Cristi TA3020 V3c fine dell'odissea
+10
Cristi
hawui1
Radiofaro
Felfra
superrobin
14 partecipanti
T-Forum, la vera HiFi alla portata di tutti :: Amplificatori :: Integrati e finali a stato solido in classe T/D :: TA-3020
Pagina 3 di 3
Pagina 3 di 3 • 1, 2, 3
Supply Bypassing caps
Adding capacitors to bypass the big supply voltage capacitors will not be effective unless they are very low ESR, very low inductance (less than 3-4nH) and very close to the MOS-FET's pins. C8 and C11 serve this purpose. they are X7R ceramic caps with extremely low parasitic inductance, less than 1nH and low ESR. other capacitors, even the 20uF MKP ones experience large lead inductances, and they cannot perform better than ceramic ones. if you reduce even more the ringing, you might use some larger X7R ceramic caps from TaioYuden or AVX, 0.47-2.2uF at min. 160V DC. but they have larger footprint and will not fit on the previous pads. do not use larger caps than 2.2uF because they will have larger inductance. also, pay attention that if the capacitors are larger than 0.47uF the overcurrent protection may not work properly in case of shortcircuit.
Re: Cristi TA3020 V3c fine dell'odissea
superrobin ha scritto:120 ns, era già impostato di fabbrica
Feltra, quegli auricap sono gli accoppiamento di ingresso, ma in quella posizione temo che ricevano un bel pò di radiazione dai mosfet
non è che la qualità del suono ne risentiva?
Appunto.
E quindi cos'è che ti sembra strano, se li ho tolti e rimesso i piccoli stock, scusa?
Felfra- Appassionato
- Data d'iscrizione : 12.10.08
Numero di messaggi : 405
Having the possibility to talk with a qualified engineer is a real privilege
The capacitor I'm using is claimed to be made with two double value capacitor wound in the opposite direction and connected in series to self cancel out inductance
I'm not in the position to say if this is true or not, but if yes, it should at least help to filter out noise coming from SMPS, I guess
Just my 2 cent opinion
superrobin- Appassionato
- Data d'iscrizione : 02.04.08
Numero di messaggi : 314
Provincia : Cadorago (CO)
Impianto : Foobar - ASIO - Musiland 02 - DAC MINI 2496 - TA3020 - Arbour 5.02
Foobar - ASIO - Xonar STX - TA2020 - Nautilus
the internal capacitor inductance..
Sorry if my intervention might sound a bit rude..
but why don't you first try to see if your amplifier is working properly instead of wasting your time trying to make the amplifier better? This amplifier is not a piece of crap "son of a compromise" as some "high production volume" amplifiers you find on market.. Each component and the layout of the pcb traces has been designed to have the best results therefore any intervention done with no proper knowledge 99% of the cases will worsen the performance..
To make tweaking on an amplifier switching high currents at very high frequencies you need:
- A very good knowledge of the phenomenon associated with these kind of circuits
- Good instrumentation and knowledge on how effectively use it..
It's not enough to read the advertisements of the capacitor vendors..
I read that supplying the amplifier with an SMPS causes high frequency artifacts at the output.. this obviously depends on what is the layout, cabling, grounding, kind of SMPS etc.. moreover there are some high frequency residuals that are generated by the TA3020 internal switching also at idle.. and you won't be able to remove these in any way.. On mine I don't have any residuals of the switching frequency even if I connected it to an SMPS.. these residuals appear at very low values, only on the bench when I fully load the amplifier..
Placing an OSCON capacitor in parallel to +5V is not said it's for sure a good thing.. you might discover that the "famous brand" capacitor picks up high frequency noise and it injects this noise directly inside the digital section of your TA3020..
I saw some amplifiers built by other people with HUGE (low capacity but big size) capacitors even under the board.. you can imagine how much noise they inject picking it up from the outputs.. this helps to build a very good oscillator..
