M-audio profire 610...grande acquisto
mouse
vastx
Luca brh
M-audio profire 610...grande acquisto - Pagina 2 Empty Re: M-audio profire 610...grande acquisto
Messaggio Da Luca brh Mer 21 Dic 2011 - 10:53
Questo è quanto riporta LatencyMon dopo circa 30 minuti di analisi
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines belonging to a driver running in your system appear to be executing for too long.
LatencyMon has been analyzing your system for 0:27:30 (h:mm:ss)
System Information
Computer name: LUCA-PC
OS version: Windows 7 , 6.1, build: 7600
CPU: GenuineIntel Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Logical processors: 4
RAM: 3488931840 total
VM: 2147352576, free: 1701371904
CPU SPEED
Reported CPU speed: 2394 MHz
Measured CPU speed: 1600 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED KERNEL TIMER LATENCIES
Highest measured kernel timer latency (µs): 1669.4397
MEASURED SMIs AND CPU STALLS
Highest measured SMI routine or CPU stall (µs) 16.6815
REPORTED DPCs
Highest DPC routine execution time (µs): 2417.9699
Driver with highest DPC routine execution time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 5.8448
Driver with highest DPC total execution time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Total time spent in DPCs (%) 6.2819
DPC count (execution time <250 µs): 10287615
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 160721
DPC count (execution time 1000-1999 µs): 126
DPC count (execution time 2000-3999 µs): 2
DPC count (execution time >=4000 µs): 0
REPORTED ISRs
Highest ISR routine execution time (µs): 688.5977
Driver with highest ISR routine execution time: USBPORT.SYS - Driver porta USB 1.1 & 2.0, Microsoft Corporation
Highest reported total ISR routine time (%): 0.1366
Driver with highest ISR total time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.2126
ISR count (execution time <250 µs): 3400025
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 4
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: none
Total number of hard pagefaults 886
Hard pagefault count of hardest hit process: 581
Highest hard pagefault resolution time (µs): 265919.7610
Total time spent in hard pagefaults (%): 0.4470
TODO: Number of processes hit: 0
PER CPU DATA
CPU 0 ISR count: 848692
CPU 0 ISR highest execution time: 228.9022
CPU 0 ISR total execution time: 3517460.6390
CPU 0 DPC count: 7659616
CPU 0 DPC highest execution time: 1676.3045
CPU 0 DPC total execution time: 138001717.7800
CPU 1 ISR count: 850892
CPU 1 ISR highest execution time: 688.5977
CPU 1 ISR total execution time: 3556207.7330
CPU 1 DPC count: 927948
CPU 1 DPC highest execution time: 2179.2857
CPU 1 DPC total execution time: 83296898.6315
CPU 2 ISR count: 850959
CPU 2 ISR highest execution time: 197.8684
CPU 2 ISR total execution time: 3554762.4248
CPU 2 DPC count: 922901
CPU 2 DPC highest execution time: 1555.9661
CPU 2 DPC total execution time: 112346844.7706
CPU 3 ISR count: 849486
CPU 3 ISR highest execution time: 279.6954
CPU 3 ISR total execution time: 3405977.5263
CPU 3 DPC count: 937999
CPU 3 DPC highest execution time: 2417.9699
CPU 3 DPC total execution time: 81008229.2744
i processi con la maggior Hard pagefaults sono
iexplore.exe 581
svchost.exe 128
svchost.exe 39
iexplore.exe 20
foxit reader 19
iexplore.exe 17
skype.exe 13
searchindexer 12
iexplore.exe 10
wmpnetwk.exe 9
iexplore.exe 8
svchost.exe 3
svchost.exe 1
explorer.exe 1
Drivers
wdf01000.sys runtime framework driver modalità kernel 2884992
usbport.sys driver porta usb 264819
ataport.sys atapi driver extension 181379
dxgkrnl.sys directx graphics kernel 68134
acpi.sys driver acpi per nt 705
che dite???
