[Vendo Scambio] VdH MAGNUM 2.5m coppia - 80€
Come da titolo vendo questo fantastico cavo!
80 euro più sped.
Non terminato. Ecco un po' di info.
This very attractive dark-red coloured mat finished twin-lead speaker cable is designed to produce the best transfer quality at an affordable price.
Each lead consists of 483 x 0.15 mm. high purity Matched Crystal (MC) OFC strands with a dense and very pure silver coating.
The resistance per lead is just: 0.21 Ohm/100 meter.
The metal cross-section area for each conductor is: 8.54 mm², equalling AWG 8.
The capacitance between the 2 leads is a nice and low 27 pF/meter.
Covering the 2 conductors you will find an extra Linear Structured Carbon ® saturated layer.
This layer dramatically improves the sonic qualities of The MAGNUM HYBRID.
The cable jacket is made of our HULLIFLEX ® 5, a very flexible and mechanically superb insulation material.
The plus and minus leads are different in jacket shape with gold coloured printing in the flat middle-section. Both properties are easy polarity finders.
Type printing at 25 cm. (10") distance makes cutting of specified lengths very easy.
Packing conditions: 50 meters per reel in a 310 x 310 x 290 mm. box with a total shipping weight of 14.7 kg.
Cable Type: Twin conductor
Conductor Material: HYBRID: High purity dense Silver coated high purity Matched Crystal OFC + Linear Structured Carbon ® saturated layer(s)
Design Purpose/
Application Area(s): Loudspeaker cable
Eff. Conductor Ø/Eq. AWG No./Strands: 2x(8.54 mm² / ~AWG 8 / 483)
External Diameter /
-Dimensions: 27.0 mm. wide; 7.5 mm. thick
Resistance 20 °C / 68 °F: 0.21 Ohm/100 m.
Capacitance: 27 pF/m.
Insulation / Dielectric Strength / Test Voltage: HULLIFLEX ® 5 / 300 Vrms min.
Connector Types Suitable: Our 6.5 mm. Ø cable entrance diameter Bus type Universal Speaker Connectors or our 8.3 mm. Ø cable entrance diameter BERRI Bus Connectors; Custom mountable on ordered lengths.
Standard Sales Units / -Lengths: 50 m. reels; With connectors mounted to specifications: any length; Without connectors: please consult your van den Hul dealer or the van den Hul distributor in your country.
Jacket Colours Available: Dark-red
Remarks: Self mounting of connectors is not advised since special soldering equipment is required; Our custom connector mounting service is available.
80 euro più sped.
Design Purpose/
External Diameter /
ciobeddu- Affezionato
- Data d'iscrizione : 12.10.10
Numero di messaggi : 155
Impianto : under costruction
Re: [Vendo Scambio] VdH MAGNUM 2.5m coppia - 80€
In coda. Dove li hai comprati?
SaNdMaN- Membro classe oro
Numero di messaggi : 5972
Trasporto: M2Tech HiFace Two
Vengono
Dalla Germania. Non sono tarocchi.. Garantisco.
ciobeddu ha scritto:Vengono
Comprati da?
Un privato. Mio zio è crucco e me li ha fatti avere.
ok, grazie x l'info. Lascio la coda.
Scusa ma non capisco il problema? Chiedo troppo poco per un cavo che costa 50€ a metro? Se lo vuoi pagare di più io li prendo. Mi sembra invece una cifra onesta allineata a quello che è il mercato. Per il resto lasciamo spazio a chi è interessato veramente..
ciobeddu ha scritto:Scusa ma non capisco il problema? Chiedo troppo poco per un cavo che costa 50€ a metro? Se lo vuoi pagare di più io li prendo. Mi sembra invece una cifra onesta allineata a quello che è il mercato. Per il resto lasciamo spazio a chi è interessato veramente..
Infatti ho lasciato la coda
Coda x info e mp!
Smigol- Appassionato
- Data d'iscrizione : 15.05.10
Numero di messaggi : 453
» [VENDO] Coppia di Scanspeak D3806 150 euro + coppia tewwter Scanspeak D2010 50 euro + s.s.
» Vendo o scambio materiale [RM]
» [Vendo Scambio] amplicuffia - 120€/80€
» Vendo (o scambio) Klipsch Heresy HIP-2
» Vendo /scambio kit punte 15 euro
Oggi alle 7:50 Da Fabiolydia
