Non usate i LED Blu
+8
daniele
Capi762000
pincellone
12 partecipanti
Non usate i LED Blu Empty Non usate i LED Blu
Messaggio Da pincellone Sab 25 Ott 2008 - 7:59
Molti lo sapranno, ma alcuni sicuramente no. I led blu sono belli da vedere, ma sono molto pericolosi per la retina. La cosa migliore e' evitare di usarli nei propri apparecchi. Se notate, nessuna apparecchiatura consumer li usa...
http://texyt.com/bright+blue+leds+annoyance+health+risks
http://www.ncbi.nlm.nih.gov/pubmed/11692615
[Retinal hazard from blue light emitting diode]
Koide R, Ueda TN, Dawson WW, Hope GM, Ellis A, Somuelson D, Ueda T, Iwabuchi S, Fukuda S, Matsuishi M, Yasuhara H, Ozawa T, Armstrong D.
Department of Ophthalmology, School of Medicine, Showa University, 2-14-19 Nishinakanobu, Shinagawa-ku, Tokyo 142-0054, Japan.
PURPOSE: To compare the effect of exposure time from a blue(460 nm) light emitting diode(LED) on the morphology of the outer retina and determine conditions where damage occurs. MATERIALS AND METHODS: Young adult rhesus monkeys were anesthetized, and received blue LED exposure from a modified slit-lamp. A 3 mm beam of 0.85 mW was imaged onto the retina through a lens positioned before the cornea and exposure damage was determined at time intervals for 12 to 90 min. Fundus photography, fluorescein angiography(FAG), retinal tomography(HRT), and s-cone electororetinogram(S-ERG) were recorded at baseline, 2, and 30 days. RESULTS: Two days after 40 min exposure, there was a grey, discolored region, which was over-fluorescent in FAG, and an incresse in HRT and S-ERG corresponding to the site which was exposed to LED light. In histological examination at 30 days, the LED had caused produced a marked disruption of the disks of photoreceptor cells, damaged retinal pigment epithelium(RPE) apical villi, and a loss of RPE melanin after 90 min exposure. CONCLUSION: A threshold level was found around 40 min. This morphological damage may impair function and continuous exposure to blue light is potentially dangerous to vision.
PMID: 11692615 [PubMed - indexed for MEDLINE]
Ultima modifica di pincellone il Dom 26 Ott 2008 - 11:17 - modificato 1 volta.
pincellone
pincellone
Data d'iscrizione : 14.06.08
Numero di messaggi : 2867
Non usate i LED Blu Empty Re: Non usate i LED Blu
Messaggio Da Capi762000 Sab 25 Ott 2008 - 9:58
Mah, leggendo l'articolo le mie conclusioni sono decisamente diverse:
NON SOVVENZIONATE QUESTI PSEUDOSCIENZIATI
[ma se proprio dovete almeno lasciate che siano loro a trarre conclusioni dai propri studi]
Povere scimmie Sad
Capi762000
Numero di messaggi : 50
Provincia : PG
Impianto : Fantastico!
Messaggio Da pincellone Sab 25 Ott 2008 - 10:14
Mi spiace per le scimmie, ma e' un dato di fatto che il led blu ha un onda molto piu' corta degli altri, quindi piu' intensa e penetrante. Al buio ci si accorge che e' molto luminoso rispetto ai led rossi o verdi.
Meglio non guardarli troppo in ogni caso...
pincellone
pincellone
Messaggio Da Barone Rosso Sab 25 Ott 2008 - 10:43
Il blu è molto vicino al violetto e agli ultravioletti quindi la cosa è realistica, visto che questi due tipi di luce non fanno di certo bene agli occhi.
Poi, se qualcuno ne sa qualcosa, bisogna vedere quanto il comportamento dei normali led è simile ai laser (luce sincrona). Sperando che nessuno usi i led laser.
Messaggio Da Silver Black Sab 25 Ott 2008 - 13:34
Capi762000 ha scritto:NON SOVVENZIONATE QUESTI PSEUDOSCIENZIATI
Perchè PSEUDO? Hai informazioni e dati in merito che ti facciano propendere per questa definizione della "Department of Ophthalmology, School of Medicine, Showa University, 2-14-19 Nishinakanobu, Shinagawa-ku, Tokyo 142-0054, Japan"?
