I nuovi amp NVA - new look
+13
Pink Freud
furio
Richard Dunn
ITACA
RAMONE67
osservatore
17 partecipanti
Pagina 3 di 3
Pagina 3 di 3 • 1, 2, 3
Re: I nuovi amp NVA - new look
[quote="RAMONE67"]
What question about CE mark?
Richard Dunn ha scritto:To the question about the CE marking, altough, as I guess you've already red, I'm not seriuosly concerned about it. I'm still talking about it because of some flaming posts.RAMONE67 ha scritto:schwantz34 ha scritto: Peccato che mr. Dunn non abbia ancora fornito uno straccio di risposta.
To what !?!?
Richard Dunn- Operatore Hi-Fi DIY Expert
- Data d'iscrizione : 20.12.10
Numero di messaggi : 48
Impianto : NVA system
[quote="Richard Dunn"]
Just take a look at the last but one post at pag. 2 (but to the last one too). Anyway, I say it again: I don't give a damn about the point. I just posted my visual impression.RAMONE67 ha scritto:Richard Dunn ha scritto:To the question about the CE marking, altough, as I guess you've already red, I'm not seriuosly concerned about it. I'm still talking about it because of some flaming posts.RAMONE67 ha scritto:
To what !?!?
Numero di messaggi : 1270
[quote="RAMONE67"]
I still don't understand the question. Are you trying to say my equipment is made in China (remember I am relying on google translate, which for one of your posts translated that I had electrocuted people).
Richard Dunn ha scritto:Just take a look at the last but one post at pag. 2 (but to the last one too). Anyway, I say it again: I don't give a damn about the point. I just posted my visual impression.RAMONE67 ha scritto:Richard Dunn ha scritto:To the question about the CE marking, altough, as I guess you've already red, I'm not seriuosly concerned about it. I'm still talking about it because of some flaming posts.
I just wrote that in the pictures posted by Schwants34 "CE" logo SEEM (not IS) to be the "china export" mark and not the european one, since the two letters appear too close each other. Only that and nothing more. There's no critical point to understand and to argue about.RAMONE67 ha scritto:Richard Dunn ha scritto:Just take a look at the last but one post at pag. 2 (but to the last one too). Anyway, I say it again: I don't give a damn about the point. I just posted my visual impression.RAMONE67 ha scritto:
It turns out you are correct and is a bad mistake by our silk screeners. Thank you for pointing it out to me.
Thanks for your clarification Mr. Dunn. Best regards.Richard Dunn ha scritto:It turns out you are correct and is a bad mistake by our silk screeners. Thank you for pointing it out to me.
anche la vodafone ha fatto un errore come questo.
quando vieni individuato sono solo 2.500 euro di multa ogni marcatura ce errata .
Numero di messaggi : 14434
RAMONE67 ha scritto:Thanks for your clarification Mr. Dunn. Best regards.Richard Dunn ha scritto:It turns out you are correct and is a bad mistake by our silk screeners. Thank you for pointing it out to me.
You must have very good eyes, it is one mm too close.
Well, not so good, 'cause I thought two letters were even closerRichard Dunn ha scritto:RAMONE67 ha scritto:Thanks for your clarification Mr. Dunn. Best regards.Richard Dunn ha scritto:It turns out you are correct and is a bad mistake by our silk screeners. Thank you for pointing it out to me.
Per chi fosse interessato a sapere qualcosa sulla qualità degli apparecchi NVA:
è da diverso tempo ormai che nel mio impianto principale uso una coppia di finali A80 + pre passivo P50sa + relativi cavi NVA, sia di segnale, sia di potenza, e del tutto sono sinceramente più che soddisfatto.
Che siano assolutamente "minimalisti" è fuor di dubbio: il pre passivo (circa 300 sterline) se guardato al suo interno lascia abbastanza perplessi in rapporto al suo costa, ma tant'è ...
Per Sergio: se ho ben capito, hai provato a pilotare i tuoi finali con pre attivi? ma è possibile farlo o si rischia di far "esplodere" tutto? Te lo chiedo perché, secondo me, i finali A80 avrebbero bisogno di un segnale con un po' più di guadgno in entrata, pena l'esser costretti, con alcune registrazioni, a portare il potenziometro del volume praticamente al massimo e di conseguenza quasi senza alcuna possibilità di regolazione. Eppure le mie casse sono abbastanza efficienti: 90db.
Lo stesso pre, collegato ad un finale con Sure TK2050, sembra invece guadagnare eccessivamente.
Usando l'uscita diretta del pre e regolando il volume dal lettore, la "potenza" sonora degli A80 è notevole.
cestma- Membro classe bronzo
Numero di messaggi : 1125
Provincia : Napoli (Sorrento)
Transport: - iFi ILink
Ciao Cesare, esplodere tutto no...io li ho attaccati per 1 minuto a due pre attivi, suono loffio...non mi convinceva, invece non lamento il discorso del segnale debole...non m'e' mai capitato, sinceramente, a proposito ...ho comprato mesi fa, usati, il pre phono col suo bell'alimentatore, phono 2 , gran bel suono, veramente, ottima sinergia col resto delle bb,
Cesare, hai visto qui?
http://www.pinkfishmedia.net/forum/showthread.php?t=111692
Richard Dunn ha scritto:furio ha scritto:Hi Richard,
nice to see you here...
I made a question to local friends about your suggestion to use passive pre-amplifiers.
