Condensatori: come funzionano
Vi siete mai chiesti che differenza c'e' tra un condensatore e una batteria? Come funziona un condensatore e a cosa serve?
Qui ci sono le risposte, purtroppo in inglese...
http://electronics.howstuffworks.com/capacitor.htm/printable
Introduction to How Capacitors Work
In a way, a capacitor is a little like a battery. Although they work in completely different ways, capacitors and batteries both store electrical energy. If you have read How Batteries Work, then you know that a battery has two terminals. Inside the battery, chemical reactions produce electrons on one terminal and absorb electrons on the other terminal. A capacitor is much simpler than a battery, as it can't produce new electrons -- it only stores them.
In this article, we'll learn exactly what a capacitor is, what it does and how it's used in electronics. We'll also look at the history of the capacitor and how several people helped shape its progress.
Inside the capacitor, the terminals connect to two metal plates separated by a non-conducting substance, or dielectric. You can easily make a capacitor from two pieces of aluminum foil and a piece of paper. It won't be a particularly good capacitor in terms of its storage capacity, but it will work.
In theory, the dielectric can be any non-conductive substance. However, for practical applications, specific materials are used that best suit the capacitor's function. Mica, ceramic, cellulose, porcelain, Mylar, Teflon and even air are some of the non-conductive materials used. The dielectric dictates what kind of capacitor it is and for what it is best suited. Depending on the size and type of dielectric, some capacitors are better for high frequency uses, while some are better for high voltage applications. Capacitors can be manufactured to serve any purpose, from the smallest plastic capacitor in your calculator, to an ultra capacitor that can power a commuter bus. NASA uses glass capacitors to help wake up the space shuttle's circuitry and help deploy space probes. Here are some of the various types of capacitors and how they are used.
Capacitor Circuit
In an electronic circuit, a capacitor is shown like this:
When you connect a capacitor to a battery, here's what happens:
Once it's charged, the capacitor has the same voltage as the battery (1.5 volts on the battery means 1.5 volts on the capacitor). For a small capacitor, the capacity is small. But large capacitors can hold quite a bit of charge. You can find capacitors as big as soda cans that hold enough charge to light a flashlight bulb for a minute or more.
Even nature shows the capacitor at work in the form of lightning. One plate is the cloud, the other plate is the ground and the lightning is the charge releasing between these two "plates." Obviously, in a capacitor that large, you can hold a huge amount of charge!
Let's say you hook up a capacitor like this:
Here you have a battery, a light bulb and a capacitor. If the capacitor is pretty big, what you will notice is that, when you connect the battery, the light bulb will light up as current flows from the battery to the capacitor to charge it up. The bulb will get progressively dimmer and finally go out once the capacitor reaches its capacity. If you then remove the battery and replace it with a wire, current will flow from one plate of the capacitor to the other. The bulb will light initially and then dim as the capacitor discharges, until it is completely out.
In the next section, we'll learn more about capacitance and take a detailed look at the different ways that capacitors are used.
Farad
A capacitor's storage potential, or capacitance, is measured in units called farads. A 1-farad capacitor can store one coulomb (coo-lomb) of charge at 1 volt. A coulomb is 6.25e18 (6.25 * 10^18, or 6.25 billion billion) electrons. One amp represents a rate of electron flow of 1 coulomb of electrons per second, so a 1-farad capacitor can hold 1 amp-second of electrons at 1 volt.
A 1-farad capacitor would typically be pretty big. It might be as big as a can of tuna or a 1-liter soda bottle, depending on the voltage it can handle. For this reason, capacitors are typically measured in microfarads (millionths of a farad).
To get some perspective on how big a farad is, think about this:
If it takes something the size of a can of tuna to hold a farad, then 10,080 farads is going to take up a LOT more space than a single AA battery! Obviously, it's impractical to use capacitors to store any significant amount of power unless you do it at a high voltage.
Applications
The difference between a capacitor and a battery is that a capacitor can dump its entire charge in a tiny fraction of a second, where a battery would take minutes to completely discharge. That's why the electronic flash on a camera uses a capacitor -- the battery charges up the flash's capacitor over several seconds, and then the capacitor dumps the full charge into the flash tube almost instantly. This can make a large, charged capacitor extremely dangerous -- flash units and TVs have warnings about opening them up for this reason. They contain big capacitors that can, potentially, kill you with the charge they contain.
Capacitors are used in several different ways in electronic circuits:
In the next section, we'll look at the history of the capacitor and how some of the most brilliant minds contributed to its progress.
History of the Capacitor
The invention of the capacitor varies somewhat depending on who you ask. There are records that indicate a German scientist named Ewald Georg von Kleist invented the capacitor in November 1745. Several months later Pieter van Musschenbroek, a Dutch professor at the University of Leyden came up with a very similar device in the form of the Leyden jar, which is typically credited as the first capacitor. Since Kleist didn't have detailed records and notes, nor the notoriety of his Dutch counterpart, he's often overlooked as a contributor to the capacitor's evolution. However, over the years, both have been given equal credit as it was established that their research was independent of each other and merely a scientific coincidence [source: Williams].
