12AX7A vs 12AX7
12AX7A vs 12AX7
Salve,
ho notato che negli USA si trovano più valvole 12AX7A che 12AX7, chiedevo
se ci fosse molta differenza tra le due, anche in termini di ascolto.
ugoloso- Novizio
- Data d'iscrizione : 15.02.12
Numero di messaggi : 6
Impianto : da farsi
Re: 12AX7A vs 12AX7
ugoloso ha scritto:Salve,
Trovato in rete:
12AX7: the original version of this tube, released in 1947. This can only be used in parallel filament circuits. This is not a big deal as virtually all audio equipment is of a parallel filament design. In other words, these will work fine in a Marshall.
12AX7A: This version can be used in series or parallel filament circuits. These usually date to the 1960s and have gray or black plates. Vintage versions of these are about the most sought after tubes of any type today. Sometimes, 12AX7A tubes made for the US Military are labeled 12AX7WA. DO NOT confuse these with current production Sovtek or Chinese crap with the suffix WX, WB, or WC! These are not military tubes and are not NOS tubes at all.
Also, as tube manufacturing became refined, the 12AX7A became much quieter. So much in fact that a lot of 12AX7A's were labeled 7025's (a very quiet version of the 12AX7).
So the bottom line is that you can use either of these tubes in your Marshall amp. It's just that an NOS 12AX7A tube is considered to be premium over the 12AX7.
pilovis- Membro di riguardo
- Data d'iscrizione : 28.12.11
Numero di messaggi : 547
Provincia : Valvolare
Occupazione/Hobby : System Administrator (Windows, Linux, Unix, Mac OSx)
Impianto : Valvolare classe A utralineare con 2 x 807 (Zaerix Ldt. London anno 1970) e 2 x 6G6G pentodi audio (National Union Mil. USA anno 1944) come driver, 1 x 5X4 (RCA anno 1953) raddrizzatrice. Progetto personale
Valvolare classe A utralineare con 2 x 6L6G (Fivre ano 1956) finali e 1 x 6N2P (USSR mil. anno 1990) driver, progetto personale.
Valvolare classe A con 2 x PL504 e 2 x ECC82 driver (cathode follower), progetto personale.
Valvolare classe A pseudotriodo con 2 x ECL86, progetto personale.
In costruzione:
Push-Pull mono 10W per chitarra con 2 x PL504 e 2 x 6N2P drivers
diretto sostituto o no
Grazie Pilo,
ottima dritta, ma quello he mi servirebbe anche sapere,
è se le 12AX7A sono un diretto sostituto delle 12AX7.
Buona domenica.
Buona domenica.
ugoloso- Novizio
Impianto : da farsi
Re: 12AX7A vs 12AX7
direi proprio di si.
In costruzione:
Re: 12AX7A vs 12AX7
si,sono uguali
Albert^ONE- Membro classe oro
Numero di messaggi : 6417
Re: 12AX7A vs 12AX7
Albert^ONE ha scritto:si,sono uguali
Grazie ancora a tutti
ugoloso- Novizio
Impianto : da farsi
» e80cc al posto delle 12ax7 ?
» 12AX7 lampo
» ECC83 - 12AX7
» Consiglio: quali 12AX7 ?
» pre-ampli mu-fullower ECC88/6N1
» 12AX7 lampo
» ECC83 - 12AX7
Ieri alle 19:22 Da mrcpal91
Ieri alle 17:37 Da ste-65
Ieri alle 8:51 Da Fabiolydia
