Metrum Acoustics NOS mini DAC Octave - recensione su tnt-audio
+18
Menestrello
lorenzo mordini
c3kkos
graziano111
kurt10
Telstar
alluce
Vella
Cella
yulian
sickshotshow
blackhole
n.enrico
settore 7-g
22 partecipanti
Pagina 2 di 4
Pagina 2 di 4 • 1, 2, 3, 4
Re: Metrum Acoustics NOS mini DAC Octave - recensione su tnt-audio
Toglierle o lasciarle con il cancelletto non fa nessuna differenza.
Nel frattempo, tenendo conto che il chip C-Media CM6331 usato dall'USBridge è presente anche nel convertitore Schiit, ho trovato questa discussione interessante:
http://www.computeraudiophile.com/f10-music-servers/new-linux-os-aimed-computer-audiophiles-voyage-mpd-5505/index14.html
Il DAC Schiit (nella versione con entrata USB) ha lo stesso problema sotto linux. Qualcuno ha già contattato la CMedia per risolvere il problema.
When I start a playlist of mixed bit and sample rate songs on an Alix 2d2 out to a Bifrost some songs, almost always when the song is a different bit or sample rate, start distorted and (fortunately) at a lower volume. Anyone had a similar experience?
I have tried the same playlist on a Mac Mini out via USB to the Bifrost with no problem - suggesting it's not a Bifrost issue.
Am using a NAS for the Alix but copied the songs to the Mac's HDD. One interesting thing is that this very occasionally also happens when first pressing play on a playlist of all-16-bit songs. Once corrected - by pressing 'Stop' and then 'Play'- the rest of the playlist executes fine. Am using MPoD as the client - not that that should have anything to do with this.
The Bifrost uses the CM6331 USB interface chip. I have been in contact with CMedia about this and they have committed to look into the issue. More pressure always helps.
blackhole- Affezionato
- Data d'iscrizione : 29.11.09
Numero di messaggi : 223
Provincia : Padova
Impianto : Impianto principale
Roon + HQplayer con AudioLinux ottimizzato realtime con Streacom Skylake i6700 + Amanero con filtro passivo DSD o Holo Audio Spring + Minute preamp (Silk Transformer Volume Attenuator STA-522A) + Ayon Sunfire + Goertz Python + Audiostatic DCI A-Sinus
2 impianto
Smartphone Xiaom Mi Max + Odac + Trends TA-10.2 + cuffia Jecklin Float Electrostat
blackhole ha scritto:Io lo possiedo ormai da un po' di tempo ormai e non sono d'accordo con quanto detto nella recensione sugli alti.
Certo, siccome è un NOS, gli alti sono leggermente tagliati verso i 20000 Hz con materiale a 44,1 Khz, ma a 96 e 192 khz la linearità è pressoché perfetta.
Tali considerazioni sono confermate dagli ascolti nel mio impianto in firma con Jriver/Jplay come player: alte a volte in evidenza e definizione ad altissimi livelli.
Il problema è che il Metrum octave suonerà molto diverso in differenti impianti per due motivi principali:
1) Non ha particolari circuitazioni per la rimozione del jitter. Se il segnale proveniente dall'adattatore USB/Spdif del computer non è perfetto il Metrum non si esprimerà ai massimi livelli. Consiglio pertanto di selezionare attentamente l'eventuale adattatore. Ad esempio il mio MHDT USBridge (con due clock separati) e lo Stello U3 si sono rivelati adatti allo scopo.
2) Non avendo veri e proprio stadi di uscita in molte situazioni sarà necessario usare un preamplificatore o un buffer. Questo mi ha lasciato perplesso poiché l'impedenza d'uscita del Metrum è intorno agli 88 ohm con più di 2V nominali, ma la mia esperienza mi insegna che questo non è l'unico parametro da prendere in considerazione. Inserendo un buffer a valvole tra il Metrum e il Trends sono sparite tutte quelle caratteristiche che a volte rendono improponibile il collegamento diretto e che sono tipiche di molti impianti con pre passivo. Non è escluso ovviamente che in altre situazioni il collegamento diretto porti ad ottimi risultati.
