HelderHIFI Pre-Amplifier PCB board
+6
H. Finn
bru.b
mauz
10 partecipanti
Pagina 1 di 3
Pagina 1 di 3 • 1, 2, 3
partendo qui dalla discussione sul s.m.s.l
https://www.tforumhifi.com/t13436-nuovi-smsl-sa-s1-e-sa-s3#210294
sono andato a dare un'occhiata sul negozio di helder audio
http://stores.ebay.it/Helder-HiFi/DIY-assembled-PCBs-/_i.html?_fsub=826598015&_sid=818666075&_trksid=p4634.c0.m322
dove ho visto questo piccolo pre a valvola. cosa se ne potrebbe pensare?
http://cgi.ebay.it/NEW-tube-pre-amp-MKIII-12AU7-fully-assembled-/260710287509?pt=LH_DefaultDomain_0&hash=item3cb38b4895
* HelderHIF Pre-Amplifier PCB board NEW and tested before shipment.
This PCB can be used with a single 12 volts power supply, and needs a 1 Ampere power supply to function properly, this is to cover the peaks in the power usage, normal power use at medium volume is around 200mA.
New features are:
1. Slow start circuit eliminates any DC on the signal line and prevents any POP sounds, the amp starts slowly over 2 minutes building up the DC voltage over the tube ( 40V ) but the heater is started directly.
2. new design is smaller and long and narrow, for easier installation and placement, the Potentiometer is placed on the narrow side
3. ALPS Blue pot is available on request ( costs 10 Euro extra )
4. High Quality film caps used in the audio path
5. Higher Gain than the previous devices, this Pre-amp has a maximal gain of 4, so its perfect for use with IPOD and other low output devices
6. comes fully assembled, no soldering needed
7. specially designed for use with the TA2020/TA2024/TK2050 modules
mauz- Membro classe argento
Numero di messaggi : 3404
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
Re: HelderHIFI Pre-Amplifier PCB board
Ciao Maurizio,
ne hanno parlato quì:
https://www.tforumhifi.com/t5521-12au7-buffer-amp-arjen-helder?highlight=helder
Interesserebbe anche a me..
Guarda quanta robetta si trova sulla baya..
http://shop.ebay.it/?_from=R40&_trksid=m570&_nkw=kit+tube+preamplifier
c'è anche quello che ha elaborato Maurarte:
http://cgi.ebay.it/IMPROVED-6N3-5670-396A-2C51-AUDIO-TUBE-PREAMPLIFIER-KIT-/350267575691?pt=LH_DefaultDomain_0&hash=item518d930d8b#ht_3614wt_1026
Qui il 3d del progetto..
https://www.tforumhifi.com/t740-costruiamo-un-pre-a-valvole-analisi-e-fase-operativa?highlight=preampli
bru.b- Membro classe bronzo
Numero di messaggi : 1394
Provincia : Torino (Ivrea)
Streamer - Rasp 3 + Digione
Aune S6 Pro
perbacco, me l'ero persobru.b ha scritto:Ciao Maurizio,
corro a leggermi tutto.
Ciao Bruno e Grazie!
p.s. sto passando una media di due ore al giorno fisse su ebay
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
una 12au7 alimentata a 12volts? E' un generatore di distorsione!
piero7- Membro classe oro
Ciao Piero,
secondo te fra questi c'è qualcosa di plug and play di discrete prestazioni?
Restando in t-price..
Aune S6 Pro
piero7 ha scritto:una 12au7 alimentata a 12volts? E' un generatore di distorsione!
E proprio quello che vogliono
bru.b ha scritto:Ciao Piero,
Io comprerei il nuovo Fabriziuolo
ragà, ma perché andate dietro a queste cinesate ignobili? Prendete solo la PCB dai cinesi e lo schema e la valvola da usare sceglietela voi! Prendete schemi seri, collaudati e stra collaudati, lasciate perdere gli arrangiamenti, comprate voi il materiale (tanto tra cambi di valvole e di condensatori, tanto vale che ve li acquistate voi i componenti) e fate esattamente come previsto dal progettista senza voler modificare e/o arrangiare, a tutti i costi, qualche cosa...
Preamp Valvolare a Pile da Arjenhelder
Ciao ragazzi.
Immagino che alcuni di voi conoscevano già codesto che io ho visto solo oggi?:
http://cgi.ebay.com/NEW-tube-pre-amp-MKIII-12AU7-fully-assembled-/260710287509#ht_4462wt_1140
non é il solo a pile, ma é il più semplice che ho trovato.
Che ne pensate?
Claudio
Che ne pensate?
Claudio
Numero di messaggi : 2616
Impianto : Cresce... ;-]]
ho unito il tuo post (messo in all'altro thread) a questo 3D, visto che parlano della stessa cosa, e nascono a 12ore di distanza uno dall'altroH. Finn ha scritto:Ciao ragazzi.
non è che nasca per le pile, diciamo che essendo alimentato a 12V, puoi alimentarlo anche col nostro classicone (batteria Pb 12V/7Ah)
Che ne pensate?
operazione che tuttavia ti sconsiglio parzialmente, non fai danni ma il filamento della valvola della valvola assorbe parecchio,
e ti porterà ad una scarica della batteria abbastanza veloce (diciamo 20 max 30 ore?)
per il resto, imho valgono le considerazioni espresse più su, e in altre separate sedi : tensione anodica bassa -> rischio di distorsione elevata..
madqwerty- Moderatore
ammazza
non avevo visto il 3d
scarica batteria..................fa niente, ma: come suona, this is the question, per quelli che come me di diy non ci bazzicano!
