(AL-GE)+Sped. DAC e Ampli Cuffie BENCHMARK DAC1 (FOTO)
(AL-GE)+Sped. DAC e Ampli Cuffie BENCHMARK DAC1 (FOTO) Empty (AL-GE)+Sped. DAC e Ampli Cuffie BENCHMARK DAC1 (FOTO)
Messaggio Da alex_i Ven Feb 27, 2015 9:04 pm
Vendo fantastico dac e ampli cuffia, non ha bisogno di presentazioni, un punto di riferimento sia nell'hi-fi che nel professionale.
In ottime condizioni, vendo a €550 SPEDIZIONE COMPRESA con corriere in 24 ore. Prezzo non trattabile. Astenersi perditempo e sognatori, Le offerte si fanno in chiesa..
Two Channel, 24-bit, 192-kHz, D-to-A Conversion
• Plays 192-kHz with 52-kHz analog bandwidth
• Direct connection to powered monitors
Total jitter immunity via UltraLock™ technology!
116 dB signal-to-noise ratio @ 48-kHz, A weighted
THD+N = -107 dB (0.00045%) measured at -3 dBFS, any sample rate, any test frequency
• AES, S/PDIF, and Toslink inputs
• Digital input source-selection switch
• Variable or preset output level controls
• Balanced Low-Z XLR outputs
• Unbalanced RCA outputs
• Automatic de-emphasis for 44.1, 48, and 96-kHz when pre-emphasis bit is set
Headphone amp = 0.0003% THD into 60 Ω
• Output-off switch position for headphone-only use
• Front panel power and error indicating LEDs
• Internal low-radiation toroidal power supply
• International 120 - 240 input voltage range
• 1/2 wide, 1RU high chassis
(AL-GE)+Sped. DAC e Ampli Cuffie BENCHMARK DAC1 (FOTO) 20150210
(AL-GE)+Sped. DAC e Ampli Cuffie BENCHMARK DAC1 (FOTO) 20150211
alex_i
alex_i
Data d'iscrizione : 17.10.11
Numero di messaggi : 314
Impianto : Sorgenti: C.E.C. DX71 Mk2 Limited Edition, M2Tech HiFace2, Shiit Loki, V-DAC2+V-PSU2, Objective ODAC, Fiio E10, iPod 5.5 Video Diy Mod.
Ampli: Denon AVR 1912
Ampli Cuffie: Lehmann BCL Black Cube Linear, Objective O2
Cuffie: HiFiMan Head Direct RE0, Grado SR60, Sennheiser HD650, Sennheiser HD800
Diffusori: JBL TX400
Cavi di segnale Mogami in configurazione kimber, cavi coassiale mogami
Software: Fobbar2000 / ASIO, JPlay
(AL-GE)+Sped. DAC e Ampli Cuffie BENCHMARK DAC1 (FOTO) Empty Re: (AL-GE)+Sped. DAC e Ampli Cuffie BENCHMARK DAC1 (FOTO)
Messaggio Da MrTheCarbon Mar Mar 03, 2015 7:59 pm
una curiosità: nel caso in cui volessi usare le uscite bilanciate, la manopola volume posta sul davanti, mi funzionerebbe anche come regolazione volume? o è solo per l'uscita cuffie?
nel caso funzionasse anche per il volume potrebbe interessarmi Smile
MrTheCarbon
MrTheCarbon
Data d'iscrizione : 29.06.11
Numero di messaggi : 1429
Impianto : Decente
Messaggio Da alex_i Mar Mar 03, 2015 10:21 pm
MrTheCarbon ha scritto:una curiosità: nel caso in cui volessi usare le uscite bilanciate, la manopola volume posta sul davanti, mi funzionerebbe anche come regolazione volume? o è solo per l'uscita cuffie?
Si, le uscite possono essere configurate come fisse, variabili (con volume frontale) oppure fisse regolabili con trimmer posteriore per regolarle al finale, basta il selettore posteriore.
Inoltre tramite con i jumper interni e possibile regolare il guadagno per accoppiarlo perfettamente al finale in suo possesso, se ce ne fosse bisogno.
alex_i
alex_i
Messaggio Da MrTheCarbon Mar Mar 03, 2015 10:25 pm
Ottimo.. Allora ci faccio un pensiero nel caso, per ora non ho budget per un nuovo dac...
Se sarà ancora disponibile quando avrò i soldi, sarà mio!
Grazie, ciao Smile
MrTheCarbon
MrTheCarbon
Impianto : Decente
Messaggio Da alex_i Mer Mar 11, 2015 11:36 am
Valuto Scambi/Permute.
alex_i
alex_i
Messaggio Da alex_i Gio Mar 19, 2015 10:19 pm
Up
alex_i
alex_i
Messaggio Da franz 01 Sab Apr 04, 2015 8:34 am
Con cosa scambi? Ampli, difussori?
franz 01
franz 01
Data d'iscrizione : 17.01.11
Numero di messaggi : 2202
Provincia : asgard
Messaggio Da alex_i Sab Apr 04, 2015 12:15 pm
Audio: Ascolto solo in cuffia, per cui...
Valuto anche altro, hardware, tablet smartphone ecc..
Tutto da Messaggi provati grazie.
alex_i
alex_i
Messaggio Da alex_i Mar Mag 19, 2015 11:09 am
VENDUTO
grazie per lo spazio.
alex_i
alex_i