Un'ultima nota. Nel campo della musica riprodotta con il computer tutto è molto relativo. Ieri (poiché ho una lunga esperienza con linux sopratutto nel campo multimediale) ho riprodotto gli stessi brani con Archlinux con kernel realtime usando un hard disk esterno. Ho usato MPD con Jackd (Jack audio connection kit) ma anche Deadbeef con uscita diretta bit perfect su alsa (in Deadbeef si possono impostare i valori di "Periods" e "Buffer" manualmente). Il risultato è stato incredibilmente diverso. Il suono è di una chiarezza disarmante. Sparita una certa melmosità sui bassi. A questo punto qualcuno potrebbe dire: ma questo è un altro Metrum!
io sono neo iscritto e francamente non ho mai frequentato forum ma in occasione del prossimo arrivo dell'octave mi stavo documentando quando sono icappato nella vs discussione , francamente sono rimasto terrorizzato in quanto non avendo grande dimestichezza com tt i software, non so se ho fatto bene o male a comprare questo dac comunque se qualcuno mi volesse aiutare a capire in maniera elementare il funzionamento col pc sarei vermente grato.
utilizzo windows con una usctita digitale rca e come playe uso foobar
ringrazio anticipatamente
graziano111- Novizio
- Data d'iscrizione : 08.07.12
Numero di messaggi : 11
Impianto : PASS LABS INT150 B&W 804D AUDIO ACCUPHASE DP85
graziano111 ha scritto:blackhole ha scritto:Io lo possiedo ormai da un po' di tempo ormai e non sono d'accordo con quanto detto nella recensione sugli alti.
Ciao Graziano, innanzitutto dovresti passare dall'area presentazioni ...
Per il resto Windows con uscita digitale non vuol dir nulla ...dovresti spiegarti meglio. Se intendi un PC con una uscita digitale spdif integrata sulla scheda madre suonerà da schifo perché l'octave ha un ingresso digitale misero e per dare il meglio ha la necessità di aver a disposizione un ottimo transport e a questo punto ti consiglio di comprarti anche una economica ma ben suonante hiface two.
Ovviamente foobar deve essere settato al meglio e bisogna verificare che il PC abbia una latenza dignitosa...
Se è altro fammi sapere ....
scusa ma come ho detto purtroppo non sono mai intervenuto all'interno di un forum però ho raccolto il tuo invito ed ho provveduto, tornando al problema io attulmente collego il mio dac all'uscita rca gialla penso che sia l'uscita audio della scheda madre il mio pc credo abbia la scheda audio integrata, per quanto riguera la lattenza.......... araboStentor ha scritto:graziano111 ha scritto:
graziano111 ha scritto: abbia la scheda audio integrata, per quanto riguera la lattenza.......... arabo
Non so che scheda audio tu abbia ma fai prima a prenderti una HiFace2 e collegarla direttamente alla prima USB libera del tuo PC.
Ti manca solo un cavo coassiale, un Mogami da 18 euro spedito a casa e hai finito.
Non ti dimenticare un buon cavo di alimentazione... il Metrum é delicato ma ti ripaga dei sacrifici.
flovato- UTENTE BANNATO
Numero di messaggi : 12509
flovato ha scritto:graziano111 ha scritto: abbia la scheda audio integrata, per quanto riguera la lattenza.......... arabo
la scheda audio dovrebbe essere integrata nella scheda madre, il pc è un alieware della DEL. raccolgo con interesse il tuo consiglio ma come posso verificare se l'uscita digitale coassiale non è appropiata e successivamente l'octave ha anche un ingresso ottico potrei usare quello o magari non è consigliato.Inoltre si parlava di latenza e di configurare in maniera opportuna foobar, dove potrei trovare una guida?
o forse mi consigliate un bel grammofono anni 30
Il grammofono é la scelta migliore.