Povere scimmie Sad
Ma sì, era meglio provare direttamente sull'uomo... Ironic
Accidenti, mi sto preoccupando per il led blu molto forte del mio GC... vabbè che lo coprivo sempre, però... adesso che lo so lo coprirò davvero sempre! I see
Numero di messaggi : 16700
Messaggio Da diechirico Sab 25 Ott 2008 - 14:13
pincellone ha scritto:Mi spiace per le scimmie, ma e' un dato di fatto che il led blu ha un onda molto piu' corta degli altri, quindi piu' intensa e penetrante. Al buio ci si accorge che e' molto luminoso rispetto ai led rossi o verdi.
giusto una precisazione, altrimenti rischiamo di far confusione.
in verità è il contrario: il rosso ha capicità di penetrare la materia molto più alte del blu.
infatti il rosso segue nello spettro elettromagnetico l'infrarosso, che conteiene frequenze molto più penetranti.
"penetranti" significa che la luce fa un cammino più lungo nella materia prima di essere assorbita.
di solito i led hanno bande di emissione abbastanza strette, ma nulla a che vedere con i laser, che emettono ad una singola frequenza.
evitamo di confondere tutti questi concetti, o ne esce una gran confusione.
tipo: attenti al nucleare oppure al CERN voglio ricreare un buco nero....
andiamoci cauti.
il problema, oltre alla lunghezza d'onda è l'intensità, ovviamente!
ciao!
Data d'iscrizione : 24.09.08
Numero di messaggi : 4745
Impianto : Grundig R25
Marantz ND8006
Grundig 1500 a Prof
Messaggio Da Capi762000 Sab 25 Ott 2008 - 15:51
Non mi riferivo al dipartimento Sergio ma alle metodologie utilizzate dagli scienziati firmatari della ricerca. Io sono una di quelle persone per il quale il fine non giustifica il mezzo, soprattutto in ambito scientifico, la ricerca a tutti i costi non è mai un bene. L'etica dovrebbe sempre guidare la ragione, in questo caso non mi sembra si studi la cura per il cancro.... Quindi magari prestare un po più di attenzione agli essere viventi ed al pianeta che ci circonda non sarebbe poi così male.
Silver Black ha scritto:Ma sì, era meglio provare direttamente sull'uomo... Ironic
Magari potresti aver ragione:
http://www.politichecomunitarie.it/comunicazione/7989/migliorare-la-direttiva-ue-sulla-sperimentazione-animale
Capi762000
Provincia : PG
Messaggio Da nd1967 Sab 25 Ott 2008 - 16:03
Silver Black ha scritto:Accidenti, mi sto preoccupando per il led blu molto forte del mio GC... vabbè che lo coprivo sempre, però... adesso che lo so lo coprirò davvero sempre! I see
Secondo me il problema non sono sicuramente il led dei nostri apparecchi.
Quanto di noi si mettono a fissarli? Lol eyes shut
Io però sul mio kingrex ho incollato sul led un pezzettino di nastro isolante fatto di due strati.
Quello sotto rosso quello sopra nero con un buco tondo.
L'ho messo sopra il led e ora la luce risulta meno intensa e di un colore blu/viola meno intenso.
Happy shock
Numero di messaggi : 12826
http://www.bnbsusanna.it
Messaggio Da daniele Sab 25 Ott 2008 - 16:59
Grazie per la segnalazione..ottimo a sapersi... Ok Ok
daniele
Data d'iscrizione : 09.09.08
Numero di messaggi : 1740
Provincia : vp
Impianto : Hegel h190
Leak Stereo 20
Thorens td124
DAC Lampizator
Dynaudio sp40
Messaggio Da MaurArte Dom 26 Ott 2008 - 10:56
Il modo di attenuare i led troppo luminosi c'è....
Numero di messaggi : 7338
Messaggio Da nd1967 Dom 26 Ott 2008 - 10:59
MaurArte ha scritto:Il modo di attenuare i led troppo luminosi c'è....
E non ce lo dici! Wink
Da quel che so basta mettere una resistenza... ma è tutto quello che so Razz
Messaggio Da pincellone Dom 26 Ott 2008 - 11:06
Si cambia la resistenza... Ogni led ne ha una collegata in serie. Ma a quel punto e' meglio rimpiazzare il led stesso...
pincellone
pincellone
Messaggio Da MaurArte Dom 26 Ott 2008 - 11:08
La resistenza non basta. Vediamo chi ci arriva Smile Smile Smile
Messaggio Da pincellone Dom 26 Ott 2008 - 11:24
Beh, volendo puoi anche metterci una resistenza variabile (dimmer switch) e regolare l'intensita' come ti pare e piace, ma mi sembra un po' troppo sofisticato come approccio...