Luca brh
Luca brh
Data d'iscrizione : 02.08.11
Numero di messaggi : 1571
Provincia : Varese
Cuffie: Beyer990pro, HD 650
Messaggio Da Luca brh Dom 7 Ott 2012 - 18:58
Per i maestri del tweak
fareste qualche modifica alla scheda per migliorarne la qualità
ne vale la pena e se si cosa fare???
stasera posto le foto dell'interno
il primo passo è stato sostituire l'alimentatore diserie con uno di buona qualità (zg146)
Luca brh
Luca brh
Provincia : Varese
Messaggio Da franz 01 Dom 7 Ott 2012 - 19:03
Luca una curiosita':
Hai avuto modo di paragonarla per la sola riproduzione audio con la 410?se si che differenze hai notato?
franz 01
franz 01
Data d'iscrizione : 17.01.11
Numero di messaggi : 2202
Provincia : asgard
Messaggio Da donluca Dom 7 Ott 2012 - 19:07
Posta foto dettagliate dell'interno così vediamo.
Data d'iscrizione : 07.11.11
Numero di messaggi : 3782
Messaggio Da Luca brh Dom 7 Ott 2012 - 19:11
franz 01 ha scritto:Luca una curiosita':
Ho fatto il confronto con un mio amico nel suo impianto e la 610 aveva degli alti un pò più in evidenza della 410 ma grandi differenze non ne ho percepite. Quello che mi ha meravigliato di più era il solito roll off sulle basse frequenze che è identico su entrambe
Cambiando l'alimentatore sicuramente questa carenza è molto diminuita ma non ho potuto testarlo con la 410.
Ora volevo capire se sostituendo "qualcosa" possa migliorare ancora. Sicuramente è una scheda audio della madonna
Ultima modifica di Luca brh il Dom 7 Ott 2012 - 19:21 - modificato 1 volta.
Luca brh
Luca brh
Provincia : Varese
Messaggio Da Luca brh Dom 7 Ott 2012 - 19:12
donluca ha scritto:Posta foto dettagliate dell'interno così vediamo.
Sono dalla morosa e mentre scrivo sto girando il risotto Laughing
appena torno a casa le posto Very Happy
Luca brh
Luca brh
Provincia : Varese
Messaggio Da Luca brh Dom 7 Ott 2012 - 22:42
M-audio profire 610...grande acquisto - Pagina 2 P1010421
M-audio profire 610...grande acquisto - Pagina 2 P1010422
non riesco a togliere le due scehde superiori e nemmeno 2 dei 5 potenziometri frontali
spero riusciate a capire qualcosa
M-audio profire 610...grande acquisto - Pagina 2 P1010423
M-audio profire 610...grande acquisto - Pagina 2 P1010424
Luca brh
Luca brh
Provincia : Varese
Messaggio Da Luca brh Dom 7 Ott 2012 - 22:48
sono riuscito a togliere una delle due schede poste sopra
M-audio profire 610...grande acquisto - Pagina 2 P1010425
M-audio profire 610...grande acquisto - Pagina 2 P1010426
M-audio profire 610...grande acquisto - Pagina 2 P1010427
Luca brh
Luca brh
Provincia : Varese
Messaggio Da fritznet Dom 7 Ott 2012 - 23:28
Occhio a rimontare Luca, e occhio anche a toccare gli integrati, soprattutto se indossi un pile Orrified
Gli integrati digitali sono molto sensibili alle scariche elettrostatiche, se non hai una banda da polso, prima di toccare qualche integrato, ma anche le schede, è buona precauzione toccare qualcosa di metallico e grande (un termosifone, ma anche un ampli o il case del pc se il case è connesso a terra).
Data d'iscrizione : 27.02.10
Numero di messaggi : 10090
Messaggio Da Luca brh Dom 7 Ott 2012 - 23:34
fritznet ha scritto:Occhio a rimontare Luca, e occhio anche a toccare gli integrati, soprattutto se indossi un pile Orrified
grazie molto per l'informazione
l'ho appena rimontata e accesa e va tuttto
Luca brh
Luca brh
Provincia : Varese
Messaggio Da donluca Dom 7 Ott 2012 - 23:56
A lù, quando carichi devi levà però il resize, che in quelle immagini non ci si vede un tubo... ho tentato di leggere la marca dei condensatori ma invano.
