[IDEA DIY] mediacenter all-in one
+8
tino84
acvtre
12 partecipanti
[IDEA DIY] mediacenter all-in one - Pagina 2 Empty Re: [IDEA DIY] mediacenter all-in one
Messaggio Da tino84 Lun 1 Nov 2010 - 15:10
wasky ha scritto:
Cooler Master Silent Pro 620 watt Smile rumore zero
fuori budget purtroppo Sad
tino84
Data d'iscrizione : 27.11.09
Numero di messaggi : 3534
Messaggio Da Stentor Lun 1 Nov 2010 - 15:11
wasky ha scritto:Ragazzi senza Alimentatori buoni si fà la fine dei MAC G5
Electronic audio interference problems
Early versions of dual processor G5 computers have noise problems. The first one is ground loop-based interference,[5] which sometimes causes noise leaks into the analog audio outputs. This bug was fixed in Rev. B G5.
The second noise problem came from the 'chirping' sound, which can be triggered by fluctuations in power draw. For example, showing and hiding the Dock makes a brief chirp. Many had blamed the power supply used in the G5 as the cause, but this theory has never been confirmed. A very effective work-around is to disable the CPUs' "nap" feature using Apple's CHUD Tools, but this was not recommended by Apple. This noise problem was not fixed until the dual core generation of G5s was produced. The power draw fluctuation was later attributed to the lack of power management features in the single-core processors.[6] Apple eventually posted the chirping bug information on its support site.[7]
Come servono schede Madri con un'ottima alimentazione
Ciao, il mio Silerstone da 300 Watt tira tre Hdd da 2Tb, una Cpu Q8300 e una Vga 9500GT (che ora tolgo visto che l'avevo messa per Snow Leopard che poi ho cancellato....) Hehe Hehe Hehe
Certo un no brand piccolo non è il massimo ....
Messaggio Da Stentor Lun 1 Nov 2010 - 15:13
wasky ha scritto:
tino84 ha scritto:
wasky ha scritto:
Marco trovo impossibile che un alimentatore no brand con 250 watt di picco tiri avanti una conf come quella da te postata Smile una scheda video medio potente di oggi supera in load i 250 watt Smile
controlla i voltaggi Smile
sempre se si accende Laughing Laughing
wasky, apropostio di alimentatori,guarda in off-topic,ho aperto un thread per comprare un alimentatore quasi-serio Smile
Io mi ero portato a casa il silent pro e il Modu87+ di Enermax ...ma poi un pochino di rumore si sente sempre ....li ho riportati indietro e ho preferito tenermi il vecchio Fanless della silverstone che avevo pagato meno dell'enermax Very Happy
Messaggio Da wasky Lun 1 Nov 2010 - 15:18
Un Silverstone viene dichiarato "nominale" ma, per sapere se sottodimensionato devi misurare un molex alla fine della cascata sia sulla 5,5 che sulla 12 e la 3,3 dal connettore ATX quando passi da idle in load Smile e non avere Vdrop Smile
con il tuo stesso processore (8400 ) la DFI 965 una 8800 GTS e due HDD un OCZ da 700 watt non bastava
@ Tino
Forse ho un EZCool da 1000 watt da darti devo ponderare alcune cose
http://www.tecnocomputer.it/prodotti/dettaglio.asp?id_prodotto=4633&id_categoria=7&id_sottocategoria=69
non è modulare ma ti posso fare un bel prezzo se lo vendo
Se ti interessa svendo la piattaforma AMD
Phenom 2 X4 965
Gigabyte 790 FX UD5
GSkill Blu Cl8 1333 Mhz 2gbx 2
Tutto a 320 € con garanzia e imballi e mai overcloccato giuro Smile
Messaggio Da tino84 Lun 1 Nov 2010 - 15:20
wasky ha scritto:
@ Tino
bello si,fammi sapere il prezzo allora Smile
tino84
Messaggio Da Marco Ravich Lun 1 Nov 2010 - 16:01
Dunque, anzitutto l'alimentatore è un'ENlight cinese (http://www.enlightcorp.com/) e la configurazione è la seguente:
  • Pentium D dual core (@ 250 x 11 = 2,75 GHz);
  • RAM 1 modulo Corsair DDR2 800 2Gb (@ 833 MHz);
  • Scheda video PCI-E Nvidia 7300 LE;
  • Disco SATA Seagate Barracuda 7200.10 250 Gb.
Un disco l'ho tolto perché non serviva, ma anche prima non aveva creato problemi.
Ora è sotto stress, ma sembra funzionare tutto correttamente (peraltro @ 64 bit)...
