Beresford, BUSHMASTER dac ... Parte 1
+69
Pier
giammo
El Alicantino
dajergas
settore 7-g
sim80
franz159
saruman1970
zenit
Charli48
Moriarty
giovi
Kevin4677
Karletto
Fernando Micelli
ilkappa
Docarlo
Gappone
staky07
pentrio
magnaco
ghiglie
alessandro1
wings
Alessandro LXIV
Vella
vastx
Dante
MDT360
scorda
traspar
Faber75
Ornito
Alessio Zenga
cricchio
Telstar
Albers
grunter
Flightangel
lorenzo mordini
ice--79
kurt10
daniele
voolkano
Patrick
iopoipoi
bartman
osservatore
StanleyB
rferrinid
alluce
sickshotshow
mauz
aittam
R!ck
73 partecipanti
Pagina 11 di 40
Pagina 11 di 40 • 1 ... 7 ... 10, 11, 12 ... 25 ... 40
Re: Beresford, BUSHMASTER dac ... Parte 1
Apparently the DAC chip is a WM8524MDT360 ha scritto:scusate ma che dac monta?
Here's some info Stanley provided on the Art of Sound forum, cut and
pasted verbatim which may help answer your question:
"As mentioned in an earlier post, the Bushmster is based on all the
good ideas and mods of the previous designs, plus some new ones. There
are no muting relays and their driver circuits. There is also no line
output output stage. So no line output opamps and associated caps.
It's a DC line output after all so no caps in the signal path to the
output RCA sockets. There is also no variable output. The input
selector circuit has also been simplified from a multi transistor,
latching circuit, and selector diodes, to a microcontroller . And yes,
I have used SMD where possible. They proved to be far less noisy in
the TC-7510. The power supply is also far more compact due to the use
of the latest generation LDO regulators. Those things are a mere
fraction in size to the 78XX regulators that they replace.
The receiver and DAC chips are also far smaller in footprint. The
board has also been laid out so that each section is as far away as
possible from any other section. This helps to reduce the possibility
of noise bleeding into adjacent circuitry."
Numero di messaggi : 10423
Provincia : Lupiae
se non ricordo male un WM8524
Fra
ice--79- Affezionato
- Data d'iscrizione : 17.03.12
Numero di messaggi : 233
Provincia : TBD
Impianto : TBD
molto molto interessante, peccato per la mancanza della usb, ma vabè si risolverebbe con un hiface o simile.
E' possibile acquistarlo solo in uk?
MDT360- Membro di riguardo
- Data d'iscrizione : 01.05.11
Numero di messaggi : 709
AMP STEREO : AERON A-160
DIFFUSORI : MONITOR AUDIO RX6
credo ci sia un distributore in oriente ma la migliore cosa è contattare Stanley Beresford.MDT360 ha scritto:molto molto interessante, peccato per la mancanza della usb, ma vabè si risolverebbe con un hiface o simile.
Provincia : Lupiae
ho provato a fare l'ordine sul sito e in totale viene 197 sterline pari a 250 euro circa, a poco più non conviene comprare il cambridge dacmagic 100 che ha pure usb 192/24?
Se hai voglia ci descrivi un po' meglio le differenze tra i due dac? L'ascolto l'hai fatto in cuffia?scorda ha scritto:Sto giusto ascoltando una radio internet (IPdio della DNT) collegata all'ingresso coassiale 1 del Bushmaster.
Nonostante trasmetta MP3 a 120 Kbps il suono che ne esce è magnifico!
L'ascolto precedente tramite un Maverick D1 risulta povero e piccolo.
Questo Beresford è una bomba!!
Numero di messaggi : 1502
Provincia : Padova
Sorgenti: Asus EEEPC
Dac: Micromega Mydac
Pre: Pass B1 Buffer
Finali: Pass Mini Aleph
Cavi:
usb: Wireworld Ultraviolet
segnale: JPS clone
potenza: Audioquest FLX 14.4
alim: Elecaudio CS-331B
De simone Biagio ha scritto:
e l'ampli per le cuffie dove è? ....è composto solo da quel piccolo operazionale SMD vicino al frontale o è nascosto sotto ?