A occhio e croce sembrerebbero Panasonic FC o Nichicon "lisci", i marroncini non saprei proprio cosa sono.
C'è veramente poco da fare comunque.
Messaggio Da Luca brh Dom 7 Ott 2012 - 23:58
difatti non ci farò niente perchè a rovinarla ci vuole poco
se non venderò la fca modificherò quella Very Happy Very Happy Very Happy
Luca brh
Luca brh
Provincia : Varese
Messaggio Da donluca Lun 8 Ott 2012 - 0:03
Ma tienitela e tenta al limite di vendere altro, 40 euro non vale veramente la pena te lo dico io, è tutta oggi che sta a suonà con gli SACD che me sò scaric... ehm, che ho reperito oggi dei Dire Straits e sia con le cuffie che, soprattutto, con il TA2024 va una meraviglia, non vedo l'ora di finire di ricappare tutto e sentire come suona!
Ah, non c'entra niente ma mi sono preso l'Alto Zephyr ZMX52 come mixer alla fine a 30 pleuri (ex-demo), che è il clone del berhinger xenyx 502 e il whafedale pro connect 502.
Anzi, mi sa che è l'originale e gli altri l'hanno copiato Razz
http://altoproaudio.com/products/zmx52
Messaggio Da fritznet Lun 8 Ott 2012 - 0:04
donluca ha scritto:
cut
cut
I marroncini dal colore potrebbero essere ELNA, ma non riesco a leggere quel che c'è scritto Very Happy
Messaggio Da Luca brh Lun 8 Ott 2012 - 0:08
ragazzi scusate per le foto ma le ho fatte di corsa
se mi dite che cosa fotografare di preciso ve le mando via pm o mail
lo so che non dovrei venderla. Ci dormo su stanotte e poi domani decido
Luca brh
Luca brh
Provincia : Varese
Messaggio Da Luca brh Lun 8 Ott 2012 - 0:09
non si può vedere il cursore del volume fatto in quel modo Shocked
Luca brh
Luca brh
Provincia : Varese
Messaggio Da fritznet Lun 8 Ott 2012 - 0:18
Luca brh ha scritto:ragazzi scusate per le foto ma le ho fatte di corsa
Quoto donluca, non so se valga la pena e il rischio di mettersi a cambiare qualche componente, se la scheda suona bene così.
Al limite prova a vedere (ad esempio su DIYAudio) se qualcuno si è già avventurato nelle modifiche, e con che risultati.
Messaggio Da Luca brh Lun 8 Ott 2012 - 0:21
Sinceramente la mia era più una menata mentale. Suonare suona bene e ne sono molto soddisfatto. Un giro su DIYAudio lo frò solo per curiosità.
Grazie per i consigli Very Happy
Luca brh
Luca brh
Provincia : Varese
Messaggio Da fritznet Lun 8 Ott 2012 - 0:22
Prego, figurati Smile
Messaggio Da donluca Lun 8 Ott 2012 - 0:52
Luca brh ha scritto:non si può vedere il cursore del volume fatto in quel modo Shocked
Lo so, ma sò sempre 30 euri. Al massimo lo cambio. Razz
Messaggio Da GiAnt1961 Ven 7 Giu 2013 - 15:49
Ciao a tutti,
una domanda ai possessori della 610 che mi sto apprestando ad acquistare. volevo chiedere se vi risulta che con la 610 si possono fare misure (di diffusori intendo). cioè è una full duplex, con un microfono ed un software apposito dovrebbe funzionare giusto?
GiAnt1961
GiAnt1961
Data d'iscrizione : 16.05.13
Numero di messaggi : 6
Impianto : Diffusori 4 vie in multiamplificazione attiva "Giant quattro", Motu 828 mk3, pre NuForce MCP18, Jriver con filtraggio FIR e DRC
Messaggio Da wasky Gio 8 Ago 2013 - 21:40
GiAnt1961 ha scritto:Ciao a tutti,
GiAnt1961
E' ininfluente nelle misure che la scheda sia full duplex importante che imposti bene il routing Smile Io misuro con la 410 della M-Audio ed è superiore usando ARTA alla CLIO audiomatica che possiedo a 16bit 44.100Hz
