Silverstone Ensemble EB02
Scartabellando nei vari forum americani ho scovato questo piccolino con le seguenti caratteristiche
prezzo $ 149 e, last but not the least, morsetti tradizionali per i diffusori :cyclops:
Necessita indagare Eccovi il link:
http://www.silverstonetek.com/products/p_contents.php?pno=eb02&area=
Special Feature | |
Freedom to pair any book shelf speakers (4Ω/8Ω) to your PC Works with EB01 or other DAC and PC audio source Class T architecture with single chip solution (TA2021B) Very high efficiency (~88%) for low power consumption and high output On/off popping noise suppression Short circuit and over temperature protection Wide dynamic range and low distortion |
stefano- Interessato
- Data d'iscrizione : 23.03.08
Numero di messaggi : 72
Provincia : Gorizia
Occupazione/Hobby : Forza INTER!!!
Impianto : Marantz CD6004
Thorens TD160
Naim Nait XS
Dynaudio focus 110
____________________________________
Virtue Two
diffusori B&W DM 310
(attaccati di rado a qualche sorgente volante)
Re: Silverstone Ensemble EB02
Molto bello! Finalmente design professionale e morsetti di classe e... standard.
Tutti qui a cercare un'alternativa alla delusione "iconica" insoma?!
Ecco le specifiche:
Enclosure
Material Aluminum top cover, SECC steel chassis
Overall dimension 152mm (W) x 176mm (L) x 82mm (H)
Dimension without knob, connectors, and feet 152mm (W) x 156mm (L) x 55mm (H)
Amplifier architecture
Rated output power 15W / per channel (4Ω THD+N=10%)
Frequency response 20 ~ 20K Hz (+/- 0.5dB)
SAMPLING RATE(FS) 32kHz, 44.1kHz, 48kHz
SNR -95dB (1kHz) THD + N 0.002% (typ at 16-bit)
Connectors & cables
Audio in interface Dual gold-plated RCA jack for left and right channels
Audio cables
200mm dual RCA plug to 3.5mm (1/8”) mini plug
200mm dual RCA plug to dual RCA plug
Speaker out interface
Two gold-plated speaker terminals sets for left and right channels
Power supply in 5.5mm DC power connector
Power supply
Total output 60W AC adapter
Dimension 64mm (W) x 31.5mm (H) x 110mm (D)
Ecco le specifiche:
Enclosure
Connectors & cables
Audio cables
Power supply
Silver Black- Amministratore
Numero di messaggi : 16700
Distrattoni...
l'avevo già nel forum.
Andate qui per vedere le foto
http://t-class.niceboard.org/altri-chip-in-classe-t-d-f22/silverstone-ensemble-eb02-ta2021b-t106.htm?highlight=eb02
nd1967- Moderatore
Numero di messaggi : 12826
nd1967 ha scritto:Distrattoni...
Mi sembrava di averlo già visto...
Io sono nuovo e sono scusato.
L'amministratore è per contro deprecabile, perchè dovrebbe conoscere a memoria ogni centimetro quadrato del forum!!!!!!
Ecchediamine!!!
Ecchediamine!!!
Provincia : Gorizia
Thorens TD160
Naim Nait XS
Dynaudio focus 110
Virtue Two
Ecchediamine!!!
Quoto ogni singola sillaba che hai detto.... quasi quasi lo licenzio
nd1967- Moderatore
in italia costa 150 eurozzi!!!!!!!!!!!!!!!! ops!
come volevasi dimostrare.
...e inoltre occhio : il chip usato è il 2021, non il "mitico" 2024 del T-amp, TA10.1, etc.
marioni- Affezionato
- Data d'iscrizione : 16.05.08
Numero di messaggi : 228
Impianto : ampli TA 10.1 con ZetaGi FT146 / casse Klipsch RF82 / meccanica CDP Philips 723 (modificato) / DAC Beresford Caiman
» SilverStone Ensemble EB02 (TA2021B)
» [VENDUTO] Case HTPC Silverstone SST LC17B 50€
» EVOCCO ENSEMBLE
» ART ENSEMBLE OF CHICAGO
» Ensemble Sangineto
» EVOCCO ENSEMBLE
