[DR 13] Wolfgang Amadeus Mozart - Requiem K626 - H von Karajan 1986
Analyzed folder: /Users/Nicola/Music/Lossless/Music/Wiener Philarmoniker - Herbert von Karajan/Requiem D minor K. 626
DR Peak RMS Filename
DR12 -2.05 dB -18.77 dB 01 I. Introitus - Requiem.m4a
DR12 -2.64 dB -19.10 dB 02 II. Kyrie.m4a
DR12 -2.25 dB -16.52 dB 03 III. Sequenz - No. 1 Dies irae.m4a
DR13 -8.22 dB -27.77 dB 04 III. Sequenz - No. 2 Tuba mirum.m4a
DR13 -1.11 dB -17.55 dB 05 III. Sequenz - No. 3 Rex tremendae.m4a
DR14 -8.75 dB -27.94 dB 06 III. Sequenz - No. 4 Recordare.m4a
DR13 -1.43 dB -20.91 dB 07 III. Sequenz - No. 5 Confutatis.m4a
DR12 -1.26 dB -18.33 dB 08 III. Sequenz - No. 6 Lacrimosa.m4a
DR14 -2.73 dB -20.41 dB 09 IV. Offertorium - No. 1 Domine Jesu.m4a
DR13 -2.33 dB -19.63 dB 10 IV. Offertorium - No. 2 Hostias.m4a
DR12 -0.97 dB -15.10 dB 11 V. Sanctus.m4a
DR15 -2.25 dB -22.95 dB 12 VI. Benedictus.m4a
DR12 -1.44 dB -18.16 dB 13 VII. Agnus Dei.m4a
DR12 -0.83 dB -16.91 dB 14 VIII. Communio.m4a
Number of files: 14
Official DR value: DR13
Versione coi files modificati
----------- ----------- ----------- ------------------------------- Wolfgang Amadeus Mozart - Requiem K626 - H von Karajan 1986 ----------- ----------- ----------- ------------------------------- DR Peak RMS File name ----------- ----------- ----------- ------------------------------- DR5 -0.00 dB -5.79 dB 01. I.Introitus - Requiem.flac DR5 -0.00 dB -5.99 dB 02. II.Kyrie.flac DR6 -0.00 dB -4.59 dB 03. III.Sequenz - Dies irae.flac DR7 -0.00 dB -8.15 dB 04. III.Sequenz - Tuba mirum.flac DR6 -0.00 dB -6.31 dB 05. III.Sequenz - Rex tremendae.flac DR6 -0.00 dB -7.36 dB 06. III.Sequenz - Recordare.flac DR5 -0.00 dB -8.42 dB 07. III.Sequenz - Confutatis.flac DR5 -0.00 dB -6.54 dB 08. III.Sequenz - Lacrimosa.flac DR6 -0.00 dB -5.88 dB 09. IV.Offertorium - Domine Jesu.flac DR5 -0.00 dB -6.64 dB 10. IV.Offertorium - Hostias.flac DR5 -0.00 dB -4.70 dB 11. V.Sanctus.flac DR5 -0.00 dB -6.95 dB 12. VI.Benedictus.flac DR5 -0.00 dB -7.20 dB 13. VII. Agnus Dei.flac DR5 -0.00 dB -5.80 dB 14. VIII.Communio - Luz aeterna.flac ----------- ----------- ----------- ------------------------------- Number of files: 14 Official DR value: 5 ----------- ----------- ----------- -------------------------------
Solo 5, manco un CD pop qualsiasi arriverebbe a tanto, eppure è una registrazione assolutamente ottima sotto tutti i punti di vista.
Quindi un DR basso non sempre è indice di registrazioni scarse o compresse
Ultima modifica di Barone Rosso il Ven 16 Dic 2011 - 18:56 - modificato 1 volta.
Barone Rosso- Moderatore
Re: [DR 13] Wolfgang Amadeus Mozart - Requiem K626 - H von Karajan 1986
Barone Rosso ha scritto:Quindi un DR basso non sempre è indice di registrazioni scarse o compresse
Già, ce l'ho quel CD ed è sublime da ascoltare. In effi però la dinamica non è mai eccezionale nelle registrazioni di Karajan, chissà perchè... Ma sicuramente dinamica non è sinonimo di qualità, o almeno non è condizione sufficiente.
In ogni caso posso dire che, avendo 4 versioni del Requiem del sommo compositore, che quello di DG by Karajan è quello che si sente peggio.
N.B.: se un DR < 8 può andar bene per il Pop, nella Classica è necessario un DR > 12. Ho più volte ribadito, infatti, che è necessario guardare la tabella che associa il genere musicale al valore DR ottenuto, questo per poter trarre le conclusioni corrette in base al risultato.
Silver Black- Amministratore
Numero di messaggi : 16700
Eccolo qua! Allora devo assolutamente sentire quello di Bohm!
morbo84- Affezionato
- Data d'iscrizione : 02.05.11
Numero di messaggi : 162
Provincia : Acqueo
Occupazione/Hobby : Informatica/Dormire
Impianto : KingRex Preamp - Trends Audio TA10.1 - Kef Coda 70.
Sono un grande amante del requiem e ne ho varie versioni.
Tra le altre anche quella di Karajan, che considero, concordando con Silver Black, sublime da ascoltare.
