JAVS X-DDC...Xmos usb
JAVS X-DDC...Xmos usb Empty JAVS X-DDC...Xmos usb
Messaggio Da kurt10 Mer 5 Set 2012 - 13:14
http://www.ebay.it/itm/JAVS-X-DDC-PC-Hi-Fi-Audio-Processor-DDC-24bit-192KHz-USB-2-0-/251024888611?pt=US_Home_Audio_Amplifiers_Preamps&hash=item3a723fd323
http://www.ne.jp/asahi/gonzaemon/audio/img/X-DDC-7.jpg
Britain's X-MOS company's X-CORE MICROPROCESSOR using
Supports the USB AUDIO CLASS 2.0 specification asynchronous mode.
16/24bit 44.1, 48, 88.2, 96, 176.4, 192KHz frequency support
ULTRA-LOW JITTER TCXO ± PPM CLOCK
Current status and playback frequency denoted front GRAPHIC LCM
JAVS only provide Windows OS installed driver and MAC OS X, Linux Kernel automatic support
At the Windows driver ASIO 2.2, S / PDIF PASSTHRU (DD / DTS), a digital capture (radiophonics recording) feature support
OPTICAL, COAXIAL, I2S (HDMI) 24bit/192KHz OUTPUT
24K GOLD 4-layers board and 1% resistor layer and the OS-CON capacitors using such advanced components.
USB bus power can be operated and support the separate external adapter (12V 1A) in connection support.
kurt10
kurt10
Data d'iscrizione : 07.04.08
Numero di messaggi : 1625
JAVS X-DDC...Xmos usb Empty Re: JAVS X-DDC...Xmos usb
Messaggio Da donluca Mer 5 Set 2012 - 13:40
Mi sembra un prodotto di tutto rispetto ma... quant'è il prezzo della XMOS?
Data d'iscrizione : 07.11.11
Numero di messaggi : 3782
