Diffusori ATC
Diffusori ATC
Girovagando in cerca di informazione sulle ATC, ho trovato questo brano redatto dalla ATC stessa, argomento bass reflex vs casse chiuse.
Mi sembra interessante e un pò controcorrente. A me sembra sensato..
A port can be used to extend bass response to lower frequencies by being tuned lower than the driver/box resonance. This is the way most ports are used in the majority of consumer home audio speakers. ATC are using ports in the same way as is used in pro audio at concerts - to gain efficiency. There is a huge difference in the two approaches.
The consumer home speaker approach allows a smaller cheap woofer in a small cheap box to produce LF more cost effectively than if done properly. This generally results in poorer quality bass but can still sound good if done well. The deficiencies in this design usually show up in high levels of distortion in the bass at elevated SPL.
ATC are using the port to allow them to use a more expensive driver in a given box. High quality drivers will have higher damping (Qts) due to large motor and high flux. This allows the port to be used to gain efficiency and still remain critically damped (better transient response). These designs can be well behaved and remain relatively low in distortion even at high SPL.
Basically, if you are talking high fidelity (low distortion) then the ONLY place you should see ported speakers is when they become large. There really isn't a good high fidelity reason to add ports to a small size speaker - all it does is increase distortion at the same time as it gains you greater bass extension. The issue is that below the port tuning you basically have the woofer in an infinite baffle (no box) and the woofer has absolutely no air damping. This means uncontrolled woofer excursion and very high distortion. So ATC simply follow good engineering practice or principles for highest fidelity.
The three options or applications of a ported speaker are as follows (source Colin Miller):
1. A system of 3 dB greater efficiency without sacrificing extension, defined by the -3dB point, or cabinet size. It doesn't make the driver more efficient, but it extends the bandwidth of a more efficient, over-damped driver (bigger magnet, lower Qes). (THIS IS WHAT ATC DO)
2. A decrease in cabinet size by 50% without sacrificing extension, again defined by the -3dB point, or efficiency.(THIS IS WHAT MOST HOME HI-FI SPEAKER MANUFACTURERS DO FOR THEIR TALL NARROW FLOORSTANDING SPEAKERS
3. An increase of low frequency extension by 1/3 of an octave, sometimes more, depending on the compared sealed alignment, while maintaining the same efficiency level or cabinet size. (THIS IS WHAT MOST HOME HI-FI SPEAKER MANUFACTURERS DO FOR SMALL BOX SPEAKERS OR MONITORS)
The cost of an expensive woofer versus a cheap woofer is significant in the price of a speaker. $50 for a cheap woofer versus $300+ for a good woofer. Ultimately this can be $1,000s in difference in retail price point. Ports are mere plastic tubes and cost 50 cents, additional glue and a router cut in the baffle. Basically a port is used to reduce cost of the woofer/speaker system EXCEPT in example 1 above where it actually increases the cost by enabling the use of more expensive higher power bigger magnet driver.
Vella- Membro classe argento
Numero di messaggi : 3992
Re: Diffusori ATC
a me interessano particolarmente le scm35...comunque atc fa anche degli amp per usare le proprie casse in mod.passiva.
Come vanno le tue scm 11?
Re: Diffusori ATC
Io ho sentito le 40 con un ampli ATC
Mi sono piaciute assai. Il tutto stava sui 7000 Euro.
Numero di messaggi : 1015
Provincia : easy
Impianto : Bushmaster MKII
tpa3116
cavi
Neat Motive 2
Re: Diffusori ATC
thepescator ha scritto:Io ho sentito le 40 con un ampli ATC
atz!!! beh mica poco... le 35 e le 40 non dovrebbero essere tanto dissimili...poi parlano muy bien del tweeter delle 35 e pare che abbiano dei bassi superlativi...so che c'e' un signore che usa degli a80 per amplificarle ed è particolarmente entusiasta dell'accoppiata...
Re: Diffusori ATC
schwantz34 ha scritto:a me interessano particolarmente le scm35...comunque atc fa anche degli amp per usare le proprie casse in mod.passiva.
E' un pò presto per dirlo, non vorrei entusiasmarmi troppo per la novità; le ho ascoltate poco e sono ancora da rodare per bene, tenuto conto che ho letto in giro che ne hanno bisogno particolarmente le ATC.
Però che dettagli senza essere tirate in alto!!!!
In particolare con il pianoforte, un decay bellissimo. Con Fever, della Chesky Records a 96/24, le differenze di intensità degli accordi erano chiaramente distinguibili, e anche i colpi di rullante di Dennis Chambers su Sweat di Gary Willis avevano ognuno la loro sfumatura dinamica. Si sente che hanno un dna da studio di registrazione.
Ieri sera con un sax su un disco di Patricia Barber era lampante come la timbrica dello strumento fosse diversa a seconda della nota suonata: le note più basse avevano un sapore e una grana diversi da quelle più acute. Ti ridanno tutto quello che c'è registrato, zero colorazioni.
Per ora riscontro anche quello letto in giro: a volume basso notturno perdono qualcosa, si siedono un pò. E tutte quelle informazioni timbriche/dinamiche possono farti perdere un filo di fluidità. Ma sono abituato alle Spendor, che ne hanno fin troppa.
Vediamo come va quando si saranno sciolte a dovere. Ma la scelta di quali tenere lo so già che sarà una sofferenza!!!
Re: Diffusori ATC
milionari!
mauz- Membro classe argento
Numero di messaggi : 3404
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
Re: Diffusori ATC
mauz ha scritto:milionari!
Di più, miliardari!!!!!
Sempre robba usata, che poi se rivende, roba da poareti purtroppo...
» Diffusori per HK
» Domandina rapida rapida....
» Denon PMA-520AE
» Diffusori per HK
» Denon PMA-520AE