The Leyden jar was a very simple device. It consisted of a glass jar, half filled with water and lined inside and out with metal foil. The glass acted as the dielectric, although it was thought for a time that water was the key ingredient. There was usually a metal wire or chain driven through a cork in the top of the jar. The chain was then hooked to something that would deliver a charge, most likely a hand-cranked static generator. Once delivered, the jar would hold two equal but opposite charges in equilibrium until they were connected with a wire, producing a slight spark or shock [source: Williams].
Benjamin Franklin worked with the Leyden jar in his experiments with electricity and soon found that a flat piece of glass worked as well as the jar model, prompting him to develop the flat capacitor, or Franklin square. Years later, English chemist Michael Faraday would pioneer the first practical applications for the capacitor in trying to store unused electrons from his experiments. This led to the first usable capacitor, made from large oil barrels. Faraday's progress with capacitors is what eventually enabled us to deliver electric power over great distances. As a result of Faraday's achievements in the field of electricity, the unit of measurement for capacitors, or capacitance, became known as the farad.
Flash capacitor from a point-and-shoot camera |
- Air - Often used in radio tuning circuits
- Mylar - Most commonly used for timer circuits like clocks, alarms and counters
- Glass - Good for high voltage applications
- Ceramic - Used for high frequency purposes like antennas, X-ray and MRI machines
- Super capacitor - Powers electric and hybrid cars
Capacitor Circuit
©2007 HowStuffWorks |
- The plate on the capacitor that attaches to the negative terminal of the battery accepts electrons that the battery is producing.
- The plate on the capacitor that attaches to the positive terminal of the battery loses electrons to the battery.
Like a Water TowerOne way to visualize the action of a capacitor is to imagine it as a water tower hooked to a pipe. A water tower "stores" water pressure -- when the water system pumps produce more water than a town needs, the excess is stored in the water tower. Then, at times of high demand, the excess water flows out of the tower to keep the pressure up. A capacitor stores electrons in the same way and can then release them later. |
Farad
- A standard alkaline AA battery holds about 2.8 amp-hours.
- That means that a AA battery can produce 2.8 amps for an hour at 1.5 volts (about 4.2 watt-hours -- a AA battery can light a 4-watt bulb for a little more than an hour).
- Let's call it 1 volt to make the math easier. To store one AA battery's energy in a capacitor, you would need 3,600 * 2.8 = 10,080 farads to hold it, because an amp-hour is 3,600 amp-seconds.
Applications
- Sometimes, capacitors are used to store charge for high-speed use. That's what a flash does. Big lasers use this technique as well to get very bright, instantaneous flashes.
- Capacitors can also eliminate ripples. If a line carrying DC voltage has ripples or spikes in it, a big capacitor can even out the voltage by absorbing the peaks and filling in the valleys.
- A capacitor can block DC voltage. If you hook a small capacitor to a battery, then no current will flow between the poles of the battery once the capacitor charges. However, any alternating current (AC) signal flows through a capacitor unimpeded. That's because the capacitor will charge and discharge as the alternating current fluctuates, making it appear that the alternating current is flowing.
© Photographer: Newstocker | Agency: Dreamstime.com A family of capacitors |
Capacitive Touch ScreensOne of the more futuristic applications of capacitors is the capacitive touch screen. These are glass screens that have a very thin, transparent metallic coating. A built-in electrode pattern charges the screen so when touched, a current is drawn to the finger and creates a voltage drop. This exact location of the voltage drop is picked up by a controller and transmitted to a computer. These touch screens are commonly found in interactive building directories and more recently in Apple's iPhone. |
Numero di messaggi : 2867
Re: Condensatori: come funzionano
Mo, come minimo, ce deve da mandà na segretaria esperta in lingua...ops..in lingue.MaurArte ha scritto:Chevvordi???E la traduzione???
Chiu "pile" pe tutti
Ultima modifica di Fabio il Mar 27 Gen 2009 - 10:17 - modificato 2 volte.
Fabio- Membro classe argento
Numero di messaggi : 2518
Provincia : pessimo
Mauri' te c'hai bisogno de capi' ste cose?
Tie' beccate la traduzione in italiano maccheronico fatta con Google:
http://74.125.43.101/translate_c?hl=it&sl=en&tl=it&u=http://electronics.howstuffworks.com/capacitor.htm/printable&prev=hp&usg=ALkJrhgcPFbob6HKSaYFeDj1cMeQ20xWYw
Complimenti!!
ci vogliono questi thread tecnici di approfondimento, specialmente per i niubbissimi come il sottoscritto
spero sia il primo di una lunga serie
Maverick- Affezionato
- Data d'iscrizione : 21.01.09
Numero di messaggi : 174
Impianto : under costruction
Buono come articolo grazie Pince
IcuZ- Membro di riguardo
- Data d'iscrizione : 06.01.09
Numero di messaggi : 631
Provincia : Meteoropatico
•Gainclone NOVA
•Philips Dvp 3264 Mod
•Tesi 504 black
•Cavi artigianali
» Diffusori omnidirezionali ... funzionano ?
» Tube dampers. Per me funzionano
» Tweeter non funzionano ...... come provarli
» Le cose moderne sopra le valvole funzionano...
» Che condensatori per PSU
Oggi alle 19:15 Da Fabiolydia
Oggi alle 13:44 Da Gabriele1
