ben descritto) della mia esperienza:
What Kinds of USB Problems Are We Trying To Solve?
My opinion: At first listen, digital audio delivered via USB sounds pretty promising. Unlike some of my colleagues at The Absolute Sound, I found that USB offers very good timing and rhythmic definition, and very stable imaging through the midrange. However, one area where I did notice significant problems involved transient information—especially on hard, sharp transients—in the upper midrange and treble regions. I found that USB could handle sustained upper midrange and treble information reasonably well, but that on transients the sound tended to become overly hard, edgy, and in some cases splashy and diffuse—basically undermining the sense of effortless clarity I was hoping for. In the process, a certain amount of very delicate, high harmonic information also tended to get lost through USB.
And The Answer Is…
Given the observations I’ve outlined above, I wanted to find out what the impact, if any, of the Furutech GT2 cables would be. I’m pleased to report that they do make an audible difference—one that directly helps mitigate the problems I mentioned (though it does not necessarily eliminate them completely).
First, I found the GT2 help minimize background noise and hash—something you (or at least I) tend to perceive not so much as a “heightened sense of quietude,” but rather as “more low-level sonic information becoming discernible.”
Second, I found that the GT2s went right after those spitty, edgy, splashy upper midrange and treble transients that had been bothering me. While my initial listening tests lead me to think these cables, while very good, probably do not enable USB interface to sound as good as competing S/PDIF interfaces, though they certainly help narrow the gap considerably. But the key point is this: with a good USB cable in play, digital audio via USB can become a highly listenable and enjoyable alternative (even if can not yet claim—in an absolute sense—to scale true “state-of-the-art” heights).
I find these results very encouraging, since they suggest to me that USB has more performance potential that some have thought—potential that good USB cables such as the Furutech GT2 can help us tap in the here and now.
http://www.theabsolutesound.com/articles/first-listen-furutech-gt2-audiophile-grade-usb-cables/
And The Answer Is…
Mulo- UTENTE BANNATO
Numero di messaggi : 4429
Provincia : quo qua
Impianto : principesco
Re: Eccovi qui perfettamente sintetizzata (con parole altrui) la mia posizione sui cavi USB :)
... la luminosa bellezza degli spazi infinitiMulo ha scritto:... mi sono illuminato d'immenso ...
nel sapere che qualcun altro sente differenze tra cavi USB!
... e vi sposerete?
Numero di messaggi : 7923
E' qualcosa che va leggermente oltre il "sentire una differenza", lui l'ha detto bene
Provincia : quo qua
Visto che si parla di "absolute sound", forse ci vuole l'orecchio assoluto in queste cose
Provincia : quo qua
Io poi penso che la sensibilità o la percettività (che è una forma di apertura) sia tutt'uno coll'apertura mentale: ironicamente o no, tutti coloro che non pensano valga la pena provare, credo sprecherebbero il loro tempo semmai lo facessero. D'altro canto, per certi pazzoidi come me e lui, se non usi un buon cavo USB ti passa proprio la voglia di usare il PC come libreria musicale, meglio lo scomodo vecchio lettore CD.
Provincia : quo qua
Le parole "Mulo" e "perfettamente sintetizzata" riunite nel solito 3d .
Che interessante ossimoro .
pallapippo- Membro classe oro
Numero di messaggi : 5514
- Sorgenti:
Mulo ha scritto:Leggendo questa pagina mi sono illuminato d'immenso, c'est à dire che ho trovato un rispecchiamento fedele (e, soprattutto, ammirevolmente ben descritto) della mia esperienza:
celestiale visione di un ILLUMINATO
MIRACOLOOOOO!!!!!!!!
MULO! (miracolato)...... menomale che esisti. te ne siamo gradi x questo.
ideafolle- Membro classe oro
Numero di messaggi : 5429
Provincia : SON CHI' ....NE'
Se aumenta la velocità dei miei hard disk esterni lo compro subito!!
paolofb65- Appassionato
Numero di messaggi : 321
Provincia : La Spezia
sono interessato all'argomento ma non riesco proprio a capire come possa un cavo digitale fare "tutta" questa differenza.