Ascoltandolo spesso (variando la versione di ascolto) sono rimasto quindi molto sorpreso al risultato di ieri sera, ma lavorando su di un mac non avevo modo di verificare un risultato che mi sembrava decisamente scorretto (ok non avere dinamica ma per un brano di musica classica/orchestrale/sinfonica bisogna quasi impegnarsi per arrivare a 5 ).
Stasera ho trovato finalmente il sw per fare la stessa analisi su mac e ....
Number of files: 14
Secondo me qualcosa e' andato storto nella tua analisi (nota che il peak e' sempre a 0) o hai avuto qualche problema in fase di conversione.
Il risultato mi ha molto confortato!!!
Number of files: 14
NaCl- Interessato
- Data d'iscrizione : 29.01.11
Numero di messaggi : 32
Impianto : MacBook Pro + Sennheiser HD 595
NaCl ha scritto:Sono un grande amante del requiem e ne ho varie versioni.
Infetti guardando bene qui file hanno qualcosa di strano.
Se mai prendo la tua misura come buona ... e ricontrollo.
Il Peak RMS non può essere 0, il valore DR è calcolato in base ad esso.
Silver Black ha scritto:Il Peak RMS non può essere 0, il valore DR è calcolato in base ad esso.
Puo essere a 0, ma è tipico dei dischi di musica Pop molto compressi.
Mi sa che quai files sono taroccati.
E visti con audacity ... hanno palesemente subito una manipolazione ....
Barone Rosso ha scritto:Silver Black ha scritto:Il Peak RMS non può essere 0, il valore DR è calcolato in base ad esso.
Certo, può essere ZERO, che è il valore più alto in assoluto, ma in musica classica è strano arrivarci... Come tu stesso sottolinei del resto.
Ma il test DR io lo farei esclusivamente solamente dalle tracce che io stesso estraggo, proprio a scopo di test, dal CD originale. Non mi fiderei di tracce scaricate (pure legalmente).
La modifica del titolo ha reso giustizia!
Dipende dai "canali di approvvigionamento". Diciamo che non devo aprire una custodi a per ascoltarmi il requiem.
NaCl- Interessato
NaCl ha scritto:La modifica del titolo ha reso giustizia!
Il mio è sicuro al 99.9% ... è la prima volta che vedo una roba del genere.
Ho appena fatto una cosa audio-pazza.
Ho provato a ricostruire le tracce giocando con matlab ....
Risultato DR11 sulla traccia 1 ... e suona pure bene
Fatto il lavoro di ricostruzione delle tracce, partendo da quelle danneggiate ... ed ecco il risultato
Devo dire che mi ha sorpreso pure a me
E si sentono pure pochi difetti.
Requiem | ||||
DR | Peak | RMS | Duration | File name |
DR11 | -2.50 dB | -20.06 dB | 5:24 | Herbert von Karajan - 01 - Introitus.flac |
DR11 | -2.50 dB | -20.58 dB | 2:40 | Herbert von Karajan - 02 - Kyrie.flac |
DR12 | -2.50 dB | -19.15 dB | 1:52 | Herbert von Karajan - 03 - Sequenz Dies irae.flac |
DR14 | -2.50 dB | -24.38 dB | 3:53 | Herbert von Karajan - 04 - Sequenz - Tuba mirum.flac |
DR12 | -2.50 dB | -20.58 dB | 2:20 | Herbert von Karajan - 05 - Sequenz - Rex tremendae.flac |
DR14 | -2.50 dB | -24.06 dB | 5:11 | Herbert von Karajan - 06 - Sequenz - Recordare.flac |
DR13 | -2.50 dB | -26.09 dB | 2:23 | Herbert von Karajan - 07 - Sequenz - Confutatis.flac |
DR11 | -2.50 dB | -20.40 dB | 3:10 | Herbert von Karajan - 08 - Sequenz Lacrimosa.flac |
DR14 | -2.50 dB | -23.12 dB | 3:50 | Herbert von Karajan - 09 - Offertorium - Domine.flac |
DR12 | -2.50 dB | -20.43 dB | 4:32 | Herbert von Karajan - 10 - Offertorium - Hostias.flac |
DR11 | -2.50 dB | -18.12 dB | 1:51 | Herbert von Karajan - 11 - Sanctus.flac |
DR15 | -2.50 dB | -24.12 dB | 5:28 | Herbert von Karajan - 12 - Benedictus.flac |
DR12 | -2.50 dB | -22.86 dB | 3:39 | Herbert von Karajan - 13 - Agnus Dei.flac |
DR13 | -2.50 dB | -21.02 dB | 5:50 | Herbert von Karajan - 14 - Communio.flac |
Number of files: 14 | ||||
Official DR value: DR12 | ||||
» Wolfgang Amadeus Mozart - Requiem K626 - Laudate Dominum - Exsultate Jubilate
» [DR 11] Wolfgang Amadeus Mozart - Requiem K.626 (1971 DG 477 8385) Wiener Philharmoniker, Karl Bohm
» W.A. Mozart - Requiem in D minor K. 626 (Herbert Von Karajan, 1975) SACD 2002
» [DR 13] Mozart Requiem - Staatskapelle Dresden, Peter Schreier
» Stamattina... Oggi pomeriggio... Stasera... Stanotte... (parte 11)
Oggi alle 13:44 Da Gabriele1
