Focusrite Scarlett 2i2: buon DAC a basso costo ?
Cercando info su questa scheda per un mio amico musicista, ho trovato questa interessante recensione di fine 2012:
http://www.hifizine.com/2012/12/focusrite-scarlett-2i2/
...qualcuno conosce/ha sentito la scheda in oggetto ???
EDIT dimenticavo le specifiche tecniche
http://global.focusrite.com/usb-audio-interfaces/scarlett-2i2/specifications
John Reekie ha scritto:There is a minor concern with the low-level digital noise on the outputs, but this is not uncommon for inexpensive bus-powered devices and in any practical application that doesn’t involve actually looking for a problem, it’s still within the noise specification. To me, the 96 kHz option, the technical results, the simple and straightforward interface, the ease of getting up and running on both Windows and Mac, the future-proofing you get with a USB class 2 device, and the very reasonable price, make the 2i2 well worthy of consideration for those looking for an easy-to-use interface for their measurement setup.
- A-D Dynamic Range 105dB 'A-weighted' (all inputs). Converter chipset A-D dynamic range 114dB
- D-A Dynamic Range 104dB 'A-weighted' (all outputs). Converter chipset D-A dynamic range 114dB
- Supported sample rates 44.1 KHz, 48 KHz, 88.2 KHz, 96 KHz
» [FOCUSRITE SCARLETT] Scarlett MixControl 1.9b4
» [FOCUSRITE SCARLETT] Nuovi driver 1.9b2: finalmente WASAPI @ 24 bit !!!
» Focusrite Scarlett 2i2 90€
» [FOCUSRITE SCARLETT] USB2 Driver 3.1.10
» DAC Modi o Focusrite (Scarlett, Itrack)
Oggi alle 13:44 Da Gabriele1
Oggi alle 9:45 Da marco123
Oggi alle 9:19 Da Fabiolydia
Oggi alle 1:33 Da Gregh