Then, when the amplifier self-oscillates the output in the audio band is distorted and the added distortion please the ears of these ppl and they think that the tweaking has added very good value.. Others are adding external capacitors with very long non-shielded terminals..
Then they complain the amplifier has a very high noise floor..
In other words..
The amplifier, if correctly installed, grounded and connected sounds magnificent either with a linear supply or with an SMPS.. obviously with an SMPS you've to apply some more attention on where you place the cables, where you attach the ground point and how you treat your cables.. anyway you don't need to change a single capacitor, integrated circuit or resistor.. each of these components have been added to perform at thier best their specific duty... changing the components with no knowlegde will lead to unpredictable results.. (the vast majority of the times odd results).. the inductance of a pin in an added capacitor may make a lot of difference in a circuit where each single trace on the board has been CAD optimized to reduce ringing and/or to pickup the least HF noise as possible..
Regarding your amplifier superrobin, another (stupid) advice.. connect a carbon (non inductive) resistor at the output and see what happens when amplifier is idle.. If heat builds up in the resistor you can be sure your ampli is picking up noise, has large output DC offset or is self oscillating.. resistor of the zobel network at the output should be a good indicator of self-oscillations as well..
make sure it's working well.. let it burn-in for some hours and you'll discover you don't need gold cacastratos capacitors to make it sound very very well..
hawui1- Affezionato
- Data d'iscrizione : 14.12.09
Numero di messaggi : 177
Impianto : YAMAHA-Pioneer
Magninificent intervention hawui
I've to tell you the I like to make tweaking just to observe the result of each single experiment, it's part of game in this hobby, and a good way to learn some lessons
As you told, the vast majority of these experiment will lead to nothing or to worse result, but sometimes I catch the rigth configuration and something nice it happens
This is the case for my previous TA2020 board and my dac, at the end of all my alchemies I've bring the overall level noticeably up
Possibly this will not the case for the V3c because it's engineered at very high level quality, but I find hard to believe that those cheap input capacitor on the PCB are equally good to a mundorf supreme
I say this because I've already experienced the real difference between a standard cap and a boutique cap
In this case I'm just adding another iron plate to encase the amp PCB, so caps, cabling and pot remains in a completely shielded environment
Now I have also to measure the current drain at idle as you suggested, the two crappy expendable speaker are already connected
Felfra ha scritto:
Appunto.
che trovi così poca differenza tra quei condensatori e gli auricap
non è che non ti credo ne, ma questo differisce dalla mia esperienza, piazzando condensarori di quel livello ho ottenuto miglioramenti significativi su amplificatori, dac e anche i diffusori
ricordo bene lo stupore quando ho sostituito il condensatore del tweeter con un mundorf supreme, i violini hanno magicamente preso vita
hawui, deve essere successo qualcosa
è da un'ora che è li acceso a suonare solo la 50Hz captata dai connettori scollegati, e l'aletta è appena tiepida, i 2 tank sono freddi
uniche cose cambiate: cabinet aperto e input scollegati dai condensatori
vuoi vedere che 5 cm di distanza non erano sufficienti e mi captavano un sacco di EMI al alta frequenza?
acciderba, qui il gioco è decisamente più duro rispetto al TA2020, adesso schermo tutto
superrobin ha scritto: si ok dai, ci siamo capiti
in effetti credo che quei mosfet irradino un bel campo elettromagnetico, quegli auricap li sotto se la accattano tutta quanta
forse
è una mia supposizione, pensa che io sto andando a costruire un'altro scomparto schermato dove mettere condensatori e potenziometro
magari poi non serve a nulla
se arriviamo pure a questo siamo destinati diritti diritti al manicomio
piero7- Membro classe oro
Feltra, fammi sapere come procede la prova coi condensatori di serie
sono piuttosto incuriosito da questa faccenda
Ho un dubbio sulle masse, sull'SMPS tra il GND della 220 e il GND della +-Vcc misuro 20 milli ohm, e in effetti quando è acceso tra il ground della Vcc e la terra misuro una differenza di potenziale di circa 0,1 millivolt
è ok così o farei meglio a collegare a terra anche il GND della Vcc?
