Forse non tutti sanno che...
Forse non tutti sanno che... Empty Forse non tutti sanno che...
Messaggio Da Marco Ravich Mer 24 Ott 2012 - 11:32
...molti (tutti ?) alimentatori switching possono funzionare anche con corrente continua !
Al meeting marchigiano alcuni partecipanti discutevano del problema di alcuni amplificatori integrati (ICEpower, ad esempio) a cui non si può applicare l'alimentazione lineare.
Ebbene, in realtà sembrerebbe possibile mettere un'alimentatole lineare - di adeguate caratteristiche, ovviamente - a monte dell'SMPS.
Certo non è detto che questo influisca poi sulla qualità del suono, ma qualcuno ha mai fatto prove in al senso ?
Per gli scettici, da questo sito:
How an SMPS works
Input rectifier stage
If the SMPS has an AC input, then its first job is to convert the input to DC. This is called rectification. The rectifier circuit can be configured as a voltage doubler by the addition of a switch operated either manually or automatically (this is a feature of larger supplies to permit operation from (nominally 120 volt or 240 volt supplies). The rectifier produces an unregulated DC voltage which is then sent to a large filter capacitor. The current drawn from the mains supply by this rectifier circuit occurs in short pulses around the AC voltage peaks. These pulses have significant high frequency energy which reduces the power factor. Special control techniques can be employed by the following SMPS to force the average input current to follow the sinusoidal shape of the AC input voltage thus the designer should try correcting the power factor. A SMPS with a DC input does not require this stage. A SMPS designed for AC input can often be run from a DC supply, as the DC passes through the rectifier stage unchanged. (The user should check the manual before trying this, though most supplies are quite capable of such operation even though no clue is provided in the manual!)
Data d'iscrizione : 20.04.09
Numero di messaggi : 6070
Provincia : MC
https://www.forart.it/
Forse non tutti sanno che... Empty Re: Forse non tutti sanno che...
Messaggio Da Stentor Mer 24 Ott 2012 - 11:34
Marco Ravich ha scritto:...molti (tutti ?) alimentatori switching possono funzionare anche con corrente continua !
How an SMPS works
Il dubbio è proprio quello se serva o meno a livello sonico....
Per gli icepower poi il loro bello, a livello di costi, è che hanno tutto integrato Very Happy
