JM LAB FOCAL COBALT 807
luisclassd
mauz
sono diffusori degli anni '90. sul misconosciuto mi sembra. su goggle si trova un solo link che sembra esaustivo e che contiene solo recensioni entusiastiche:
http://www.audioreview.com/mfr/focal-jmlab/floorstanding-speakers/cobalt-807/PRD_119790_1594crx.aspx#review0
per il resto, nebbia o poco più. non è strano?
fattomi forte da quanto scritto al link sopra le ho prese sulla baia e devo dire che sono euforico del risultato. al momento le uso col Trends e, ascoltando Cocorosie, Jill Scott e i quartetti di Ravel la qualità è buonissima, tanto da farmi intravvedere quanto, da ora in poi, dovrei lavorare sull'amplifcazione per metterla in pari
da audioreview.com
"Let me get to the overall 5 star rating first; this is a small 7-inch 2-way mini-monitor type speaker. It doesn't have the highest amplitude ability in the world, nor the deepest bass. No mini-types do. Within the design criteria of this speaker, however, I have heard only one speaker better: the Scientific Fidelity Crown Joule. The 807 is happy with 100 watts of power; the Sci-Fi CJ needs at least 3 times that. And high powered amps that sound good are expensive. The 807 sounds good with Myryad, NAD and Jolida amps. It sounds even better with the YBA Integre, Bryston and Classe amps, and Musical Fidelity. To whit: the soundstage of the 807s extends past the speakers vertically, hoizontally and has great depth. Not only that, but I am one wont to roam the room while listening: the soundstage of the 807s is extremely stable and consistent. There are no crossover-related artifacts that I can hear, unlike Snells and KEF speakers. Most importantly, the 807s are speakers that do not have a single,overriding flaw or liability that destroys a person's sense of satisfaction. They may not be the best in the world at anything, but they're pretty far up there at anything, considering their design. No comb filtering like the Alon Adrianas, which are $10,000 list. Fuller bodied than the Thiel SCS3s. Listen to any one of several recordings of 1) Brahms' 1st symphony,1st movement. 2)Bach's Tocatta and Fugue in D minor. 3)Smetana's Moldau. 4)Mozart's Eine Kleine Nachtmusuk. Altho the power and majesty, the delicacy and life, or the sense of venue and space all come through, you can still hear the differences of placement, lateral reverb and in some cases even the editing artifacts that are on the recordings. Most speakers that are good eneough to let you hear editing are so analytical that you can't stand them. Not the Cobalts. Smoooooth. If I could stand to lock my head in one place, I might take Vandersteens or Dunlavys. But I can't, and can't afford them. I'll take the 807s anyday.
Strengths:
Smoothness, imaging depth and stability.
Weaknesses:
Not-perfect dynamic range, even with subwoofer. Lack of deep bass if used alone.
Similar Products Used:
Snell K5, Paradigm Active 20, Paradigm Export Monitor and KEF Q15."
mauz- Membro classe argento
Numero di messaggi : 3404
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
Re: JM LAB FOCAL COBALT 807
mauz ha scritto:sono diffusori degli anni '90. sul misconosciuto mi sembra. su goggle si trova un solo link che sembra esaustivo e che contiene solo recensioni entusiastiche:
fattomi forte da quanto scritto al link sopra le ho prese sulla baia e devo dire che sono euforico del risultato. al momento le uso col Trends e, ascoltando Cocorosie, Jill Scott e i quartetti di Ravel la qualità è buonissima, tanto da farmi intravvedere quanto, da ora in poi, dovrei lavorare sull'amplifcazione per metterla in parida audioreview.com
Strengths:
Weaknesses:
bella mauz, quanto hai investito in queste bellezze ?
pardon
http://cgi.ebay.it/JMLAB-FOCAL-COBALT-807S-diffusori-da-stand-vero-suono-/140496614104
schwantz34 ha scritto:pardon
eggià!
ahahahahaha
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
mauz ha scritto:schwantz34 ha scritto:pardon
eggià!
ahahahahaha
Ottimo prezzo
comunque, da tenere d'occhio
su ebay, per una coppia nuova partono da 250 euro al compralo subito a 400
se viaggiano così bene col trends...
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
il massimo della tecnologia focal anni 90 al minimo prezzo. allons enfants de la patrie
luisclassd- Interessato
- Data d'iscrizione : 04.12.08
Numero di messaggi : 92
Occupazione/Hobby : montagna, bici e ovviamente audio(since 1984)
Impianto : tutto cio' con waf accettabile, ovvero le cuffie.
Se è per questo ti assicuro che anche le Focal Utopia il Trends suona bene
Gli e le ho vendute io!!!
Come ho già detto a lui,ha fatto un vero affare,COMPLIMENTI!
lollipopo- Appassionato
Numero di messaggi : 300
Impianto : In evoluzione....
