[venduto] Scheda audio pro MOTU Ultralite (10 in / 14 out) - 270 euro
Vendo fantastica scheda audio firewire (no usb) Motu Ultralite. Ottima anche come dac e mixer standalone senza l'uso del computer. Tantissime connessioni: bilanciate, sbilanciate, spdif... Suono preciso e dettagliato!
Unico proprietario, scatola, manuale e cd originali.
Vendo a 270 euro + spedizione
Priorità ritiro a mano
Spedisco con corriere (consegna 24/48h)
Specifiche:
Bus-powered FireWire computer interface
Sturdy lightweight construction
Compact size (8.5"W x 7"D)
24-bit/96kHz audio quality
Discrete I/O
10 inputs with 2 mic preamps
14 outputs including separate mains
Sample-accurate MIDI I/O
TRS main outs
Front-panel headphone jack
Stereo 24-bit 96kHz S/PDIF in/out
Front panel LCD metering
Individual 48V phantom power on preamp inputs
CueMix DSP™ near-zero monitoring and mixing system
Support for multiple CueMix DSP mixes
Front-panel mix control
Stand-alone operation
3-way preamp pad switch (0, 18 & 36dB)
24dB of adjustable trim (in 1dB increments; 60dB gain range)
18dB of gain for TRS inputs
SMPTE sync and striping via any analog input/output.
Includes drivers for Mac & PC, including ASIO, WDM, Wave, GSIF, Core Audio, and Core MIDI
Supports all popular Macintosh and PC audio software
Compatible with all host-based effects processing
Includes AudioDesk recording/sequencing software for Mac
2 FireWire ports
Plug-and-play operation
Includes power supply for stand-alone operation
Qualche recensione:
http://www.musicradar.com/reviews/tech/motu-ultralite-23657
http://www.zzounds.com/productreview--MTUULTRALITE
http://www.musiciansfriend.com/pro-audio/motu-ultralite-firewire-audio-interface
Specifiche:
Discrete I/O
TRS main outs
2 FireWire ports
Qualche recensione:
Numero di messaggi : 1502
Provincia : Padova
Sorgenti: Asus EEEPC
Dac: Micromega Mydac
Pre: Pass B1 Buffer
Finali: Pass Mini Aleph
Cavi:
usb: Wireworld Ultraviolet
segnale: JPS clone
potenza: Audioquest FLX 14.4
alim: Elecaudio CS-331B
VENDUTO
Venduto altrove!
Chiedo scusa per essermi dimenticato di specificare che era in vendita anche su altri siti.
Provincia : Padova
Pre: Pass B1 Buffer
Cavi:
segnale: JPS clone
» [VENDUTO] Scheda Audio - ESI Maya44 PCI - 50 euro
» [Vendo] Scheda audio USB Tascam US-144 - 100€ + ss
» [VENDUTO] [Go+Sped]Asus Xonar STX con scheda audio 115 euro
» [VENDUTO] scheda audio Echo Audiofire 2 [AN] - € 110
» [VENDUTO] scheda SURE TA2024 euro 25+spedizione
