Kama Bay 35-2000; ohm
Re: Kama Bay 35-2000; ohm
Allora, per quanti avessero lo stesso dubbio in futuro e dovessero finire su questo thread, segnalo che ho interpellato direttamente la Scythe; mi hanno risposto di cercare solo diffusori a 8 ohm, in quanto con gli altri ci potrebbero essere danneggiamenti; riporto il testo integrale della risposta:
"I recommend you to buy 8 Ohm speakers. I would say there is a very good chance that it will work properly, but there is also a small chance that the speakers / amp will be damaged. The speakers are 4 ohms so it will give the amp higher stress than 8 ohms speakers as you need double the power to drive a 4 ohms Compared to an 8 ohms speakers. It might make the amp halt at half volume or earlier. I cannot be clear since some speakers goes as low as 2 ohms although they are rated 4. This is because they rate the speakers on average impedance, but impedance is not always the same value from the point of frequency. As in a 200Hz signal to the speaker may be 4 ohms, but a 80Hz signal to the speaker could be 2 ohms. This depends on the speaker’s characteristics called impedance curve. The halt of the amp itself will not damage the gears, but when an Amplifier is in stress, there is a chance that the amplifier will output Distorted signals that may damage the amp and / or the speakers. The chances are low but there still is.
__________________
English & German Support"
CLipper
__________________
CLipper
clipper- Appassionato
- Data d'iscrizione : 10.03.11
Numero di messaggi : 265
Provincia : parma
Impianto : Sintoampli Marantz + Casse Bose - Scythe Kama Bay 35-2000 + Scythe Kro Craft - Cuffie: Sennheiser HD569, Superlux HD681 evo, Superlux HD668b, Sennheiser PX100, KZ ED16, Sennheiser CX300, Tennmak Dulcimer, Liam & Daan Swan - Dap: iBasso DX150, Cayin N3, Ruizu A50, Sansa Clip+.
In pratica alla Scythe hanno letto la risposta che ti aveva dato emmeci e l'hanno tradotta in inglese!!
Zio- Membro classe argento
Numero di messaggi : 4009
Provincia : Emilia
CLipper
Provincia : parma
» fischio kama bay 2000
» Scythe Kama Bay SDAR-2000
» Impedenza ScyThe Kama Bay AMP 2000
» Scelta diffusori per Scythe Kama Bay Amp 2000
» Sansui AU117 vs Scythe Kama Bay 2000
Oggi alle 21:26 Da lello64
Oggi alle 21:15 Da marco123
Oggi alle 18:07 Da ste-65
