Opamp A' la Lampizator
K8
pincellone
Opamp a componenti discreti costruito da Lampizzone. Mulo perche' non lo provi e ci dici com'e'?
http://www.lampizator.eu/LAMPIZATOR/FETISHIZATOR/fetishizator.html
OP-AMP Fetishizator a'la Fikus
In 95% of players, the first opamp after the DAC will be a double op-amp like 5532.
What we do,
The J-FET is A type here. For B type - use 2k7 resistors instead of 820 Ohms.
This is the opamp base version of fetishizator - quick and dirty version without attention to neat soldering.
For the single opamps - like BB OPA-604 or AD825 - build a modified version.
If the DAC is wired to the second opamp inside the double unit (pins 6 input, 7 output) - adapt the schematics accordingly. Some designers do so because the second half of opamp is easier to wire depending on PCB layout.
On my drawing I have both sides populated, but usually one double opamp serves one channel so you build a half of fetishizator only, one half per channel.
If you don't trust the existing power supply to the 12V pin (pin (it may be contaminated with noise from clock, from DAC, from motors) you can float pin 8 and build your own supply of 12 V DC (or 15 V DC). That is probably a good thing to do.
What we do,
- we remove the opamp,
- float the leg 1 (output) to isolate the feedback circuit (R and C from input to output)
- solder the new socket in place of opamp
- build the Fetishizator on the second socket
- plug the fetishizator in
- Install new solid RCA's
- wire the pin 1 to the RCA, mount the CAPACITORS (like a 2,2 uF MKP) directly on the RCA's.
- Wire the RCA ground to the PCB ground
- upgrade the capacitor supplying the leg 8 with 12 V DC with a better one like Blackgate, Tantalum or Oscon.
- Voila - It should work.
Numero di messaggi : 2867
Re: Opamp A' la Lampizator
Personalmente non mi interessa.
Mi accontento di un OPA211, AD797BR, LME49710, OPA827.
Ospite- Ospite
Mulo ha scritto:Personalmente non mi interessa.
Certo dopo che hai inondato il forum con le tue recensioni di opamp forse faresti fatica ad accertare la sconfitta.
Bello me lo sono segnato
Barone Rosso- Moderatore
Barone Rosso ha scritto:Mulo ha scritto:Personalmente non mi interessa.
K8- Membro classe bronzo
Numero di messaggi : 1194
Quale sconfitta, scusa?Barone Rosso ha scritto:Mulo ha scritto:Personalmente non mi interessa.
Ospite- Ospite
Mulo ha scritto:Quale sconfitta, scusa?Barone Rosso ha scritto:Mulo ha scritto:Personalmente non mi interessa.
che il lapizator suona meglio ...... dei tuoi opamp
Ma come fai a dirlo se non hai confrontato quell' "operazionale discreto" agli opamp detti più sopra?
Ospite- Ospite
Mulo ha scritto:Ma come fai a dirlo se non hai confrontato quell' "operazionale discreto" agli opamp detti più sopra?
E più bello .
Comunque un classe A secco con un piccolo feedback locale e un buon FET potrebbe fare egregiamente il suo lavoro, provalo.
Forse non l'hai capito che non mi interessa, gli operazionali sono buoni abbastanza...
Ospite- Ospite
Salve,
A me lampizator interessa tantissimo, ma non ho le conoscenze tecniche per districarmi, purtroppo.
ci vorrebbe un tutorial in italiano tipo quelli di Maurarte, anche se devo dire che non sembra così difficile da realizzare.
possibile che nessuno lo abbia già fatto in questo forum?
Per la cronaca , ho uno problema al mio dac Zhaolu Oritek, non si sente più.
da istruzioni di Ori l'ho aperto, e dai test il suo stadio analogico va bene il problema è nella scheda del dac AD1852 originale, quindi nulla da imputargli direttamente.
ma sorpresa, pensavo fosse senza OPA, invece eccolo lì OPA2604AP.
quindi mi piacerebbe davvero sentire un dac lampizator, anche se il mio Oritek prima del guasto mi ha dato grandi soddisfazioni per il prezzo IMHO.
L'idea dei dac e comunque delle sorgenti che mi sto facendo, è che bisogna cercare qualcosa con stadi d'uscita progettati come si deve e poi guardare il chip, IMHO.
Saluti
Francesco
Saluti
Francesco
Numero di messaggi : 1386
embty2002 ha scritto:Salve,
ci vorrebbe un tutorial in italiano tipo quelli di Maurarte, anche se devo dire che non sembra così difficile da realizzare.........
Diciamo che il sito di lapizator è un bordello ... trovarci dentro le cose non è facile.