Davvero belle, i miei complimenti e ad un prezzo poi
Numero di messaggi : 2841
Impianto : Marantz PM6005
Rotel RCD 951
Aiwa Excelia XK-007
Sansui T-60L
Focal Chorus 714V
Cavi: Real Cable; JBL
Secondo Impianto:
ahimé! il mio ha il potenziometro che sgracchietta. poi gli cercherò un pre almeno decente.Stentor ha scritto:Se è per questo ti assicuro che anche le Focal Utopia il Trends suona bene
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
mauz ha scritto:ahimé! il mio ha il potenziometro che sgracchietta. poi gli cercherò un pre almeno decente.Stentor ha scritto:Se è per questo ti assicuro che anche le Focal Utopia il Trends suona bene
Non ho mai utilizzate il Trends senza pre .... eliminalo subito con i dip switch e comprati un pre !!!
in Francia sono molto valutate,da noi quasi sconosciute .....
Cabinet di primordine e tweeter da favola,assolutamente fuori dalla sua categoria,quasi mi pento !!
Luca, mi fa piacere sapere che ci sei anche tulollipopo ha scritto:Gli e le ho vendute io!!!
e io ti rinnovo i miei Ringraziamenti!!
e aggiungo anche che lollipopo è stato molto disponibile e gentile
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
lollipopo ha scritto:in Francia sono molto valutate,da noi quasi sconosciute .....
Beh sono francesi comunque consolati ... ora puoi prendere le nuove Electra 1007s: € 2.190,00 di listino ...uno street price un po' inferiore (non ci sono sconti alla Klipsch) e un rapporto prezzo prestazioni incredibile: per me un best buy !
Ultima modifica di Stentor il Mar 18 Gen 2011 - 22:47 - modificato 1 volta.
Anche se la transazione è avvenuta su altri lidi, ci tengo anch'io a dare un super feedback positivo a Maurizio!
Stentor ha scritto:lollipopo ha scritto:in Francia sono molto valutate,da noi quasi sconosciute .....
Hai fatto bene a dirlo,otra sono definitivamente pentito !
lollipopo ha scritto:Stentor ha scritto:lollipopo ha scritto:in Francia sono molto valutate,da noi quasi sconosciute .....
E buttati e prendi le nuove Electra ...se ti piacevano le cobalt qui la differenza è abissale !!
Hai avuto modo di sentirle?Stentor ha scritto:lollipopo ha scritto:Stentor ha scritto:lollipopo ha scritto:in Francia sono molto valutate,da noi quasi sconosciute .....
pure io ero uno dei pretendenti,solo che allo scadere dell'asta non ero in casa
le ascoltai anni fa abbinate all' yba integre' ..
le trovai veramente piacevoli...
glialberi- Affezionato
- Data d'iscrizione : 11.11.09
Numero di messaggi : 240
Provincia : ho finito di arrabbiarmi da parecchio tempo
Impianto : Nella stanzetta:
Miniwatt n3
sonic frontiers sft-1 transport
dac sotis isis
cavi alu Deantoni
acousticrevive rr77
in cerca del diffusore giusto ..
Altro impianto ..del mio amico
Si le avevo acquistate a suo tempo per l'impianto HT e usavo quelle da pavimento come frontali e le tue come surround ...ottimi diffusori ma le nuove electra 1007s ...rinunci al tweeter al berillio ma sono comunque
Vedo che come me ti piacciono le focal. Piccolo OT, cosa ne pensi delle 836V? le hai mai ascoltate?Stentor ha scritto:lollipopo ha scritto:
Rotel RCD 951
Aiwa Excelia XK-007
Sansui T-60L
Focal Chorus 714V
Secondo Impianto:
Orazio Privitera ha scritto:Vedo che come me ti piacciono le focal. Piccolo OT, cosa ne pensi delle 836V? le hai mai ascoltate?Stentor ha scritto:lollipopo ha scritto:
Solo un ascolto da un riv e non mi dispiacevano assolutamente ...certo se puoi fare un piccolissimo sforzo di prezzo e rinuncia di prestazioni in basso le 1007 probabilmente sono meglio...però anche le 836
PS: io ADORO le Focal ...nel mio impianto principale non voglio altro
Ho ascoltato le 836 da un rivenditore abbinate a un M.Fidelity M3 peccato non avere in quel momento la disponibilità economica, erano anche in offerta
Rotel RCD 951
Aiwa Excelia XK-007
Sansui T-60L
Focal Chorus 714V
Secondo Impianto:
» [VENDUTO] JMLab FOCAL COBALT 807 - 250 euro +ss
» [CHIUSO] JM LAB FOCAL COBALT 807s - 220 euro - consegna a mano BI-NO-MI
» Focal Spirit One: Le prime cuffie di Focal
» Focal Chorus 807V e Focal JimLab 807V
» Focal Sib
» Focal Sib
Oggi alle 9:45 Da marco123
Oggi alle 9:19 Da Fabiolydia
Oggi alle 1:33 Da Gregh
