EMU Driver per Seven
EMU Driver per Seven Empty EMU Driver per Seven
Messaggio Da wasky Sab 6 Nov 2010 - 2:20
Finalmente non si usano più quelli di Vista per le ottime schede EMU
Release per Schede PCI e PCI Ex
http://connect.creativelabs.com/emu/Files/EmuPMX_PCDrv_US_2_30_00_BETA.zip
E-MU is pleased to announce that we are providing a public Beta driver for all current E-MU PCI/PCI products for use in Windows XP, Windows Vista and Windows 7 32-Bit & 64-Bit versions.
Applies to: 0404 PCI/PCIe, 1212M PCI/PCIe, 1616/1616M PCI/PCIe
** Download is an executable file that contains just the driver. Works with PatchMix v2.1 or greater. You should be able to run it and install it over the top of any existing driver version.
** Some XP users may get asked for permission to replace/overwrite two files. Allow the files to be replaced.
** While this driver should also work for legacy products such as the E-MU 1820, 1820M, 1212 v1, Sync Daughter card and the 02 CardBus PCMCIA card, they have not been tested. These are all discontinued products and will no longer be part of any new software or hardware development nor will they have any further specific updates.
** There is no official support for this Beta driver. Your feedback on this Beta driver is desired and welcome. Contact us via our support email system and select Windows 7 Beta Driver or Windows 7 Beta Driver x64 for the Operating System platform at:
Release per Schede USB
http://connect.creativelabs.com/emu/Files/EMUU_PCAppDrv_US_1_40_00_BETA.zip
E-MU is pleased to announce that we are providing a public Beta driver for all current E-MU USB Audio Interface products for use in Windows XP, Windows Vista and Windows 7 32-Bit & 64-Bit versions.
Applies to: 0202 USB, 0404 USB, Tracker Pre USB
** Download is an executable installer file that contains both the E-MU USB Control Panel and the new Beta driver.
** Please refer to the ReadMe file in the installer package for specifics on this Beta driver.
** There is no official support for this Beta driver. Your feedback on this Beta driver is desired and welcome. Contact us via our support email system and select Windows 7 Beta Driver or Windows 7 Beta Driver x64 for the Operating System platform. E-MU Technical Support is at:
eliminare e precedenti prima di installare i nuovi