Mettiamo che volessi riprodurre direttamente da cd su pc, ci sono altri mille passaggi che potrebbero creare problemi. Il cavo sata, l'alimentazione del pc stesso, la qualità delle usb stesse che immagino sia molto scadenti, anche su schede da centinaia di € tipo la mia rampage 4x. Il cavo usb probabilmente è l'ultimo dei problemi. però io ascolto musica solo da pc, sarei contento se qualcuno mi delucidasse su come il risultato con un buon cavo usb possa migliorare.
Seo360- Affezionato
- Data d'iscrizione : 11.08.10
Numero di messaggi : 151
Provincia : Varese
Seo360 ha scritto:sono interessato all'argomento,
Ovviamente non fa "tutta questa differenza"
si tratta di sfumature e sensazioni,
è l'ultimo dei problemi, appunto, come hai scritto,
e quindi è un problema anch'esso,
che puoi trascurare, se non gli dai importanza,
oppure "drammatizzare", se dai importanza ad ogni sfumatura.
Nella vita
anche le "drammatiche" varianti tra vini, tra caffè e tra profumi,
mi pare insignificante,
il colore della spiaggia, il tessuto dell'interno dell'automobile,
la quantità dei programmini/giochini che i nuovi cellulari hanno,
mi sembra tutto insignificante,
ma la vita è la somma di cose insignificanti e drammatiche davvero.
Un filo cosa cambia? Nulla direi, ma se trasforma l'ansia in pace
ha cambiato tutto,
e tutto a basso costo.
E che palle...... Se non ti interessa, non dire che ti interessaSeo360 ha scritto:sono interessato all'argomento ma non riesco proprio a capire come possa un cavo digitale fare "tutta" questa differenza.
P.S. Noi ci preoccupiamo solo di quello che possiamo controllare, e i cavi USB hanno questa ^ importanza nè più nè meno..
Provincia : quo qua
a me interessa che ti interessi che a lui non interessi
Numero di messaggi : 3693
Provincia : PU
diffusori - Stabilo 880 Woody
il resto è diy montessoriano
ha cambiato tutto,
Comunque io credo che non sappiate leggere l'inglese non-del-tutto-terreno di questa ^ persona.
Ultima modifica di Mulo il Mer 20 Ago 2014 - 16:10 - modificato 1 volta.
Provincia : quo qua
Credo che con un buon cavo USB da 10-20 euro si è felici lo stesso,non vedo tutte queste sfumature fenomenali all'orizzonte.
Albert^ONE- Membro classe oro
Numero di messaggi : 6417
Fichissimo, meglio per te. Chissà dove l'hai trovato poi un buon cavo USB da 10-20€, persino il QED che è tristarello e miserello costa appena di più. Ho da fare, chiudo qui.Albert^ONE ha scritto: Credo che con un buon cavo USB da 10-20 euro si è felici lo stesso,non vedo tutte queste sfumature fenomenali all'orizzonte.
Provincia : quo qua
Mulo ha scritto: Ho da fare, chiudo qui.
- Sorgenti:
Io ce l'ho un buon cavo USB che persino Albert^ONE potrebbe permettersi: http://www.ab-system.hk/index.php?route=product/product&path=77&product_id=94
Ma lo tengo sempre ne cassetto, lo uso di tanto in tanto solo con l' HA INFO U2 Plus V2. Anche l' Atlas Element A-B ultimamente se ne sta nel cassetto, perchè con i miei apparecchi gli preferisco il Chord, e ovviamente l' Audioquest più costoso; invece quello A-Mini di Element mi è prezioso.
Non turbatevi, siamo pazzoidi
Provincia : quo qua
pallapippo ha scritto:Mulo ha scritto: Ho da fare, chiudo qui.
quoto
magari ....fosse vero che co' sti sermoni ............
p.s. comunque, io con il mio dac uso il cavo usb della stampante , e va benissimo.
Beato te! A me quando lo riattacco alla stampante comincia a sonà e fischià come un ossesso, me stampa le bollette cantate!!!
emmeci- Membro classe oro
L'importante è crederci ^^^ no?
