[VENDUTE] [VENDO-PU]un po' di cuffie: AKG K701 130+ss/ Beyer DT880 150+ss/ JVC HA RX 900 40+ss
Come da titolo vendo un po' di cuffie per monetizzare e togliermi altre curiosità
AKG K701 euro 130,oo + ss (con imballo originale)
Beyerdynamic DT880 Edition 32 Ohm euro 150,oo + ss (con imballo originale e valigetta pelle)
JVC HA RX 900 euro 40,oo + ss (senza imballo originale)
CARATTERISTICHE:
AKG K701
Headphones weight without cable (g) 235
- Sensitivity (dB/mW, dB/V*) 105
- Audio bandwidth (Hz to kHz) 10-39,8
- Max. input power (mW) 200
- Rated impedance (ohms) 62
- Convertible jack plug (1/4" to 1/8")
- Replaceable ear pads
- Patented self-adjusting headband
- Exclusive leather headband
- Unbreakable metal arches
- 99.99% oxygen-free cable (length in m) 3
- Single-sided cable
- Hard gold-plated jack plug and contacts
- Patented Varimotion diaphragms
- 2-Layer diaphragm
- Flat-wire voice coil
- Open-back, dynamic headphones
- NdFe magnets
Beyerdynamic Dt880 32 Ohm
Transducer type . . . . . . . . . . . . . . . . Dynamic
Operating principle. . . . . . . . . . . . . . Semi-open
Frequency response . . . . . . . . . . . . . 5 - 35,000 Hz
Nominal impedance . . . . . . . . . . . . . 32 Ω
Nominal SPL . . . . . . . . . . . . . . . . . . 96 dB
T.H.D. . . . . . . . . . . . . . . . . . . . . . . . < 0.2%
Power handling capacity. . . . . . . . . . 100 mW
Sound coupling to the ear . . . . . . . . Circumaural
Nominal headband pressure . . . . . . . approx. 2.8 N
Cable length and type . . . . . . . . . . . 3 m / straight cable
Connection . . . . . . . . . . . . . . . . . . . Gold-plated 1/8" mini stereo
jack plug (3.5 mm)
and 1/4" adapter (6.35 mm)
Weight without cable. . . . . . . . . . . . 290 g
JVC HA RX 900
High-quality dynamic sound reproduction with 50mm Neodymium driver unit and two types of superior sound structure
Ring port structure provides high-quality dynamic sound
Acoustic lens structure reproduces natural sound through two pieces of specially-engineered acoustic lenses
Acoustic lenses (located in front of diaphragm) tune direct and indirect sound by subtly offsetting holes in each lenses
Wide head pad and soft ear pads for optimum comfort
11.48ft(3.5m) pure copper cord for minimization of transmission loss
1/4 inch plug adapter included
Specifications
Driver Unit 1.95"
Magnet type Neodymium
Frequency Response 7-26,000Hz
Nominal Impedance 64ohms
Sensitivity 106dB/1mW
Max. Input Capability 1500mW(IEC)
Cord Length 11.48ft
Weight (without cord) 12.35oz
Plug Gold-plated
Accessory 1/4 inch plug adapter
Code MAX 24 ore, e se è lecito dirlo, nel mercatino ho anche un ampli per chi volesse ottimizzare le spese di spedizione.
In vendita anche su altri lidi, quindi la "CODA" non è garanzia assoluta.
CARATTERISTICHE:
AKG K701
- 2-Layer diaphragm
- NdFe magnets
jack plug (3.5 mm)
JVC HA RX 900
Specifications
Driver Unit 1.95"
Cord Length 11.48ft
Plug Gold-plated
Numero di messaggi : 3693
Provincia : PU
diffusori - Stabilo 880 Woody
il resto è diy montessoriano
Interessato alle DT800 32ohm
...Così poi vendo le mie 990.
Quando posso passare a provarle?...Stasera?
Gas- Affezionato
- Data d'iscrizione : 10.12.09
Numero di messaggi : 238
Impianto : Lettore CD Pioneer PD-S605
Ampli Pioneer A-300R Precision
Sinto Pioneer F-504RDS Precision
incontro per cuffie
- hai MP
ah, dimenticavo... valuto anche permute con materiale di mio interesse tipo:
Beyer DT990
Fidelio X1
Senn HD 600
Fostex 50 RP
Beyer DT990
Fidelio X1
Senn HD 600
Fostex 50 RP
Provincia : PU
Re: [VENDUTE] [VENDO-PU]un po' di cuffie: AKG K701 130+ss/ Beyer DT880 150+ss/ JVC HA RX 900 40+ss
@Gas hai MP
Provincia : PU
K701 venduta
Provincia : PU
DT880 venduta
Provincia : PU
Ritiro la JVC per sottoporla a torture tweakkanti, il resto è già venduto si può chiudere, grazie.
Provincia : PU
» mini rece cuffie: K701 DT880 SRH940 HD650 T50RP Dt990 DT770
» [VENDUTO] (PU) cuffie Beyer DT 990 (100,oo) DT 770 (90,oo) Shure SRH 940 (150,oo)
» [VENDUTO] [Vendo-PU] Vendo cuffie Beyerdynamic DT880 Edition 32 Ohm 150€+ss
» [VENDUTE] [Vendo RM] CUFFIE AKG K272 HD - 100 euro
» [Vendute] Vendo varie cuffie chiuse semi-nuove in garanzia
Oggi alle 13:44 Da Gabriele1