Can you tell me something more or suggest some other internet pages where you talked about that?
Many thanks!
Try www.nene-valley-audio.com which is an archive website, or just do google search.
EDIT - it seems that one is down, try this - http://nva.sclnz.com/
Website OK now, virus removed.
Only the CE mark on the new amp was slightly out in dimension, all other amps OK. Artworks altered at screen printer, and thank you for those that noticed the problem and told me.
Richard
Richard
Sorry, Richard.
Just tried to have a look on nene-valley.
On home page my avast antivirus still reports a trojan (js:Redirector-NJ [Trj]).
But just trying to surf on single items (using menu on the left) everything runs.
Best regards
furio- Membro di riguardo
- Data d'iscrizione : 22.10.11
Numero di messaggi : 662
Provincia : TO
Occupazione/Hobby : Ateo praticante / rockettaro impenitente
Impianto : HTPC, Oppo BDP-105, Thorens TD 145MK11,
braccio Grace, pick-up Fideliry Research FR-1 MKII;
Pre monotriodo, finale con Hypex NC400;
Denon AVR3808; Casse tre vie autocostruite
Riapro l'argomento perché sarei veramente interessato a sapere qualche cosa in più sul suono degli ampli NVA...ne sento parlare fin dagli anni 90 ma non ho mai avuto la fortuna di ascoltarli. Nella mia città natale un tipo li aveva con delle Quad esl63 e poi (per questioni di waf) con delle Monitor Audio Studio 20 e ne diceva meraviglie...Mi interesserebbe sapere com'è il comportamento "in basso", il punch è discreto? La pienezza c'è? o sono esilini?
Purtroppo per il momento devo lasciar perdere un progetto troppo ambizioso ma avrei comunque intenzione di far progredire l'impianto
Numero di messaggi : 1263
Provincia : .
Occupazione/Hobby : .
per quello che riguarda il punch, l'ap70 in mio possesso ne ha eccome, spinge molto bene tanto e' che non lo ho messo alla corda. Mantiene un carattere chiaro e aperto ma ugualmente autorevole in basso.
spero di esserti stato utile.
saluti
luca
saluti
luca
gianluca sassu- Appassionato
Numero di messaggi : 450
Provincia : allegro ma un po' inquieto
Occupazione/Hobby : operaio/ andare ai concerti
Impianto : ampli mhz classed mcd 255,exposure 2010s2,diffusori B&W cdm7 se, , cerwin vega xls215, marantz cd5000,dynavoice challenger m-65 ex, leonardo audio at-200, sony cdp 227esd,marantz cd60,esb 40ld.
gianluca sassu ha scritto:per quello che riguarda il punch, l'ap70 in mio possesso ne ha eccome, spinge molto bene tanto e' che non lo ho messo alla corda. Mantiene un carattere chiaro e aperto ma ugualmente autorevole in basso.
saluti
luca
Grazie, hai magari qualche confronto da fare?...per "spingere" intendi volume o sensazione di pienezza in basso? c'è aggressività sul medio-alto?
Provincia : .
Hi Mr. Dunn, nice to read u here.
What truly matters is to have very good ears
But that's far rarer.
And sooner or later i gotta try a NVA amp, they keep popping into my head every 2-3 months
Telstar- Membro classe bronzo
Numero di messaggi : 1717
» Nuovi diffusori ,Nuovi dubbi...
» Nuovi DAC
» nuovi (?) S.M.S.L SA-S1 e SA-S3
» nuovi fw
» [PN] Trasformatori a 5 € nuovi
» Nuovi DAC
» nuovi fw
Pagina 3 di 3
Oggi alle 2:33 pm Da AndreaCD
Oggi alle 2:21 pm Da handros
Oggi alle 9:43 am Da Fabiolydia
Oggi alle 8:11 am Da Quaiozi!
Oggi alle 5:05 am Da AndreaCD
Oggi alle 1:03 am Da Gabriele1
Ieri alle 10:38 pm Da valterneri
Ieri alle 8:05 pm Da arthur dent
Ieri alle 4:55 pm Da Marco Ravich
Ieri alle 11:59 am Da rinorho
Mer Nov 20, 2024 10:45 pm Da handros
Mer Nov 20, 2024 10:42 pm Da handros
Mer Nov 20, 2024 9:38 pm Da Fabietto68+
Mer Nov 20, 2024 7:08 pm Da giucam61
Mar Nov 19, 2024 7:12 pm Da morgana90
Mar Nov 19, 2024 9:19 am Da Quaiozi!
Mar Nov 19, 2024 8:53 am Da Marco Ravich
Lun Nov 18, 2024 8:44 pm Da Darios8
Lun Nov 18, 2024 8:41 pm Da Darios8
Lun Nov 18, 2024 8:39 pm Da Darios8
Lun Nov 18, 2024 8:38 pm Da Darios8
Lun Nov 18, 2024 8:37 pm Da Darios8
Lun Nov 18, 2024 3:22 pm Da fritznet
Lun Nov 18, 2024 2:43 pm Da fritznet
Lun Nov 18, 2024 12:09 pm Da Quaiozi!
Lun Nov 18, 2024 9:13 am Da amineruu
Dom Nov 17, 2024 12:32 pm Da mauretto
Dom Nov 17, 2024 9:40 am Da Zio
Sab Nov 16, 2024 6:43 pm Da arthur dent
Sab Nov 16, 2024 4:55 pm Da fritznet
