Satorique 3 - Kit diffusori con SB Acoustic Satori
+9
mecoc
robertopisa
franzfranz
bru.b
13 partecipanti
Pagina 2 di 2
Pagina 2 di 2 • 1, 2
Re: Satorique 3 - Kit diffusori con SB Acoustic Satori
Hi Tim,
the Cayin (full) tube amplifier is not in the main system. I normally use it for my Electrostatic AKG headphone.
The amplifier that i will use with the satorique is hybrid and has this characteristics:
Power on 8 ohm: 100 + 100 Watt @ 1kHz, 2% THD
Sensitivity per 100 Watt / 8 ohm: 1.0 Volt - 4.5dBu
Input impedance: 100kohm
Balanced XLR and unbalanced RCA inputs
Input / driver stage with E182CC NOS triodes
Power stage with Sanken transistor
Bandwidth (-1dB): 2Hz ÷ 100kHz
Damping factor at 100Hz: 50
No general feedback
Fully dual mono
This amplifier (the hybrid one) is the Osmino on my profile .It has a problem with the potentiometer and I'm trying to fix it. It's a khozmo 100K 48 steps.
I will open a dedicated 3D.
In the meantime I'm using the Cayin (the back up amplifier) for the tunig and the break-in of the speakers. The Caiyn has the double exit: 4homs and 8 homs. I use the 8 homs exit.
No general feedback
Fully dual mono
bru.b- Membro classe bronzo
Numero di messaggi : 1394
Provincia : Torino (Ivrea)
Streamer - Rasp 3 + Digione
Aune S6 Pro
The Satorique 3 has an Impedance of 4 Ohm, and I write it, because the midrange sound would not fit in level if you use a full tube amp wich transformer between tube an Speaker.
If you use the hybrid amp, you didn't have this problem, the Transistor output can handel a wide rage of Impedance.
The impedance correction is only for Amplifier with Transformer, such real tube amps need.
Tim1999de- Novizio
- Data d'iscrizione : 28.05.18
Numero di messaggi : 3
Provincia : Weimar
Hi Bruno,
Congratulations to your Satorique 3, very nice that you are impressed by the sound.
Regards Tim
Regards Tim
Tim1999de- Novizio
Provincia : Weimar
Questi diffusori sono Fantastici, il risultato non ha nulla a che vedere con un kit di autocostruzione.
Sono olografice, e da ex possessore di monovia fostex, hanno un medio da brividi.
Tutto il bene che ho letto su questo satori da 16" è assolutamente confermato.
Al momento le sto ascoltando con un valvolare Caiyn da 12 W perchè il classe A ha il potenziometro in riparazione.
Ho contattato il produttore del potenziometro e si è offerto di ripararmelo gratuitamente. Ho solamente dovuto spedirlo a Varsavia.
Ho in mente un test su questi diffusori che potrò condividere sul forum, un amico possiede un registratore digitale ad alta risoluzione .. vedremo cosa ne esce fuori.
Aune S6 Pro
complimenti per le casse bru.b
2 domande un po OT
cos'è l'affare posizionato sopra ,color acciaio, forma ad ogiva
cosa sono i tubi del gas da 1 pollice (cavi) che arrivano alle casse?
La piramide ?
2 domande un po OT
La piramide ?
Mauro
Think before click
SubitoMauro- Moderatore
Numero di messaggi : 1941
Provincia : Alto Milanese
Impianto : Nad C 356 BEE
Dynaudio Emit M20
Sennheiser HD380pro
Ciao Mauro,
ti rispondo sotto:
ti rispondo sotto:
https://www.whathifi.com/forum/hi-fi/speaker-voodoo-totem-beakscos'è l'affare posizionato sopra ,color acciaio, forma ad ogiva
https://www.fabercables.com/cosa sono i tubi del gas da 1 pollice (cavi) che arrivano alle casse?
http://www.playmobil.it/grande-piramide-del-faraone/5386.htmlLa piramide ?
Aune S6 Pro
pensavo fosse qualcosa tipo Schumann Pyramid
Mauro
Think before click
Dynaudio Emit M20
Sennheiser HD380pro
Gran begli oggetti! Bravo!
Sauro_Sapi- Appassionato
- Data d'iscrizione : 29.10.12
Numero di messaggi : 349
Provincia : Modena
Impianto : Catena Audio: sorgente digitale Denon DCD 2010AE, amplificatore Denon PMA 2010AE, diffusori RJ Design Violini Primi MKI.
Trasporto: cavi DIY sia per segnale che potenza, su progetti TNT FFRC e Shoestrings.
Ambiente: sala 6x3.9m mediamente trattata.
Ma le lasci grezze? Non le vernici?
Abe1977- Affezionato
- Data d'iscrizione : 11.10.16
Numero di messaggi : 124
Provincia : Al
Sorgente: Cambridge Audio CXN
Nas: Western Digital My Cloud
Pre: Electrocompaniet EC 4.8
Finale: Electrocompaniet AW120
Diffusori: Audiojam2 FABRIX
Per il momento si..
Si intonano con il pavimento ed il mobile di ingresso a detta di mia moglie.
Allora perchè sbattersi e rischiare di scontentare il capo..?
Aune S6 Pro
bru.b ha scritto:Per il momento si..
In effetti, il capo è sempre il capo....
Provincia : Al
» [To - prov] Vendo diffusori Satorique 3 con componentistica SB acoustic 1500€
» [VENDUTO] Diffusori Acoustic Energy Aegis NEO - 115€ + ss
» Diffusori da abbinare ad advance acoustic xi90
» Acoustic Revive YST-64 Supporto per diffusori da pavimento
» Consiglio diffusori: Monitor audio BX2 vs Q-acoustic 2020i
Pagina 2 di 2
Oggi alle 18:07 Da ste-65