Ultima modifica di pincellone il Dom 26 Ott 2008 - 11:27 - modificato 1 volta.
pincellone
pincellone
Messaggio Da MaurArte Dom 26 Ott 2008 - 11:27
Beh, volendo puoi anche metterci una resistenza variabile (dimmer switch) e regolare l'intensita' come ti pare e piace, ma mi sembra un po' sofisticato come approccio...
nonononononono è una cosa piuttosto semplice. Cool Cool
Messaggio Da pincellone Dom 26 Ott 2008 - 11:30
Vabbe' Maurizio, io mi arrendo Very Happy Sicuramente non mi metto a competere con te su queste cose... Facci sapere.
P.
pincellone
pincellone
Messaggio Da MaurArte Dom 26 Ott 2008 - 11:41
Basta non utilizzare il classico ponte di diodi ma un semplice diodo ed una resistenza adeguata prelevando l'alternata direttamente dal secondario.
Messaggio Da pincellone Dom 26 Ott 2008 - 11:58
andiamoci cauti.
ciao!
Questa immagine chiarisce le cose, il led blu e' il piu' "penetrante"...
Non usate i LED Blu Inande10
pincellone
pincellone
Messaggio Da diechirico Dom 26 Ott 2008 - 12:04
è il più intenso, non il più penetrante!!
son due cose ben diverse...
Marantz ND8006
Grundig 1500 a Prof
Messaggio Da Silver Black Dom 26 Ott 2008 - 23:51
MaurArte ha scritto:Basta non utilizzare il classico ponte di diodi ma un semplice diodo ed una resistenza adeguata prelevando l'alternata direttamente dal secondario.
Meno male che era una cosa piuttosto semplice!!!!!!!!!!! Laughing Laughing Laughing
Stavo già pensando a qualcosa di esoterico come fulminare il led con un cacciavite!!! Hehe
Messaggio Da ANTONIO55 Lun 27 Ott 2008 - 8:24
Non si potrebbe semplicemente coprire il led con uno smalto o con un colore che attenui l'intensità della luce?
Il led non scalda granchè, quindi non dovrebbero esserci problemi, altrimenti si cambia con uno di diverso colore.
ANTONIO55
ANTONIO55
Data d'iscrizione : 28.02.08
Numero di messaggi : 325
Provincia : Ottimo dopo la prova con il Gainclone
Messaggio Da Silver Black Lun 27 Ott 2008 - 11:53
ANTONIO55 ha scritto:Non si potrebbe semplicemente coprire il led con uno smalto o con un colore che attenui l'intensità della luce?
Forse con un pennarello nero... Anche lo scotch usato da Andrea non è male, ed è anche un'operazione reversibile, ma è molto più invasivo e brutto da vedere, mentre con il pennarello non si noterebbe nulla. Resta da valutare l'efficacia del pennarello...
Al momento io copro il led con la custodia di cartone di un CD! Oppure consigli di ascoltare gli occhiali da sole... Cool Anche la musica si sente meglio! (scherzo!)
Messaggio Da nd1967 Lun 27 Ott 2008 - 12:12
Silver Black ha scritto:Anche lo scotch usato da Andrea non è male, ed è anche un'operazione reversibile, ma è molto più invasivo e brutto da vedere
Brutto sarai tu Laughing
A parte gli scherzi.... se usi bene forbici/taglierini e fai un bel cerchietto sul nastro isolante, praticamente sull'apparecchio non si vede (a meno che tu non vai a 50 cm....)
Silver Black ha scritto:Al momento io copro il led con la custodia di cartone di un CD!
Ah perché questo invece bello da vedere Razz
Silver Black ha scritto:Oppure consigli di ascoltare gli occhiali da sole... Cool Anche la musica si sente meglio! (scherzo!)
Secondo me anche le punte sotto la poltrona/il divano possono favorire l'ascolto riducendo le vibrazioni Laughing
Messaggio Da Silver Black Lun 27 Ott 2008 - 12:17
nd1967 ha scritto:A parte gli scherzi.... se usi bene forbici/taglierini e fai un bel cerchietto sul nastro isolante, praticamente sull'apparecchio non si vede (a meno che tu non vai a 50 cm....)
Ahhhhhh, e allora dillo!
Io pensavo che usassi due pezzi di scotch a X... Rolling Eyes
Dipende dalla custodia del CD! Wink
Messaggio Da poeta_m1 Mar 28 Ott 2008 - 2:54
Mmm, ma alimentando un led con c.a. a 50Hz, poi non ci sono effetti di flickering (sfarfallìo)?
Riguardo il test sulle povere scimmie, è scritto che la soglia di sicurezza è di 40 minuti... non credo che nessuno si metta a fissare un led blu per più di 2 secondi, o almeno, lo spero!
Ciao!
Poeta®
poeta_m1
Data d'iscrizione : 15.09.08
Numero di messaggi : 222
Occupazione/Hobby : Modellismo, hifi, retrocomputing, auto/moto etc.