Se la scheda é integrata non hai scelta... pigliati Hiface2 o similari.
L'ingresso ottico del Metrum é buono ma ci vuole un cavo ottico come minimo da 40 euro.
Ho fatto suonare a lungo il Metrum in ottico ma le prestazioni migliori le hai in coassiale.
Un Mogami da mezzo metro e non hai problemi.
Per la latenza lascia tutto a default, non ti avventurare in strani setup, non cambia molto e devi sapere quello che fai.
La latenza diventa fondamentale sugli ingressi per registrare musica live, in uscita hai velocita e memoria adeguati.
Foobar va bene ma ci sono anche altri player su Window interessanti.
Parti con quello e poi hai da divertirti.
Ho assemblato decine e decine di server musicali ....nessuna uscita digitale integrata é stata mai sufficiente ..... Ascolta il suggerimento di Flovato
Se on ti piace hiface two scegline un'altra qualsiasi asincrona ....sarà sempre molto meglio di quella integrata sulla scheda madre
vi ringrazio per i preziosi consigli anche se mediterò sul grammofono con ingressi sbilanciati peccato che non si trovano molti 78giri
un consiglio per foobar: da task manager, click col dx sul processo foobar2000.exe e scegli priorità "realtime"
"meglio che nulla, marito vecchio"
c3kkos- Interessato
- Data d'iscrizione : 07.06.11
Numero di messaggi : 88
Impianto : Scythe SDA-2100 revB
B&W DM602 S3
Marantz CD6000 OSE
experimental use of atv2
ho provato ma nn lo modifica mi dice che è stata impostata priorità alta
che windows hai? col "7" la imposta senza far storie
c3kkos- Interessato
B&W DM602 S3
Marantz CD6000 OSE
si windows 7 64 ma evidentemente atipico come il padrone
ripeto la procuda
con il programma aperto
avvia gestione attivita
tasto dx su foobar
imposta priorità
a questo punto seleziono tempo reale e mi dice impossibile impostare la priorita tempo reale è stata impostata la priorita alta
bho!!!!
ripeto la procuda
tasto dx su foobar
imposta priorità
bho!!!!
la procedura è corretta...
l'unica che mi viene in mente è che l'account con cui ti "colleghi" a win7 non abbia i permessi di amministratore pc e che ti impedisca per cui tali operazioni...
c3kkos- Interessato
B&W DM602 S3
Marantz CD6000 OSE
provo a verificare e ti faccio sapere per il momento tante grazie
Quando usavo foobar c'era un manuale pdf in Italiano che spiegava molto bene perché la latenza era ininfluente.
Da Wiki: In campo informatico, la latenza (o tempo di latenza) di un sistema può essere definita come l'intervallo di tempo che intercorre fra il momento in cui arriva l'input al sistema ed il momento in cui è disponibile il suo output. In altre parole, la latenza non è altro che una misura della velocità di risposta di un sistema.
la latenza è DETERMINANTE.
Chi si ricorda i primissimi masterizzatori CD che, poverini, venivano montati su dei pc che oggi sembrerebbero INUTILIZZABILI?
Dico... io son giovincello ma acquistai il mio primo 6x2x2x al CONTINENTE per 600mila lire e lo montai su un Pentium 133.
Come partiva lo screensaver, durante la masterizzazione, il pc andava in crisi, il buffer di scrittura del masterizzatore SVUOTATO e il cd? buttato via........ (5/6mila lire al tempo..)
