Sonance Sonamp 275 SE Consigli Tecnici
Ho preso d'occasione questo finale dotato anche di modulo BBe SAT e vi volevo chiedere qualche consiglio
QUì trovate il datasheet
e QUì invece il manuale.
Sul retro dell'ampli ci sono oltre all'ingresso RCA anche un uscita RCA descritta nel manuale in questo modo :
The BBE SAT module included with the 275 SE/ 275X3 SE includes buffered R and L RCA output jacks. These can link additional power amplifiers to a single source component without using messy Y-cord adaptors. Note: The buffered output signal is not BBE-processed.
dalle immagini sul manuale si vede che viene usata per collegare degli ampli in cascata ( la Sonance è molto aprrezzata in impianti audio multiroom con diffusori da incasso ).
Volevo sapere se era possibile collegare a questa uscita rca un subwoofer attivo.
Inoltre a pagina 6 del manuale è dedicato un paragrafo ad un Hi-pass filter situato sempre sul modulo BBE
che riporto:
The 275 SE and 275X3 SE have high-pass filters located on the BBE SAT Module circuit board.The filter settings are determined by the positions ofa pair of shorting sleeves on jumper pins. IMPORTANT: The high-pass filter jumpers are set at the factory in the high-pass filter ON position. Sonance HIGHLY RECOMMENDS that these jumpers remain in the ON position if the amplifier will be used in a system that includes in-wall volume controls for the speakers. The amplifier’s high-pass filters reduce infrasonic energy and help protect autoformerbased volume controls from saturation and overload. To bypass the high-pass filters,set the jumpers to the OFF position: 1.The jumper pins are located in the marked area of the BBE SAT module circuit board,as shown in the upper portion of Figure 4. 2.As shown in the lower portion of Figure 4,remove the shorting sleeves from their factory-set (ON) position on the jumper pins and replace them in the OFF positions. Make sure you insert the shorting sleeves all the way onto the jumper pins.
Da quanto ho capito e letto questo filtro ( -3db a 27Hz ) attivo di default, e, disattivabile spostando dei jumper sul modulo e serve proteggere i controlli di volume dei diffusori d incasso.
Utilizzando io dei diffusori normali dite che posso disattivarlo?
che riporto:
talbain- Interessato
- Data d'iscrizione : 12.10.13
Numero di messaggi : 50
Provincia : Benevento
Impianto : Impianto 5.1 per Home Theather, Videogames, etc etc. + Impianto ascolti musicali
Sorgente Analogica : Giradischi McCrypt DJ-U3565 B DJ-/USB
Sorgente digitale : Raspberry PI 3 + Hifiberry Digi+ pro + AUDIOPHONICS LPSU25 Linear
Sorgente digitale : Lettore BD Samsung BD-H6500
Meccanica CD : Lettore DVD Sunstech DVP X-505
Dac : Xiang Sheng DA-03A
Sinto AV : Yamaha RX-V767
Preamplificatore artigianale ECC82
Finale : Sonance Sonamp 275 SE
Amplificatore integrato Classe D : Wosong WA-205 (TK2050)
Amplificatore integrato Classe D : TA2022 2x90W
Subwoofer : Mivoc Hype 10 G2
Diffusori Frontali : Tannoy Mercury V1 (condivisi tra i due impianti con Dynavox Amp-S)
Centrale : Dynavoice Magic CR-5
Satelliti : Magnat Supreme 102
Cavi di segnale RCA : Wireworld Luna 7
Cavo diigitale coassiale : Ricable Hi-End DH1
Cavi di Potenza : Ricable Speaker Premium
Re: Sonance Sonamp 275 SE Consigli Tecnici
Alla prima domanda ho trovato risposta, collegato un sub attivo, funziona tranquillamente, come supponevo è un'uscita di linea.
Per il secondo dubbio, appena ho tempo lo tiro fuori dal mobile, lo apro e controllo come sono settati i jumper dell'hi-pass filter e, se attivo, lo disattivo visto che dal manuale si capisce chiaramente che serve come protezione per i controlli di volume dei diffusori a incasso.
» Consigli tecnici e non per un nuovo impianto
» Pareri e consigli dai tecnici del forum : Bravo Amp v2
» C'è mica qui un vecchio e decrepito tecnico con un barlume di memoria
» ALIENTEK D8 [parte 1]
» Chi mi spiega perchè ? (Per tecnici)
Ieri alle 23:52 Da Darios8
» Indiana line Arbour 4.02
Ieri alle 10:09 Da fabioc978
» ELIPSON HERITAGE XLS 11
Ven 6 Set 2024 - 17:07 Da Darios8
» Lonpoo LP42X - Amplificate
Ven 6 Set 2024 - 14:37 Da magistercylindrus
» Kit per bmw x5
» consiglio/parere
Ven 30 Ago 2024 - 10:55 Da arthur dent
Gio 29 Ago 2024 - 15:13 Da ste-65
Gio 29 Ago 2024 - 1:52 Da valterneri
Mer 28 Ago 2024 - 12:39 Da root
Lun 26 Ago 2024 - 21:02 Da derbi659
» Pre Phono Nakamichi
Lun 26 Ago 2024 - 15:22 Da Silvi89
Lun 26 Ago 2024 - 12:10 Da Simozena
Lun 26 Ago 2024 - 8:32 Da GLR
Dom 25 Ago 2024 - 14:37 Da angelo1968
» Consiglio finale 2 ch
Dom 25 Ago 2024 - 10:51 Da cdr700
» Vestlyd V15C
Sab 24 Ago 2024 - 0:05 Da Zio
Ven 23 Ago 2024 - 23:53 Da Zio
Gio 22 Ago 2024 - 0:59 Da TRIPLALLOSCADERE
» Giradischi Technics
Mer 21 Ago 2024 - 15:13 Da valterneri
