SPARKLE Audio Amplifier
SPARKLE Audio Amplifier Empty SPARKLE Audio Amplifier
Messaggio Da Marco Ravich Gio 4 Nov 2010 - 11:35
Anzitutto una foto che vale più di 1000 parole:
SPARKLE Audio Amplifier SPARKLE-Audio-Amplifier
Dopodiché un'interessante articolo a riguardo:
Besides sending out press releases in an interesting version of Chinglish [Unapproachable Cooling has to be one of my all-time favorites, Ed.], Sparkle Computer presented SFAUD2A1 during Computex Taipei 2009 tradeshow. Unlike a regular sound card, this simply-named card actually doesn't create audio per se.
Instead, the SFAUD2A1 card is a sound amplifying card, something we haven't heard before in this form. Sparkle created a card that uses either a discrete, or more expected - motherboard-integrated audio chip such as RealTek's ALC series - to clean up & amplify the signal going out to the speakers. This concept is interesting one indeed, but going through the specifications made us wonder.
In order to create the card, Sparkle teamed up with D2Audio, digital amplifier company that was recently purchased by Intersil. By using the DAE chip [already proven in Alienware's Hanger 18 HTPC, Ed.] and so on, Sparkle hopes to create the market of PC amplifiers. This is a regular T-class amplifier with low power consumption similar to ones in cars and mobile stereos. Regardless of the quality, this is first product in this class and we would say bravo to the manufacturer - this is a product that can be big in the IT world.
According to the list of paper with specifications, Sparkle should amplify the sound by eight Ohm, 25W output on five channels, making a total of 125W. With DAE-3, new world of possibilities opened. Still, until we see this product and run it through our measuring equipment, we cannot confirm marketing specifications. Just like 119-124 dBA Sound-To-Noise ratio isn't something that you can achieve with a $5,000 LynX AES16e plus Aurora 16 setup, yet you'll read that claim plastered all over $150-200 sound cards. Just some food for thought.
There is one part of the spec where we have to take offense... Sparkle specifies "High Thermal Efficiency - no Heat Sink required", an obvious jab at Creative and ASUS. Folks, sound cards or sound amplifying cards don't need heatsinks because of thermals. But they need to be built inside a full aluminum, top-and-down enclosure to protect the audio signal from the ever-present EMI [Electro-Magnetic Interference] that just destroys sound quality and increases the noise. Regardless of "digital chip", the AD-DA conversion is still made at the output part, and this is where the sound generating products such as sound cards are vulnerable and yet, exposed to EMI.
...qualcuno ne sà di più ???
Ultima modifica di Marco Ravich il Gio 4 Nov 2010 - 16:02 - modificato 1 volta.
Data d'iscrizione : 20.04.09
Numero di messaggi : 6070
Provincia : MC
https://www.forart.it/
SPARKLE Audio Amplifier Empty Re: SPARKLE Audio Amplifier
Messaggio Da wincenzo Gio 4 Nov 2010 - 13:25
Già visto qualcosa di simile
http://www.msi.com/index.php?func=proddesc&maincat_no=134&prod_no=1654
wincenzo
wincenzo
Data d'iscrizione : 10.07.08
Numero di messaggi : 2531
Messaggio Da Marco Ravich Gio 4 Nov 2010 - 16:01
Sì, è una cosa molto simile (anche se questa è 5x25w) ma non ha l'interfacciamento con la scheda madre che non ti costringe ad usare per forza QUELLA scheda madre.
Io volevo ragionare un po' attorno a questi prodotti "inside PC" per capire cosa si può suggerire ai costruttori per realizzare un prodotto audiofilo.
Ad esempio secondo me, la scheda ideale dovrebbe essere 2.0 o, al massimo, 2.1.
Dopodiché io metterei i connettori posteriori "di rete" (come quelli dell'Icon, per intenderci)... anche una bella schermatura 100% della scheda non sarebbe male, imho.
Infine l'alimentazione: meglio separata ?
Provincia : MC