Naturalmente non ci sono cd da buttare via ascoltando foobar, e con la potenza di calcolo disponibile su un pc "moderno" è praticamente inutile parlare di problemi latenza con flussi di dati cosi esigui..
c3kkos- Interessato
B&W DM602 S3
Marantz CD6000 OSE
bene il grammofono non l'ho trovato ma l'hiface2 è arrivata ed installata da oggi farò quanche prova d'ascolto con l'auttuale dac in attsa che arrivi l'octave e poi vi farò sapere le impressioni con l'attuale catena
se qualcuno poi mi volesse suggerire come è meglio funzionante l'hiface2 con foobar è bene acetto
cari signori sono ancora qui a chiedere lumi l'octave è arrivato l'ho installato nella mia catena tuttu bene, però come faccio a capire se il file ke sto acoltando effettivamente è nella definizione indicata da foobar nella barra in basso?
potete spiegarmi
saluti
potete spiegarmi
saluti
Mi "intrufolo" in questo topic....arrivato ieri l'Octave,3/4 ore di ascolto,non so quanto tempo deve rodare e che margini di miglioramento possa avere,può piacere o no,ma ha me sembra già magia!
Seguendo le parole di Fabio ho cercato di dedicargli un cavo alimentazione appropriato,bè...mi sembra davvero tanta roba!!!!
Musicalità ad alti livelli e onestamente mi sembra di aver dato completezza ai pezzi di ascolto quotidiano.
Da sottolineare inoltre un pizzico di dinamica in più...di brio insomma.
Tutto ovviamente IMHO.
lorenzo mordini- Membro di riguardo
- Data d'iscrizione : 29.08.11
Numero di messaggi : 917
Impianto : ...aiuto!
lorenzo mordini ha scritto:Mi "intrufolo" in questo topic....arrivato ieri l'Octave,3/4 ore di ascolto,non so quanto tempo deve rodare e che margini di miglioramento possa avere,può piacere o no,ma ha me sembra già magia!
Grande Lorenzo... questo farai fatica a venderlo, benvenuto nel club.
Sappi che il bimbo é sensibile ad ogni cosa... piú roba buona gli dai a monte e meglio suona.
Cavo coassiale Black Cat Veloce... se lo trovi a buon prezzo fammi un fischio che ne prendo uno anche io.
Trasporto di qualità... il tuo Anedio dovrebbe andare a nozze.
Cavi di segnale, Yulian argento o oro/rame o roba seria come quella che di solito usi tu.
Non oso pensare con il Merlino che favola.
Sono contento che ti piaccia, sarà scontato ma ricordati che dopo 100 ore cambia radicalmente... diventa piú morbido e musicale.
Facce sapé.
Dimenticavo... cavo USB WireWorld Starlight... da non credere il miglioramento (da mezzo metro, non piú lungo).
Sto usando,al momento,solo cavetteria by Yulian (coax argento compreso),per l'usb invece uso al momento l'Aquvox.
lorenzo mordini ha scritto:Sto usando,al momento,solo cavetteria by Yulian (coax argento compreso),per l'usb invece uso al momento l'Aquvox.
Mi dispiace darti questa notizia ma AqVox (quello con la ferrite per intenderci) suona proprio malaccio.
Peccato tu sia lontano perché ti presterei volentieri tutto.
Roda, roda, che poi si ascolta insieme
Se poi si sente bene me lo vendi perché tanto vuol dire che è bacato
Numero di messaggi : 3131
Provincia : molesto
Impianto : bacato
Menestrello ha scritto:Roda, roda, che poi si ascolta insieme
Ho un buco nel sedere... dici sia un baco ?
Pensa che ho visto un'altro Conrad Johnson con gli stessi condensatori del tuo... vuoi vedere che quello tarocco é il mio.
» Recensione TNT audio - Metrum Acoustics NOS mini DAC Octave
» Metrum Acoustics NOS Mini DAC "Octave" come suona?
» Metrum Acoustics Octave MKII
» DAC contest sfida a quattro Metrum Octave - Lavry DA11 - Minimax - RME ADI2
» Metrum Acoustic Octave
Pagina 2 di 4
Oggi alle 13:44 Da Gabriele1