c'é pure questo
http://cgi.ebay.com/Hybrid-Headphone-Tube-Pre-Amplifier-6N23P-G2-Class-/250748620802#ht_7245wt_1140
ne aprlano qui:
http://www.diyaudio.com/forums/tubes-valves/180801-low-voltage-tube-pre-amp-t-amp.html
c'é pure questo
ne aprlano qui:
Tra un pò i cinesi tireranno fuori un pre a valvole alimentato a zolfanelli!
hahaha
beh, su diyaudio:
"I have Arjen Helder's 12AU7 board (earlier version, I think MKII) with a TA2020 amp and it does improve the sound - running it off the same 12V 3.5A power supply as the amp. Try to get the board cheaper without the Chinese tube as those do not sound good at all. I tried RCA cleartop 12AU7 and eventually put JAN6189W as it has 'fuller' body."
beh, su diyaudio:
domanda da innocente, perché dovrebbero volerlo?Stentor ha scritto:piero7 ha scritto:una 12au7 alimentata a 12volts? E' un generatore di distorsione!
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
Stesso esperimento: provato pre MKII con TA2020 sempre di Arjen e SMPS da 3.5A. Il risultato è sicuramente piacevole.H. Finn ha scritto:hahaha
beh, su diyaudio:
Certo, non pensiate che questa schedina permetta di avere le stesse prestazioni di un buon pre a valvole. La versione in vendita ora è forse un po' troppo cara.
Numero di messaggi : 3107
Provincia : Sinusoidale
a partire da quale spesa tu, ma anche altri utenti navigati, giudicheresti accessibile un buon pre a valvole?mgiombi ha scritto:Certo, non pensiate che questa schedina permetta di avere le stesse prestazioni di un buon pre a valvole. La versione in vendita ora è forse un po' troppo cara.
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
guarda mau,io non ci capisco molto di valvole...
ma ho ascoltato i consigli di piero e altri e il risultato è stato decisamente soddisfacente,anche io ho preso una scheda cinese sulla baia(la mia era però decisamente peggio rispetto a quelle che fate riferimento voi)poi alla fine è uscito un buon apparecchio.
Se vuoi seguire il travaglio è qui:
http://t-class.niceboard.org/t12846-clone-marantz-7c-vintage
ho buttato via un po di soldi ma alla fine ho recuperato
Numero di messaggi : 1764
Impianto : non finirò mai
di lavorarci
Grazie Andrea per la tua risposta e il tuo consiglio. sicuramente tu e Piero sapete quello che fate e mi piacerebbe anche molto ascoltare le vostre realizzazioni, ma il problem è che io non smanetto neanche un po' e quindi queste soluzioni da inscatolare sarebbero comode a molti, almeno a scopo didattico per chi è alle prime armi. sentiamo se magari Maurarte gli prende le misure..
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
mauz ha scritto:a partire da quale spesa tu, ma anche altri utenti navigati, giudicheresti accessibile un buon pre a valvole?mgiombi ha scritto:Certo, non pensiate che questa schedina permetta di avere le stesse prestazioni di un buon pre a valvole. La versione in vendita ora è forse un po' troppo cara.
primo: dal progetto
secondo: dall'alimentazione
terzo: dalla qualità del materiale utilizzato
quarto: dal layout
prima del quanto costa, contano queste cose.
Ora voler utilizzare a tutti i costi una valvola nata per lavorare a 250V a soli 12V
ti da il metro della misura della qualità, e a prescindere dal costo economico
mi sembra che helder monti un survoltore per far lavorare la valvola a qualche volt in più.
solo una cosa....piero sa quello che fa....io mica tantomauz ha scritto:Grazie Andrea per la tua risposta e il tuo consiglio. sicuramente tu e Piero sapete quello che fate e mi piacerebbe anche molto ascoltare le vostre realizzazioni, ma il problem è che io non smanetto neanche un po' e quindi queste soluzioni da inscatolare sarebbero comode a molti, almeno a scopo didattico per chi è alle prime armi. sentiamo se magari Maurarte gli prende le misure..
di lavorarci
In questo giorni sto ascoltando uno YAQIN MS-12B. Penso che sia un esempio di buon pre accessibile. Peccato per l'unico ingresso di linea.mauz ha scritto:a partire da quale spesa tu, ma anche altri utenti navigati, giudicheresti accessibile un buon pre a valvole?mgiombi ha scritto:Certo, non pensiate che questa schedina permetta di avere le stesse prestazioni di un buon pre a valvole. La versione in vendita ora è forse un po' troppo cara.
La prova su tnt:
http://www.tnt-audio.com/ampli/aaavt_ms-12b.html
E quello di Maurarte liscio?
Dovresti solo acquistare il trasf. ed i componenti..
Aune S6 Pro
piero7 ha scritto:
primo: dal progetto
quarto: dal layout
Grazie Piero!
Provincia : (BI)
NVA a30px
ION Obelisk 100
Royd Merlin
Raspberry PI 4
Topping E30
SONY CDP338ESD
SONY XDR F1HD
Raspberry PI 3B+
Allo DigiOne
Topping E30
Topping L30 II
HiFiMan Deva Pro
SoundMAGIC HP1000
» Audiphonics o ArjenHelder ta2024?
» TK2050 8-channel amplifier board 7.1 or 5.1 ........
» TA2024 PCB Audio Integrated Amplifier Board
» Sure TA2024 D-class Audio Amplifier Board aiuto!!!
» 5532 + 3886 Power amplifier board + Protection circuit
Pagina 1 di 3
Oggi alle 0:09 Da ste-65
Ieri alle 23:56 Da Quaiozi!
Ieri alle 22:40 Da lello64
Ieri alle 11:13 Da embty2002
Ieri alle 10:16 Da Chardonnay