premetto che quello sul lato 220 è collegato alla terra della spina insieme a tutto il cabinet
è la prima volta che maneggio un alimentatore switching e amp ad alimentazione duale, non vorrei fare qualche cavolata, o quantomeno creare un famigerato anello di massa
SMPS....
the smps protective Earth pin 3 of the mains connector is connected to secondary GND through a small resistor and capacitor. you can find them behind one of the big capacitors, close to the heatsink. the reason why i connect like this is to avoid GND loops and noise. if you experience noise, you can increase the value of the reistor up to 10R. do not leave the smps without this connection because not only will alter the noise ratio and increase EMI, but it will create flux imbalance in the transformer and lead to staircase saturation which can trigger the over-current protection or even damage the smps in some cases.
Regà io ho un ampli superschermato dal buon vince, però ogni tanto sento cmq qualche fruscio-crepitio.
Sto diventando matto nel capire se proviene realmente dall'ampli o da altro..
Skywalker- Membro di riguardo
- Data d'iscrizione : 17.05.09
Numero di messaggi : 876
Skywalker ha scritto:Regà io ho un ampli superschermato dal buon vince, però ogni tanto sento cmq qualche fruscio-crepitio.
da altro cosa ? non è che ci voglia poi molto a provare sorgente diversa , piuttosto che cavi e casse ...un po' di buona volonta' ....
Con il mio fratellino , nessun problema del genere. L'ampli è silenziosissimo . Devi mettere l'orecchio praticamente a contatto con i tweeters per riuscire a sentire, con il potenziometro al massimo, un debolissimo fruscio.Skywalker ha scritto:Regà io ho un ampli superschermato dal buon vince, però ogni tanto sento cmq qualche fruscio-crepitio.
pallapippo- Membro classe oro
Numero di messaggi : 5514
- Sorgenti:
Il fatto è che non è un rumore fisso ma molto intermittente.
Si sente molto di rado.
Ho già provato a cambiare cavi, sorgenti e diffusori ma il problema persiste. Quindi "credo" possa essere l'ampli. Sto cercando di capire, anche insieme al buon vince, che può essere visto che da lui il problema non si verificava.
Come rumore assomiglia a quello che si sente quando un canale radio non è perfettamente sintonizzato per darvi l'idea..
Mai sentito.Skywalker ha scritto:Come rumore assomiglia a quello che si sente quando un canale radio non è perfettamente sintonizzato per darvi l'idea..
In bocca al lupo .
- Sorgenti:
pallapippo ha scritto:Mai sentito.Skywalker ha scritto:Come rumore assomiglia a quello che si sente quando un canale radio non è perfettamente sintonizzato per darvi l'idea..
In bocca al lupo .
Grazie!
speriamo di risolvere, anche se non è che sia un problema grave (visto che si presenta piuttosto di rado) è un pò fastidioso.
L'unica differenza rispetto al tuo mi pare siano due condensatori in piu di alimentazione e le otto uscite per gli altoparlanti invece di quattro.
che possano essere quelli?
Mi appena è venuta in mente la storia dell'isolamento galvanico... Cristi non aveva postato le modifiche da effettuare alla pcb per la storia della messa a terra? magari nel tuo caso potrebbe risolvere il problema...
Speriamo! anche se non c'ho capito una mazza di quello che hai detto
Cmq hai mail!!
Cmq hai mail!!
» Ma Cristi???
» Cristi's TA3020 v4 coming soon !
» Costruzione del mio Cristi's TA3020 v4.
» Nuova board TA3020 di Cristi tutta a discreti
» La migliore versione ta3020 by Cristi da comprare insieme alla PSU
Pagina 3 di 3
Oggi alle 14:33 Da AndreaCD