...che vi devo dire, anch'io dubitavo ma mi son dovuto ricredere.
Staremo a vedere.
Data d'iscrizione : 20.04.09
Numero di messaggi : 6070
Provincia : MC
https://www.forart.it/
Messaggio Da Giobax Lun 1 Nov 2010 - 21:54
Preso uno pure io.....speriamo non finisca tra le moooolte cose comprate perchè "sarebbe carino ricavarne..." e poi finite a prendere polvere in cantina... Laughing
Giovanni
Giobax
Giobax
Data d'iscrizione : 29.06.09
Numero di messaggi : 947
Impianto : work in progress
Messaggio Da Stentor Mar 2 Nov 2010 - 0:26
Giobax ha scritto:Preso uno pure io.....speriamo non finisca tra le moooolte cose comprate perchè "sarebbe carino ricavarne..." e poi finite a prendere polvere in cantina... Laughing
Giovanni
....achhhh stavo per comprarlo ma poi ho letto il tuo post e ho pensato agli altri due HT-PC che ho in casa... Shocked Shocked ...
Messaggio Da Marco Ravich Mer 3 Nov 2010 - 11:37
...vedo che qualcuno ha avuto la mia stessa idea:
http://www.newlaunches.com/archives/onkyo_apx2_and_hdc20a_hd_audio_computers.php
http://thomashawk.com/2005/06/empire-series-media-center-pc-serious.html
Provincia : MC
Messaggio Da Stentor Mer 3 Nov 2010 - 14:26
Marco Ravich ha scritto:...vedo che qualcuno ha avuto la mia stessa idea:
In effetti l'idea non è per nulla male Oki
Messaggio Da dtraina Lun 20 Dic 2010 - 21:14
Comprato il case a 10 neuri al marc di Genova !!!
Ora ci si diverte, mi "avanza" una mobo asus con athlon xp64...
Razz
dtraina
dtraina
Data d'iscrizione : 04.05.09
Numero di messaggi : 1806
Impianto : da pianto
Messaggio Da Marco Ravich Lun 7 Feb 2011 - 13:51
AGGIORNAMENTO: ho trovato 'sto sitarello davvero carino...
π-Amp (PC Integrated - Amplifier) Idea
Provincia : MC
Messaggio Da piero7 Lun 7 Feb 2011 - 15:01
ma che bello!!!!
[IDEA DIY] mediacenter all-in one - Pagina 2 1a
Messaggio Da Marco Ravich Lun 7 Feb 2011 - 16:19
...io l'avevo immaginato anche più scenografico (e sopratutto fanless):
Surprised
In qualsiasi caso è uno spunto: dentro si potrebbe migliorare (e di molto) ! Crazy
Provincia : MC
Messaggio Da Marco Ravich Sab 19 Feb 2011 - 12:14
OK, ragazzi, qualche novità:
  1. Ho scritto all'autore del π-Amp esortandolo a rilasciare il progetto sotto Creative Commons... il risultato lo potete vedere sul sito ! Cool
  2. Ho trovato questo simpatico sito dove ci si potrebbe ispirare per qualcosa di esteticamente interessante. Qualche esempio:
    [IDEA DIY] mediacenter all-in one - Pagina 2 149[IDEA DIY] mediacenter all-in one - Pagina 2 001[IDEA DIY] mediacenter all-in one - Pagina 2 028
  3. Ho trovato anche questo interessantissimo progetto DIY per un bel HTPC-case fanless !!!
    Fully passive DIY HTPC case project
    [IDEA DIY] mediacenter all-in one - Pagina 2 L_mp_levy_ja_kovalevyjen_paikat_2_
Sarebbe da fare: π-Amp + fanless HTPC + "woodPC" = strafigata
Che ne pensate ??? Wink
Provincia : MC
Messaggio Da Marco Ravich Mer 16 Mar 2011 - 12:05
UP per annunciare l'arrivo della versione BI-AMP (con xover attivo) del π-Amp: potete seguire l'evoluzione su questo 3ad @ bit-tech.net...
Certo che una versione in classe D (magari con DAC integrato)...
In compenso ho trovato anche 'sto francese che ha costruito questo "wood PC" coi TA2022:
[IDEA DIY] mediacenter all-in one - Pagina 2 198pe
Woodpc 3 v3 , Tripath Amplifier, Analyser, DCX 2496
Provincia : MC
Messaggio Da lucasaudio Mar 5 Nov 2013 - 17:01
Ragazzi, come è andata a finire la costruzione con questo supereconomico case?
lucasaudio
lucasaudio
Data d'iscrizione : 11.04.12
Numero di messaggi : 1333
Impianto : IL MIO IMPIANTO