Comunque non si tratta di un opamp, ma si tratta di un classe A secco basato su un j-fet, soluzione molto diffusa e che funziona bene. E in piena filosofia lapizator, che elimina tutti gli opamp.
Purtroppo, come fa sempre il lapizator, del segnale bilanciato ne prende solo canale. Non penso che sia impossibile usare tutti e due i canali con un ampli non opamp, tipo push pull. È che purtroppo non ho ancora trovato progetti decenti in merito.
Ultima modifica di Barone Rosso il Ven 30 Gen 2009 - 18:34 - modificato 1 volta.
Chiamalo come vuoi, ma Lampizator lo ha denominato "OP-AMP Fetishizator a'la Fikus"
I nomi sono nomi
ma questa è la versione completa.
http://www.lampizator.eu/LAMPIZATOR/FETISHIZATOR/JFET_CDout.pdf
Classe A con tanto di alimentazione lineare stabilizzata (che si potrebbe eliminare a seconda dei gusti).
lo tiro su sto topic
perche volevo realizzarlo...
ma c'è un problema bisogna dimensionarlo e scegliere i fet giusti in base alla tensione, a quanto ho capito...
se c'è qlc che ci capisce e ha voglia di aiutarmi...
per scegliere il fet giusto sono indeciso tra a e b, ma credo proprio che il corretto sia B
forse maurarte sta facendo la stessa modifica...
datasheet fet
http://www.datasheetcatalog.com/datasheets_pdf/B/F/2/4/BF245A.shtml
datasheet dac
http://www.asahi-kasei.co.jp/akm/en/product/ak4385/ak4385_f01e.pdf
http://www.asahi-kasei.co.jp/akm/en/product/ak4385/akd4385-sc1-01e.pdf
datasheet fet
datasheet dac
ANDR3A101- Membro di riguardo
Numero di messaggi : 673
Provincia : mah se tira...
Lucio Cadeddu...
ANDR3A101 ha scritto:lo tiro su sto topic
datasheet fet
datasheet dac
Si tratta di un prefet in classe A, NON È un opamp.
Inoltre lo schema che mostra è stato fatto per il pilotaggio in corrente e non in tensione, quindi dovresti adattare una parte del circuito.
lo so che non è un opamp...
pero se non leggi i dati del dac, non si puo variare il circuito, e questo decide se usare A o B
cmq apparte fare la modifica per la conversione, che devo fare?
Lucio Cadeddu...
ANDR3A101 ha scritto:lo so che non è un opamp...
Devi mettere una resistenza da 1 MOhm fra il gate e la massa oltre al potenziometro, inoltre bf245a potrebbe reggere a delle tensioni picco picco piuttosto basse, quindi potrebbe essere inadatto ad un pilotaggio in tensione classico.
Inoltre Io l'avevo sperimentato con tutti i condensatori indicati nello schema del tipo Austriaco e non andava.
ok grazie...
ma che centra il pot?
tu lo hai provato?
guarda, io lo avevo preso in considerazione perche era un ottimo stadio d'uscita meglio degli opamp...
pero a te non funziona? non suona proprio?
tu lo hai provato?
Lucio Cadeddu...
ANDR3A101 ha scritto:ok grazie...
tu lo hai provato?
Entrava in oscillazione e penso che il problema stia nei condensatori sotto al source.
hai mai pensato di risolverlo? ne vale la pena?
hai qlc idea? su come sistemarlo intendo...
perche se non è difficile vorrei farlo io...
Lucio Cadeddu...
ANDR3A101 ha scritto:hai mai pensato di risolverlo? ne vale la pena?
Riferendomi a questo:
Prova ad eliminare i condensatori (c4 c5 c6 e c9), ma continuo a pensare che il livello di ingresso ammissibile resterebbe sempre troppo basso.
Il progetto originale di lapizator usa una tensione di polarizzazione sbagliata e non ha un buffer in uscita. [Ma bisogna notare che anche il prefet di Maurarte usa una polarizzazione apparentemente sbagliata e riesce sempre a funzionare e il transistor è lo stesso un bf245b].
a questo punto aspetto... perche maurarte stava sviluppando proprio questo...
se no poi al limite se e troppo complicato, cambio semplicemente l'opamp, anche se non è la cosa migliore...
Lucio Cadeddu...
Prova a seguire il topic di moaps su diyaudio forum trovi il PCB, schema e il bill del suo operazionale a discreti
http://www.diyaudio.com/forums/showthread.php?postid=319300
Roberto
Roberto
grazie...
Lucio Cadeddu...
il fetishizator l'ho montato ma a me risulta che il fet in basso deve essere girato per funzionare correttamente.
» lampizator
» lampizator
» lampizator a pagamento
» Ho acquistato il Lampizator dac
» Lampizator Speaker's
» lampizator