MDT360 ha scritto:ho provato a fare l'ordine sul sito e in totale viene 197 sterline pari a 250 euro circa, a poco più non conviene comprare il cambridge dacmagic 100 che ha pure usb 192/24?
Come fai a sapere se suona meglio? Caro lei è un probblema
R!ck- Membro classe argento
Numero di messaggi : 4987
Provincia : ---
Impianto : -------------
io non vedo neanche il pot volume
daniele- Membro classe bronzo
Numero di messaggi : 1740
Provincia : vp
Impianto : Hegel h190
Leak Stereo 20
Thorens td124
DAC Lampizator
Dynaudio sp40
daniele ha scritto:io non vedo neanche il pot volume
Io lo vedo ...è verde piccolo ...in basso a sinistra...
Allora l 'ampli cuffia e proprio quell'integrato, ed è assolutamente da ascoltare prima di trarre qualsiasi conclusione. Non vi è un volume, Stan a quanto ho capito, dice che è sufficiente quello quello del player, e probabilmente ha ragione il potenziometro che si vede e relativo all' uscita cuffia. Per quanto riguarda il dac magic secondo me non c'è paragone, qust'ultimo è passato da casa mia ed è subito andato via, perchè la differenza con la emu modificata era evidente, ovviamene a favore della emu,, il Bushmaster credo che invece rimarrà per molto tempo a farmi compagni., Spero di essere stato chiaro.
Provincia : Lupiae
De simone Biagio ha scritto:Allora l 'ampli cuffia e proprio quell'integrato, ed è assolutamente da ascoltare prima di trarre qualsiasi conclusione non vi è un volume, Stan a quanto ho capito, dice che è sufficiente quello quello del player, e probabilmente ha ragione il potenziometro che si vede e relativo all' uscita cuffia, per quanto riguarda il dac magic secondo me non c'è paragone, qust'ultimo è passato da casa mia ed è subito andato via, perchè la differenza con la emu modificata era evidente, ovviamene a favore della emu,, il Bushmaster credo che invece rimarrà per molto tempo a farmi compagnia, spero di essere stato chiaro.
Beh se è solo un opamp miracoli non ne fa di certo come ampli cuffie! ...ma scusa Biagio il potenziometro verde in basso a sinistra e la manopola che ha davanti cosa sono?
il coso verde dovrebbe essere l' interruttore di accensione, la manopola è il controllo volume cuffia, per la qualità di questa sezione aspetta di provarla e poi mi dici.
Ultima modifica di De simone Biagio il Ven 20 Lug 2012 - 15:44 - modificato 1 volta.
Provincia : Lupiae
Questa è la sezione che è stata citata: In basso a destra il potenziometro volume cuffia.
Provincia : Lupiae
De simone Biagio ha scritto:il coso verde dovrebbe essere l' interruttore di accensione, la manopola è il controllo volume cuffia, per la qualit di questa sezione aspetta di provarla e poi mi dici.
E secondo te come fa a controllare il volume della cuffia ....quello che vedi Verde è un potenziometro mentre l'interruttore è in alto !
Sulla qualità Biagio ....non può che essere quella dell'operazionale SMD che ha installato .... non c'è un ampli a discreti e un singolo opamp non fa miracoli ... e visto il prezzo era impensabile che avesse anche un buon ampli per cuffie ! ....è già tanto che ci sia
Il tutto ovviamente se è solo quell'integrato ...poi io non so se sotto c'è altro ....
