Trends PA-10 Tube Headphone
Tigre Della Tazmania
Prisma_
Ricevo oggi dalla Trends Audio l'annuncio di un nuovo amplificatore per cuffie, qui sotto vedete il messaggio che ho ricevuto in quanto ho registrato la matricola del mio TA10.1 presso il loro sito.
Per il momento non ci sono ne foto ne prezzi, ho già chiesto e appena li riceverò ve li giro.
Saluti e buone feste.
Prisma_
Dear Prisma,
Trends PA-10 Tube Headphone/Pre Amplifier is released -
High end but not priced audio product.
Thank you for purchasing Trends Audio's products !
After a fairly long and extensive beta-test period, the Trends
PA-10 Tube Headphone/Pre Amplifier is finally released. It
represents a major new technology of Hi-Fi products, containing
a long list of unique features:
- the innovative circuit design of low voltage hybrid (tube/transistor)
pre-amp to provide audiophile quality sound, compact size, and
easy/safe DIYer accessibility
- pure class-A circuit to provide the best sound performance
- support both 6DJ8/6922 series and 12AU7 series tubes by simply
switching the jumpers. DIYers can easily change their both series
tubes to enjoy the fun.
- ONE bi-triode 6DJ8/6922 or 12AU7 tube as voltage amplification and
TWO MOSFETs as output driver which perform the warm, comfortable
tube sound and in addition, guarantee the high fidelity & sufficient
driving power to the next power amplifier stage.
- provide all functions of headphone amplifier, pre-amplifier and
phono pre-amplifier
- provide TWO sets of switching audio inputs. Besides the normal CD
input, the Phono input with higher gain is provided for small output
turntable or PC sound card. No separated phono pre-amplifier
is required.
- Besides the normal audio output in the back panel, ONE headphone
output in the front to drive even high-impedance audiophile-grade headphones
- compact design (mini-size & light weight), suitable for hi-fi room,
living room, sleeping room or even right beside your laptop computer.
- TWO precise screw-driving potentiometers for professional audiophiles
to adjust the tube’s bias voltage to guarantee the best working point
for different tubes.
- require just a single +24V power supply ONLY, besides the bundled
AC adaptor, audiophiles can apply all other power supply with the
same spec., e.g. lead-acid batteries.
- a specially designed AC power adaptor with extra low ripple & noise
for Hi-Fi device is bundled for continuous power supply
- separate pre-amp unit & power adaptor to minimize interference and
flexible to apply other power sources, e.g. lead-acid battery.
Please feel free to contact our dealer near you and send your email
to sales@trendsaudio.com if you want to have this Great Audiophile
Gifts in 2009.
Merry Christmas & Happy New Year !
Regards,
David HO
TrendsAudio
Unit E, 13/F, World Tech Centre,
95 How Ming Street, Kwun Tong, Hong Kong.
Tel: (852) 2566 5810
Fax: (852) 2566 5740
Email: sales@TrendsAudio.com
SKYPE: itok_david
http://www.TrendsAudio.com
MSN: davidh@itok.com
Prisma_
Dear Prisma,
phono pre-amplifier
is required.
Gifts in 2009.
Regards,
David HO
TrendsAudio
SKYPE: itok_david
Ultima modifica di nd1967 il Gio 18 Dic 2008 - 19:17 - modificato 2 volte. (Motivazione : aumentata dimensione carattere)
Prisma_- Interessato
- Data d'iscrizione : 11.08.08
Numero di messaggi : 96
Occupazione/Hobby : */Suono e ascolto musica.
Impianto : Console: PC Linux Mint - DacMagic - T2024 - Klipsch RB81
Sala: Burson Audio PRE-100, PI-100 power amp, RFE Florentia
Re: Trends PA-10 Tube Headphone
Prezzi (dal sito http://www.trendsaudio.com/):Per il momento non ci sono ne foto ne prezzi, ho già chiesto e appena li riceverò ve li giro.
Pre-order price: USD199
After Jan 12, 2009: USD225
Saluti a go-go,
Grrr...
Tigre Della Tazmania- Appassionato
- Data d'iscrizione : 07.10.08
Numero di messaggi : 372
Impianto : Grrr...
Altre foto al sito rinnovato qui:
http://www.trendsaudio.com/pa_desc.htm
Saluti a tutti, Buon Natale e Felice Anno Nuovo.
Prisma_
Prisma_
Mi sembra proprio un Little Dot 1+ (valvola + mosfet) con un prezzo diverso...
Ospite- Ospite
Trends Audio PA-10
Qualcuno ha avuto modo di provarlo? Impressioni?
Ora è disponibile anche su playstereo...
http://www.playstereo.com/product_info.php?products_id=896
Numero di messaggi : 3107
Provincia : Sinusoidale
Ho spostato al seguente risposta
in un nuovo tread dedicato
http://t-class.niceboard.org/cuffie-e-amplificatori-dedicati-f43/little-dot-1-t2068.htm
robertor ha scritto:il little dot 1+ che segnalava mulo adotta 2 tubi termoionici ed è up gradabile.
poi. cosa di non poco conto, costa meno della metà.
non gestisce tutte le tipologie di cuffia, nel senso che è limitato.
però è di gran lunga più bello del trends.
nd1967- Moderatore
Numero di messaggi : 12826
Finalmente è arrivata la recensione su TNT.
http://www.tnt-audio.com/ampli/trendsaudio_pa-10.html
Io un pensierino, come pre, ce lo farei.... !
Ultima modifica di nd1967 il Lun 2 Mar 2009 - 10:12 - modificato 1 volta. (Motivazione : sistemato link)
K8- Membro classe bronzo
Numero di messaggi : 1194
si, ma la conclusione dell'articolo non è che sia incoraggiante.
'ottimo sistema per il pc'...
però, c'è da dire che ci stiamo allontanando - come per il t-rex - dalla nostra filosofia:
il TA con questo pre va sui 400eu.
sicuri che sia il meglio che si riesca a trovare a questa cifra?
gli ingressi sono pure pochi e non c'è neanche l'ingresso phono mm.
mah, ho qualche dubbio...
non è che si sta cavalcando a bestia l'onda T per proporre anche vecchi progetti con prezzi all'apparenza accattivanti?
scusata la considerazione...
PS
Antò, aspetto ancora il tuo iban!!!
PS
Numero di messaggi : 4745
Impianto : Grundig R25
Marantz ND8006
Grundig 1500 a Prof
Sinceramente con 24V non so cosa si possa ottenere da un ecc88, è meglio puntare su un buon pre, magari non a tubi, dove ci sono anche un po' d'ingressi in più.
Ciao.
Ciao.
meral964- Membro di riguardo
Numero di messaggi : 765
Impianto : In Firma.
MaurArte ha scritto:Ragazzi per me costa troppo, con 24V di anodica ci si fa veramente poco.
Consiglio questo (se riuscite ad acquistarlo)
YAQIN MS-12B
Suona bene, è completo e con quelche ritocco è davvero un buon pre.
Ho aperto un nuovo tread per il preamplificatore YAQIN MS-12B
http://t-class.niceboard.org/preamplificatori-f41/preamplificatore-yaqin-ms-12b-t2103.htm
nd1967- Moderatore
» Tube Headphone/Pre-amp
» Portable Rechargeable Tube headphone amplifier Li-battery
» Vari progetti amplificatori cuffia
» Mini 6J1 tube headphone preamplifier
» SENSE G1 USB DAC Class A Tube headphone amplifier