Provincia : quo qua
Detta così dai ragione a Mulo (il quale magari ragione ce l'ha pure ...o forse no, non me ne intendo e non mi pronuncio).Albert^ONE ha scritto: Credo che con un buon cavo USB da 10-20 euro si è felici lo stesso,non vedo tutte queste sfumature fenomenali all'orizzonte.
Voglio dire che é un'ammissione implicita del fatto che i cavi usb influenzino il suono. Ossia: un cavo da 1 euro é troppo misero e suona male, ma con uno da 10 o da 20 giá siamo ad un livello più che soddisfacente.
Io l'ho intesa così.
Ma se passa questo concetto (che, per carità, per quanto ne so può essere giusto) allora nulla vieta che un cavo usb da 100 euro possa suonare ancora meglio.
n.enrico- Membro di riguardo
- Data d'iscrizione : 08.04.09
Numero di messaggi : 923
Non c'è una ragione o un torto: le cose vanno provate e se per te fanno la differenza, allora hai speso bene i soldi. Con i cavi il discorso non cambia (certo se ne provi di vari livelli di prezzo ti rendi conto dei valori relativi).
Provincia : quo qua
No, non è così!n.enrico ha scritto:... Ossia:
con uno da 10 o da 20 giá siamo ad un livello più che soddisfacente ...
se passa questo concetto nulla vieta che un cavo usb da 100 euro
Un cavo USB deve avere la struttura costruttiva adeguata a trasferire
il segnale digitale "riconoscibile senza esitazioni" al circuito di ricezione,
fatto questo, un ulteriore miglioramento è inutile.
Un esempio?
se in mezzo al rumore io ti detto un numero telefonico, tu puoi non capirlo,
ma se la mia voce è comprensibile è inutile che io sia Claudio Capone,
il numero resta uguale e la decodifica idem, idem!
(Claudio Capone, purtroppo deceduto, era la fantastica voce di Superquark)
Ma io credo che:
sia più probabile che due USB suonino differenti
che due cavi 220 Volt di rete suonino differenti
che due fili segnale di un metro applicati dopo un buon preamplificatore,
suonino differenti.
Un buon preamplificatore: ovvero, quasi nessun valvolare.
Quindi, chi, in altri 3D, parla di quel o di quell'altro cavetto segnale o cavo rete,
dovrebbe astenersi di giudicare l'inutilità di spendere su cavi USB.
Mulo ha scritto:E che palle...... Se non ti interessa, non dire che ti interessaSeo360 ha scritto:sono interessato all'argomento ma non riesco proprio a capire come possa un cavo digitale fare "tutta" questa differenza.
guarda che sono serio. vorrei provare un audioquest Forest, così, per provare un cavo diverso e vedere se c'è un cambiamento, anche minimo. Ma non ho il coraggio ne di spendere quei soldi per un cavo usb, ne di pensare a quello che potrebbe uscire dalla mia bocca dopo averlo provato
Seo360- Affezionato
Provincia : Varese
suvvia mauro , un po' di serieta ogni tanto ci vuole, mi e' arivato il dac nuovo .l'asus. adesso veramente, io o provato a cambiare il cavo mo come mai non lo so ,ma cosi e' con quello della stampante di qualita .... sconosciuta al posto di quello del dac che uso in dotazione , be' non ci crederai ma la differenza cie' con quello della stampante io suono era inscatolato , quando o rimesso il suo e' tornato a posto suono aperto e privo di veli . me sa che mulo a ragione sui cavi . mulo quale mi conzigli di prendere se lo volessi cambiare?
» Differenza entrate audio Denon PMA925R e collegamento periferiche
» Eccovi una sorgente valida ed economica per multiamp!
» help subwoofer
» W3-micro....le MIE
» rendere visibile posizione potenziometro
» help subwoofer
Pagina 1 di 15
Ieri alle 19:22 Da mrcpal91
Ieri alle 17:37 Da ste-65
Ieri alle 8:51 Da Fabiolydia