Su questo non ci sono dubbi, per la qualità prima provalo, poi come ti ho detto darai il tuo parere, può essere che sto prendendo un abbaglio, ma da tempo non usavo una cuffia con tanto piacere. per i potenziometri e colori credo che non sto sbagliando, vedi se con questa foto è più chiaro. Il vaso è un Rosenthal.Stentor ha scritto:De simone Biagio ha scritto:il coso verde dovrebbe essere l' interruttore di accensione, la manopola è il controllo volume cuffia, per la qualit di questa sezione aspetta di provarla e poi mi dici.
Provincia : Lupiae
Si vede meglio?
Provincia : Lupiae
Da sinistra verso destra, interruttore d'accensione, tasto selezione automatico/manuale, led di segnalazione automatico, led canale x 4, presa cuffia , volume cuffia.
Provincia : Lupiae
De simone Biagio ha scritto: Da sinistra verso destra, interruttore d'accensione, tasto selezione automatico/manuale, led di segnalazione automatico, led canale x 4, presa cuffia , volume cuffia.
e che avevo detto io ? ...in basso a sinistra della foto aperto c'è il potenziometro dell'operazionale dedicato alle cuffie .... cmq l'ha fatto davvero bene il cabinet ...lineare ma funzionale
Allora c'è stato un grande equivoco. il cabinet sicuramente lineare e funzionante, ma la cosa che mi ha stupito di più è il servizio che Stan dedica ai suoi clienti, come se fosse un rapporto esclusivo, dopo le poche righe che ho scritto l'altra sera ( prova a casa dell'amico Pierfrancesco), mi scriveva dicendomi che esisteva un aggiornamento del Firmware, mi domandava se fossi stato capace di sostituire l'integrato, spiegando in poche mosse come fare, alla mia risposta affermativa, mi dice che mi spedisce subito il nuovo integrato, e mi prega di mandargli indietro il vecchio per poterlo ricodificare, ma forse conoscendo la calme di noi Italiani per certe cose, mi tranquillizza dicendomi fai pure quando ti sarà comodo. Nemmeno dopo tre giorni da questa conversazione, specificando che è avvenuta venerdi, quindi week end di mezzo, martedi mattina di buon ora il pacchettino di Stan era nella mia buca delle lettere e se ormai non fosse prossimo agosto, avrei pensato che Stan usi come servizio postale, Babbo Natale e le sue renne.Stentor ha scritto:De simone Biagio ha scritto: Da sinistra verso destra, interruttore d'accensione, tasto selezione automatico/manuale, led di segnalazione automatico, led canale x 4, presa cuffia , volume cuffia.
Provincia : Lupiae
un buon trasporto economico da accoppiare a questo dac? ovviamente intendo usb > coassiale.
Secondo voi la xonar essence può andar bene?
Non ho esperienza personale ma ho letto sui forum inglesi che c'è chi la usa con soddisfazione.
Provincia : Lupiae
From the first DAC that I sold, the TC-7510, I have been performing miracles. There are no other audio designers in the world who can design better than me at the price I do it. Name me one if you think otherwise.Stentor ha scritto:
StanleyB- Operatore Hi-Fi
- Data d'iscrizione : 08.06.12
Numero di messaggi : 145
Hello Stan I hope you are well, the new firmware has solved the problem of automatic coupling of the dac, but unfortunately have not yet managed to play my Emu 0404 as a transport S / PDIF, I'll try with a Waveio I have at home and you I know. The Bushmaster even as a DAC for my Pioneer PD 75 is a miracle, I always like more. I also attacked the Sky box and got a noticeable improvement in sound. All I need to hear it with the liquid, and then I send to Stentor, to objectively and honestly, as he always did give his authoritative judgment. Who knows not to revise the Madonna. Spero che per questa pessima traduzione non mi arrestino.
Provincia : Lupiae
I wouldn't waste my time sending the DAC to him. It is quite obvious he has already built up negative thoughts. We call thise kind of people objectivists. There is a topic on that on AoS.
» Beresford, BUSHMASTER dac ... Parte 2
» Beresford Bushmaster
» [MI] Beresford BushMaster MK1
» [TO] Beresford BushMaster MK1
Pagina 11 di 40
